07-29-2012, 03:37 AM
#1
It's a loosing battle ....
As many of you know my motor was just hydrolocked and fixed and now I blew my rear end up. O haven't even put 4k on it since I got it!!!
Has many people seen this issue with the rear ends?
07-29-2012, 06:29 AM
#2
you know what they say...."You wanna play ..youre gonna pay"...
07-29-2012, 10:06 AM
#3
Oh don't be a negative Nancy.... It's not a blown up rear end, it's an opportunity to improve it!
Blessed is he who expects nothing, for he shall not be disappointed.....
07-29-2012, 10:11 AM
#4
Not a problem. Now you can justify that locker and regear you've needed.
07-29-2012, 10:15 AM
#5
Plasti Dip yourself!
Damn. Beating that Jeep up.
07-29-2012, 12:10 PM
#6
You've got deeper pockets than I do.
07-29-2012, 12:56 PM
#7
That looks like a steering wheel gasket issue. You obviously have no idea how to manage your equipment and beat the **** out of it. Once you learn to respect your vehicle you won't breaks things much.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
07-29-2012, 01:19 PM
#8
Sarcastic Fantastic
Not to say that it can't happen to the best of us - because it can! However, you definitely aren't starting off with a good track record!
I fix automated drilling equipment for a living. Typically when we are called to fix a piece of equipment that is beaten like that we quickly conclude that the problem is "between the seat and the wheel." lol Hopefully this isn't so and you're just having some bad luck!
Summary of lessons learned:
1. Watch for high water over air box (CHECK)
2. Watch for unecessarily high RPMs while negotiating hills/obstacles (CHECK)
3. (anxiously awaiting lesson #3)
Just a question: did you discover any damage to the pumpkin housing, pinion, bearing caps, or axle shafts after you cleaned it out?
--/ 2011 Jeep Wrangler JKU - The White Coyote /--
Support our Jeep community and actively participate in our threads! Use thumbs up for good & helpful posts!
My Build: http://www.jeepforum.com/forum/f96/c...hread-1339466/
Teraflex - General Tire - Poison Spyder - AEV - Warn - Yukon - ARB - Aussie - Motive Gear - Rigid LED - Procomp - Synergy - EVO - Viair
Poison Spyder and AEV had a baby: the only JKU with a Poison Spyder bumper and an AEV Tire Carrier!
07-29-2012, 02:00 PM
#9
Dude, tell us the story! You live in a perfect place to wheel, just got the jeep, running some trails, ...
Fill in the blanks. Glad you fixed the 3.8 so cheap, this may be a little more than that.
2002 TJ Sport RED Jeep #648 30-44/3.73
Trail rider and DD
I need some red full size doors for a TJ
07-29-2012, 05:06 PM
#10
I have no idea how to manage my equipment... and beat the **** out it??
07-29-2012, 05:19 PM
#11
Or spell correctly (:
07-29-2012, 05:21 PM
#12
I keep coming back to this thread.... What did you do to grenade that diff?
07-29-2012, 05:53 PM
#13
Make mine a Jeep!
07-29-2012, 06:28 PM
#14
Abit about when it happened we we're going up a pretty steep hill that IV done before in the Jeep...
Was in 2 gear and no issues really creeping up the back then all of a sudden a huge pop and I was going back down the hill back wards. Finally got it stopped and was abel to put it in 4x4 got it turned around and back down the hill. And towed rest the way out of the trail. Everyone there said it was cause I was in 2 and not 4.
So back to the diff with this being a daily driver is it a good idea to put a locker in the rear if heard that's a big no no. If so what would you recommended for a locker. Only thing good inside is the axel shafts gears are gone, so should I regear now or am I fine to put same gears back in I'm planning to go to 33 later but no bigger.
07-29-2012, 06:33 PM
#15
jrmars07
Plenty of select-able lockers you can get that you can switch on and off making it good for both DD and trail use.
I recommend ARB air select-able lockers.
2010 2dr Wrangler
2.5" ProComp Lift, Front Adj Trackbar, JKS Disco's
Fox Shocks
Tera Front Lower Controls Arms, Rear Upper Control Arms, Synergy HD Balljoints
Tom Woods 1310 Driveshafts
33" KM2's on ProComp 7069 16x8's
Superchips Flashpaq
AEV Premium Front Bumper, IPF 900XSD Lights, Warn 9.5ti w/ Synthetic Line
D30 Front Sleeved and Gusseted, RCV's, ARB Locked
4.88 G2 Gears
D44 Rear ARB Locked, Chromoly Shafts
