-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Jeep back after accident: issues (http://www.jeepforum.com/forum/f96/jeep-back-after-accident-issues-1522649/)
Apostle 05-13-2013 06:59 AM
2012 JKU Sport
First, steering vibrates at 65+ They gave me 2 new tires for the repair, and put one on the front, one as a spare. so rotated tires to back and put older up front. no change
they replaced the axle and most of the steering.
Suggestions?
second issue: the steering wheel. it seems like the shaft is bent, as i rotate it, it drops at 90 deg, appears the same either direction. dont remember if this is normal, but i dont think it is. Can someone check theirs quick?
It is going back to the shop, they missed some items
Apostle 05-13-2013 07:49 AM
Bump for view
Mol 05-13-2013 07:52 AM
You're talking about the intermediate shaft? Is it actually bent, or does the angle change at the u joint?
As far as the vibration...is it just in the steering wheel or can you feel it in your seat/shifter? Could be a driveline vibe...axle shafts, drive shafts, gears?
What was hit and what was the extent of the damage?
Apostle 05-13-2013 07:56 AM
They replaced the whole front axle. and my understanding the trac bar, drag link, tie rod.
vibration is in steering wheel, think maybe in shifter (not sure about seat).
hit a pole, front drivers side, sheered pole. pic on facebook
JTPhoto 05-13-2013 07:56 AM
Anything vibes and shakes speed related are 90% tire and/or wheel. It is possible that you have one or more bent/out of round wheels. Torque converter and driveline vibes tend to be more RPM based and will appear at the same RPM no matter what speed.
I was fortunate to have no issues with my Jeep after the accident, but I also have a good relationship with the dealer. I knew what had to be fixed and they obliged. I was also fortunate to get a used front diff that was in like new condition.
Apostle 05-13-2013 08:06 AM
What about the steering wheel? when you rotate it, does it drop down? or is it in the same position no matter which way you turn it?
Mol 05-13-2013 08:09 AM
Must have looked past it, I'll go check it out now.
Ask then to inspect the gear box, sector shaft, and pitman arm...unrelated I know, but when I was t boned, steering issues started working their way out after the repairs. Ended up with a broken sector shaft and upon further inspection, splines in the pitman arm were twisted. If your axle took a hard enough hit, something similar could have happened, especially given your concern for the condition of the intermediate shaft
Mol 05-13-2013 08:10 AM
I guess I'm not understanding the question...does what drop down?
Apostle 05-13-2013 08:12 AM
the steering wheel. when i turn it, the steering wheel drops about 1/4-1/2 an inch, usually 90deg either way
Apostle 05-13-2013 08:13 AM
its subtle, the only reason i noticed it was because i was looking for issues
Mol 05-13-2013 08:25 AM
Yeah that's not normal at all...
Apostle 05-13-2013 08:27 AM
so the steering is fubar as well. theyre going to fix it, just want to make sure i find everything before i take it back
Mol 05-13-2013 08:42 AM
Can't be certain, but sounds like somethings askew between the steering box and column
Apostle 05-13-2013 08:48 AM
but your 100% certain that yours does not drop? its like the shaft is warped
Mol 05-13-2013 09:06 AM
I'll go get in the jerp in about five minutes to verify, but yeah no steering wheel that I'm aware of moves while rotating.
Maybe a silly question, but is your tilt release fully locked?
The time now is 02:16 PM.
