J/k 16 inch wheels - JeepForum.com
post #1 of 18 Old 09-13-2006, 08:27 PM Thread Starter
Stevebo
J/k 16 inch wheels
I didnt realize how much of a problem a 1 inch difference can make in finding tires. When I get my jeep i want to put bigger tires on it. If you search 15 inch theres probably 100 different tires between 30 and 35 starting as cheap as 100 bucks. For 16 inch I found One tire between the sizes of 30-35 and its 250 bucks!!!!
Stevebo is offline
post #2 of 18 Old 09-13-2006, 08:34 PM
DogsJeep
www.quadratec.com
Go to JK section tires Maxxis, look at a cooper tire dealer, toyo tires, tones of quality off brand tires usually half the price. Or go to Sam's Cub, they can order them for you.
DogsJeep is offline
post #3 of 18 Old 09-14-2006, 10:57 AM
87Feep
1987 YJ Wrangler
Look into 305/70R16's and 315/75R16's
87Feep is offline
post #4 of 18 Old 09-14-2006, 11:04 AM
wrnglrguy
wrnglrguy's Avatar
I have the 16" Moab rims, and there are quite a few options. Not sure where you're looking. The real difference is, you can't usually find them in 32x11.5 or 33x12.5, you have to go with the metric sizing. Try here for a quick conversion reference...http://www.oly4x4.com/metrictireconv.htm
wrnglrguy is offline
post #5 of 18 Old 09-14-2006, 12:24 PM
badcard
badcard's Avatar
I put 265 75 16 Bridgestone Dueller AT's on my MOAB's and they fit fine. They are about a 31.5 overall diameter and 10.5 wide. I paid about $136 each at a local SAMS Club for them.
badcard is offline
post #6 of 18 Old 09-14-2006, 08:52 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
If it not hard at all to find off-road tires for 16 and 17" wheels. You must not be looking in the right spot.
2013 FR-S
BlaineWasHere is offline
post #7 of 18 Old 09-16-2006, 09:53 AM Thread Starter
Stevebo
Hey guys what would be the biggest tire you could fit on the new wrangler without having to do a lift or without it rubbing?
Stevebo is offline
post #8 of 18 Old 09-16-2006, 11:51 AM
Sweeney
No one really knows. Everyone who has been sent in to measure has been lost in an endless pool of oil gushng from the JK.
Sweeney is offline
post #9 of 18 Old 09-16-2006, 11:55 AM
BlaineWasHere
BecauseRacecar
My guess is 33x10.5 BUT THAT IS A GUESS!!!!
2013 FR-S
post #10 of 18 Old 09-16-2006, 11:59 AM
Sweeney
I've heard 33" too, but width would depend on the wheel you use. 10.5" is probably correct with the stock off-set.
Sweeney is offline
post #11 of 18 Old 09-16-2006, 12:12 PM
daciuk55
well teraflex says with there 2.25"BB you can fit 35's, and from the look of the picture you can fit them with a decent amount of room.so i am guessing that 33's will fit stock.
heres a pic of the new lift kits for those of you who havent seen them
that picture gets me excited
1) 1993 YJ AX-15-, ford 8.8 LSD/ dana 30 4.10s,3.5" Black Diamond,5/8 " M.O.R.E Shackels,AA SYE/Tom Woods rear CV Shaft,33x10.50 BFG Mud Terrains
2)1998 XJ Sport AX-15- 1 3/4" Budget Boost- Tomken Gas tank skid-30x9.50 BFG All Terrains
3)1998 Xj sport 2 door ax-15- bone stock
4)1964 cj-5a
daciuk55 is offline
post #12 of 18 Old 09-16-2006, 02:15 PM Thread Starter
Stevebo
33's was my guess also, prolly have to wait and see though. I would LOVE to put a lift on it and put some 35-37 inchers on their, but that will have to wait. I dont want to void the warranty, rather wait the 3 years and get all the kinks outta the jeep first. Unless Im am wrong and a lift doesnt void it, but I figure it does.
Stevebo is offline
post #13 of 18 Old 09-17-2006, 09:20 AM Thread Starter
Stevebo
Putting a lift would void the warranty right?
Stevebo is offline
post #14 of 18 Old 09-17-2006, 09:25 AM
Sweeney
Aftermarket "additions" only void a warranty IF that addition directly causes the failure of the warrantied component.
It could be argued that a lift could be the cause of a steering or u-joint?cv joint failure but not an engine, stereo, etc. failure.
Sweeney is offline
post #15 of 18 Old 09-19-2006, 03:17 PM Thread Starter
Stevebo
What is the largest tire that can fit on the stock 16 inch rims?
Stevebo is offline
Will 15 inch wheels fit my new JK? tclaremont JK Wrangler Technical Forum 14 12-01-2010 03:47 PM
Rubicon 16 inch Wheels BrentwoodUPSER TJ Wrangler Technical Forum 11 10-20-2007 10:29 PM
15 or 16 inch wheels Opinions Dudewayne TJ Wrangler Technical Forum 9 01-06-2006 02:13 AM
16 Inch Wheels SpitNine TJ Wrangler Technical Forum 2 10-15-2004 01:56 PM
15 and 16 inch Wheels biffstephens TJ Wrangler Technical Forum 6 09-24-2004 02:44 PM
