Insulate Floor of JK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Insulate Floor of JK
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 05-06-2010, 03:07 PM   #1
DBA2GO
When driving on the highway the floorboard didn’t get too hot; but when driving off road it got very warm, so I decided to insulate the floor of my JK.
I used 4 rolls of Thermo-Tec #14620 which is 60 square feet of material to insulate the floor of my 2008 Jeep Wrangler Unlimited Rubicon. This material appears to have very good specifications when compared to similar products.
Last year I insulated the inside of the hard top. Here is that write-up:
http://www.jeepforum.com/forum/f96/d...ardtop-809376/
Take the recovery gear, seats & carpet out of Jeep. Then clean the metal from all mud & stuff.
I measured then cut the insulation into small pieces for easy installation. I used small pieces about 6” & 12”. The stuff is easy to cut w/ razor blade tool. Then peal the backing on and stick it on the metal surface.
Then use a roller to smash the insulation onto the metal. Then cut out the seat & other holes in the insulation.
Then put the carpet back in. Notice the slight ridge in middle picture; that is where the front drive shaft broke and banged against the floor of the Jeep; but that is another story.
Total cost $200.00. I got this from Auto Barn. I don’t work for, nor get any remuneration from, Auto Barn or Thermo-Tec.
I tested this 3 weeks ago in Death Valley (only 92F – so not that good of a test); but it really helped keep the heat on the feet down to a manageable level.
An added bonus is that the Jeep is now very quiet, I can even hear the stock stereo while on the highway; even over the whine of the tires.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 03:34 PM   #2
mclaggan123
jeepaholic
mclaggan123's Avatar
nice job. how long did it take you?
http://www.jeepforum.com/forum/groups/lj-owners/
2006 Rubicon unlimited, silver. 5.5" long arm lift. 35" BFG KM2's on 15" black steelies. skidrow steering skid and radiator skid . LOD rear bumper with tire carrier. Flowmaster 44 exhaust. .CB with tuffy Overhead storage . Offroad lights in bumpers front and rear plus 2 more on the winch hoop.
mclaggan123 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 03:38 PM   #3
DBA2GO
All together: tearing everything out, cleaning, installation of insulation & reinstalling everything, 20 hours.
Unread 05-06-2010, 04:16 PM   #4
plac
cool little project
2013 VW GTI
plac is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 08:19 PM   #5
1222
Make mine a Jeep!
1222's Avatar
If you remember, report back this summer when the temp is around 110 degrees. Maybe Iíll do something similar like yours.
Nice right up too.
1222 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 09:28 PM   #6
kubwa_jim
I love what you did and it looks great, but I never have any carpet in my Jeep, so it would end up looking like the inside of a space ship if I did that.
Don't look at me, your rights were violated before I ever got here!!
kubwa_jim is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 09:41 PM   #7
GEM1N1
How much did it cut down on the road noise? Humming tires?
2008 2dr Black Rubicon Automatic.
2.5" Rough Country BB
295/70/17 Nitto Trail Grapplers
Missouri Concealed Carry Permit
Kansas Concealed Carry Permit
www.KcConcealedCarry.com
GEM1N1 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 09:49 PM   #8
GPV
I think you may need to go back and cut holes over the floor drains. Just in case you need them in the future. Nice job there!
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline   Reply With Quote Quick reply to this message
Unread 05-06-2010, 11:39 PM   #9
No_Return
Very cool!
I am looking at doing not only the floor but the Inside of the Hard Top too... Last summer when it hit 117 It felt like I was riding in a Microwave oven even with the A/C on Full blast.
Love my Black Jeep but wow it gets toasty. I was even considering buying a Roof rack and painting the floor of the basket Silver. I'll Just leave it on all summer.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 07:48 AM   #10
Russrover
Clean install OP. Very nicely done.
07 X, 35 BF ATs, 3 inches of lift
RED JEEP CLUB MEMBER #586
Russrover is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 10:00 AM   #11
DBA2GO
Thanks for all of the positive comments. I know a lot of Jeep folks take the doors & roof off to go wheeling. I wheel mostly in the deserts of the southwest and I like the doors & roof on with A/C running. Last year I did the insulated the roof and that helped a lot. Now, I'm hoping this floor insulation will continue to improve my wheeling comfort.
... I thought about cutting out around the drain holes; but in the 2 years I've had this beast, I haven't needed to drain the water out.
... Between the insulation on the roof and the floor, it is surprisingly quiet in my Jeep.
... "cool" ha ha - I hope so.
Unread 05-07-2010, 10:17 AM   #12
JIMBOX
That is a really good looking job, but
I live in the desert to and I've done my entire top with Acoustic-Thermal insulation, but
The instructions were to make sure the foil side, is on the heat generating surface--so it helps reflect the heat, so mines against the inside of the top--
My JK is very comfy at 115 deg in the Nevada desert and I guess any insulation you add to the insides of these bricks---Helps !!!
good job
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 10:25 AM   #13
DBA2GO
good job
JIMBO
So, did you glue the foil side to the inside of the top?
Unread 05-07-2010, 10:26 AM   #14
fernjack
When you did your "new headliner" did you wipe down the surface with brakeclean or rough it up ........ or just cleaned it well ? Is it still completely intact after the year ? I am thinking of getting insulation in there for the -40 days LOL ! And am wondering about the longevity of the adhesive , if it stays stuck in your heat it should stay stuck in our cold ..........Thanks
fernjack is offline   Reply With Quote Quick reply to this message
Unread 05-07-2010, 10:35 AM   #15
DBA2GO
I actually had some mud and stuff on the inside of the roof. I just cleaned it really well with just soap and water. I used quite a bit of the headliner glue installing the headliner. It's still stuck.
