Jeep back after accident: issues - JeepForum.com
post #1 of 21 Old 05-13-2013, 05:59 AM Thread Starter
Apostle
2012 JKU Sport
First, steering vibrates at 65+ They gave me 2 new tires for the repair, and put one on the front, one as a spare. so rotated tires to back and put older up front. no change
they replaced the axle and most of the steering.
Suggestions?
second issue: the steering wheel. it seems like the shaft is bent, as i rotate it, it drops at 90 deg, appears the same either direction. dont remember if this is normal, but i dont think it is. Can someone check theirs quick?
It is going back to the shop, they missed some items
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #2 of 21 Old 05-13-2013, 06:49 AM Thread Starter
Apostle
Bump for view
–Voltaire
Apostle is offline
post #3 of 21 Old 05-13-2013, 06:52 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
You're talking about the intermediate shaft? Is it actually bent, or does the angle change at the u joint?
As far as the vibration...is it just in the steering wheel or can you feel it in your seat/shifter? Could be a driveline vibe...axle shafts, drive shafts, gears?
What was hit and what was the extent of the damage?
Mol is offline
post #4 of 21 Old 05-13-2013, 06:56 AM Thread Starter
Apostle
They replaced the whole front axle. and my understanding the trac bar, drag link, tie rod.
vibration is in steering wheel, think maybe in shifter (not sure about seat).
hit a pole, front drivers side, sheered pole. pic on facebook
–Voltaire
Apostle is offline
post #5 of 21 Old 05-13-2013, 06:56 AM
JTPhoto
JTPhoto's Avatar
Anything vibes and shakes speed related are 90% tire and/or wheel. It is possible that you have one or more bent/out of round wheels. Torque converter and driveline vibes tend to be more RPM based and will appear at the same RPM no matter what speed.
I was fortunate to have no issues with my Jeep after the accident, but I also have a good relationship with the dealer. I knew what had to be fixed and they obliged. I was also fortunate to get a used front diff that was in like new condition.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #6 of 21 Old 05-13-2013, 07:06 AM Thread Starter
Apostle
What about the steering wheel? when you rotate it, does it drop down? or is it in the same position no matter which way you turn it?
–Voltaire
Apostle is offline
post #7 of 21 Old 05-13-2013, 07:09 AM
Mol
Mol's Avatar
Must have looked past it, I'll go check it out now.
Ask then to inspect the gear box, sector shaft, and pitman arm...unrelated I know, but when I was t boned, steering issues started working their way out after the repairs. Ended up with a broken sector shaft and upon further inspection, splines in the pitman arm were twisted. If your axle took a hard enough hit, something similar could have happened, especially given your concern for the condition of the intermediate shaft
Mol is offline
post #8 of 21 Old 05-13-2013, 07:10 AM
Mol
Mol's Avatar
I guess I'm not understanding the question...does what drop down?
Mol is offline
post #9 of 21 Old 05-13-2013, 07:12 AM Thread Starter
Apostle
the steering wheel. when i turn it, the steering wheel drops about 1/4-1/2 an inch, usually 90deg either way
–Voltaire
Apostle is offline
post #10 of 21 Old 05-13-2013, 07:13 AM Thread Starter
Apostle
its subtle, the only reason i noticed it was because i was looking for issues
–Voltaire
Apostle is offline
post #11 of 21 Old 05-13-2013, 07:25 AM
Mol
Mol's Avatar
Yeah that's not normal at all...
Mol is offline
post #12 of 21 Old 05-13-2013, 07:27 AM Thread Starter
Apostle
so the steering is fubar as well. theyre going to fix it, just want to make sure i find everything before i take it back
–Voltaire
Apostle is offline
post #13 of 21 Old 05-13-2013, 07:42 AM
Mol
Mol's Avatar
Can't be certain, but sounds like somethings askew between the steering box and column
Mol is offline
post #14 of 21 Old 05-13-2013, 07:48 AM Thread Starter
Apostle
but your 100% certain that yours does not drop? its like the shaft is warped
–Voltaire
Apostle is offline
post #15 of 21 Old 05-13-2013, 08:06 AM
Mol
Mol's Avatar
I'll go get in the jerp in about five minutes to verify, but yeah no steering wheel that I'm aware of moves while rotating.
Maybe a silly question, but is your tilt release fully locked?
Mol is offline
