Jeep back after accident: issues - Page 2 - JeepForum.com
post #16 of 21 Old 05-13-2013, 09:21 AM
ncb
The steering wheel isn't perfectly round or it's not mounted perfectly centered so it gives the illusion of it "dropping" down when you turn it 90 degrees left or right. I'd post pics but I can't size pictures small enough for JF. WTF is up with that?
ncb is offline
post #17 of 21 Old 05-13-2013, 09:55 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
The picture thing? A great example of the new owners of this forum sucking big balls.
Also, what is a "KB byte"
Mol is offline
post #18 of 21 Old 05-13-2013, 03:34 PM Thread Starter
Apostle
Ok, so it appears to drop, i can deal with that. still got the vibe issue, it is felt all over. not just steering wheel. seat, floor, shifter
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #19 of 21 Old 05-13-2013, 04:26 PM
Mol
Mol's Avatar
Any slop in your front driveshaft?
Mol is offline
post #20 of 21 Old 05-13-2013, 04:37 PM Thread Starter
Apostle
just got done running, once i eat im headin out to fix some small stuff. ill check the shaft. They replaced the axle, but not the shaft. im thinking it may be bent a bit (maybe). worse case, i take it off and take it for a spin, see if it still happens
–Voltaire
Apostle is offline
post #21 of 21 Old 05-13-2013, 05:35 PM
Mol
Mol's Avatar
Could be a bent or imbalanced drive shaft, could be misaligned gears, or you may just need a couple new u joints. U joints are easy enough to diagnose.
Mol is offline
