Intermittent Start Issues 07 Wrangler HELP! - JeepForum.com
post #1 of 4 Old 09-14-2012, 02:22 PM Thread Starter
emorganb
My '07 Wrangler has been having start issues for over a year. Sometimes it's fine, sometimes I have to crank it a couple times and it will start right up, and twice I've had to find a different mode of transportation. At first thought it was the battery, got a new one last year... problem not solved. Decided to deal with it for a while since 9 times out of 10 I could get it to turn over... but it continued to get worse. It clicks every time and the all the electrical is fine and working. Assumed a bad coil in the starter. Just replaced the starter.... still happening. What is going on? Mechanic is assuming a "computer" problem. Anyone else experiencing this?
emorganb is offline
post #2 of 4 Old 09-14-2012, 06:27 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Bad ground circuit in starter circuit?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 4 Old 09-14-2012, 06:32 PM
jeephidelt
If you have an automatic, wiggle the shifter or shift all the way down and all the way up back into park and try it again. I've had the same problem and it is very common. Pardon my lack of technical terminology, but basically, the issue is the sensor that tells the ignition that it is in park. If the computer doesn't think it is in park, it won't start. If you get it securly into park, it will start right up.
2007 JKU X
-Tyler
jeephidelt is offline
post #4 of 4 Old 09-17-2012, 10:46 AM
Spaschal
jeephidelt is 100% correct. wiggle the shifter, will work everytime.
Spaschal is offline
2007 , issues , start , wrangler
Intermittent start and stalling issues Rickm4 TJ Wrangler Technical Forum 1 03-21-2010 11:52 AM
95 Wrangler intermittent start kingmac YJ Wrangler Technical Forum 16 03-09-2010 07:31 PM
Intermittent Start issues, No crank, Questions about Clutch Interlock pilotjay TJ Wrangler Technical Forum 4 07-21-2009 05:40 PM
99 Wrangler intermittent start when hot ajmjbrowning TJ Wrangler Technical Forum 2 11-13-2008 08:36 PM
intermittent Idle issues 05 4.0 mikekel TJ Wrangler Technical Forum 1 01-02-2007 02:44 PM
