Intermittent rough idle after mudding - JeepForum.com
post #1 of 13 Old 09-06-2013, 01:26 PM Thread Starter
takeitsleazy
When sitting at idle, I've noticed it will start to get rough for a min or two, and then resume back to normal for five or so mins. About a 200 rpm rise when this happens. I don't know if it's necessarily related to mudding, but my engine bay, under the jeep, etc has been pretty dirty lately. Things to check for? I have 1400 miles on the clock
2013 JK 2DR 3.6L, 1991 XJ 4DR 4.0L, Wife:2008 JK 4DR 3.8L
takeitsleazy is offline
post #2 of 13 Old 09-06-2013, 05:51 PM
AlbertaJeeper
Check your oil filter for dirty/muddyness. If you're worried it couldn't hurt to drop the oil out and see if it's milky. Then if it is, I believe it would be best to flush some through a couple times. I'm sure others will chip in though!
AlbertaJeeper is offline
post #3 of 13 Old 09-06-2013, 05:54 PM
Jeffro06
Jeffro06's Avatar
Is your engine bay muddy too?
Jeffro06 is offline
post #4 of 13 Old 09-07-2013, 04:30 AM Thread Starter
takeitsleazy
yes, the engine bay is quite muddy. looks like nothing but steam got to the air intake, but you never know. didnt go through anything deep at all, but it still went everywhere lol. another question: i plan on hosing my jeep off, including the engine bay, this weekend. anything i need to cover besides the air intake?
ill check my oil filter now, thanks, alberta!
post #5 of 13 Old 09-07-2013, 05:30 AM
Jeffro06
Jeffro06's Avatar
I'd open up the air box, see if the filter is wet, or if it has some mud on it, causing some restriction.
I never cover anything when I pressure wash my engine, but I don't blast the air intake either. Spraying off the engine then spraying it with Simple Green and letting that sit for about 10 minutes then pressure washing it again does wonders.
Jeffro06 is offline
post #6 of 13 Old 09-07-2013, 05:45 AM Thread Starter
takeitsleazy
awesome, my shop has tons of simple green lying around. really appreciate the info
post #7 of 13 Old 09-07-2013, 06:39 AM
Jeffro06
Jeffro06's Avatar
The engine being slightly warm seems to help a bit too.
Jeffro06 is offline
post #8 of 13 Old 09-07-2013, 10:29 AM Thread Starter
takeitsleazy
Sweet. It's not the air filter, I was told that it could be the throttle. Hopefully not
post #9 of 13 Old 09-07-2013, 08:40 PM
JohnRodriguez
your oxygen sensors have mud plugging them. they require outside air to get a proper readings and have a hole where the wires go into them.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #10 of 13 Old 09-07-2013, 09:30 PM
Neo1130
2015 JK Wrangler
Ummm, what?! O2 sensors monitor the exhaust gasses, not "outside air."
Neo1130 is offline
post #11 of 13 Old 09-07-2013, 10:04 PM
JohnRodriguez
the oxygen sensor is basically a galvanic battery. it generates a voltage signal (0-1 volt) based on the differential between the oxgen content of the exhaust gas, and the oxygen content of the ambiant air, when the sensor is hot itself. this is why they have internal heaters to get them up to temp to work properly quicker from a cold start up.
if the outside air port it plugged then it wont work properly and the idle will be the thing that is most noticable.
many years ago I was looking into installing a ford fuel injection into my 73 torino with a 351C. this was long before anybody made a drop in kit that are offered today. Back then you had to actually do some research to do things. not have a forum to go to and have a question answered by a bunch of smart ***** that don't know how a fuel injection system really works. if you take offense to this, then tuff.
post #12 of 13 Old 09-08-2013, 12:44 PM Thread Starter
takeitsleazy
Will do some research on that, find the locations and clean em. Got to my air box and checked the filter- hardly any mud on it. Cleaned the bottom out but that didnt help with the problem. O2 sensors are next to check
post #13 of 13 Old 09-08-2013, 07:44 PM
Neo1130
2015 JK Wrangler
Sorry John, my buddy was surfing my account. Don't know if he was trolling or not because he should know better... I know I do! No butt-hurt here, just need to log off my account I guess...
Neo1130 is offline
