instrument cluster illumination lights - JeepForum.com
post #1 of 11 Old 09-13-2013, 04:14 PM Thread Starter
njseifrick
after a 6 hour trail ride I noticed that when I turned on my running lights my instrument cluster illumination lights failed to come on. All instruments seem to be in working order, just have a dark dashboard. Switch works with the interior overhead lamp. Any thoughts on what the problem might be? 2006 TJ.
njseifrick is offline
post #2 of 11 Old 09-13-2013, 06:44 PM
Vin
Did you try turninh the stalk to adjust the brightness of the cluster lights? It sounds like you have them turned down all the way.
Vin is offline
post #3 of 11 Old 09-13-2013, 09:47 PM
wilywillie
Maybe the TJ tech section would have better answers. Just saying.
I'm just here for the gasoline. --Max
wilywillie is offline
post #4 of 11 Old 09-15-2013, 12:08 PM Thread Starter
njseifrick
Thought that's where I was . . . sorry
post #5 of 11 Old 01-07-2014, 12:02 PM
MrsSmithL
I want to replace the bulbs for my instrument cluster from stock to red LED (where I can) as the stock green is blinding at night (especially for the trip) but cannot find what size bulbs I need to purchase for what areas. I read that they can vary. Anyone that can point me in the right direction? Help is greatly appreciated!!
MrsSmithL is offline
post #6 of 11 Old 01-08-2014, 09:56 AM
RogueStatus
you can adjust the brightness by turning the dial headlight knob to dim down the dash lights/radio.
Jeep-less again
RogueStatus is offline
post #7 of 11 Old 01-09-2014, 11:42 AM
MrsSmithL
I know that, I want to change out the colour as indicated in my previous reply. I need to know what size bulbs are needed.
post #8 of 11 Old 01-09-2014, 12:19 PM
DAYJ
its not just 1 bulb, its a bunch of littler leds that are soldered in to the cluster
New- 2013 Commando Green Rubicon
Old-2010 Flame Red Rubicon Unlimited
Utah Jeep Crew Member #47
Cheyenne Trail Junkie
ROADS!? Where we're going, we don't need roads... (Doc)
DAYJ is offline
post #9 of 11 Old 01-09-2014, 02:23 PM
Diode Dynamics
Jeep Lighting Experts
Diode Dynamics's Avatar
2011 JK Wrangler
If it were an older model, I would probably suggest taking the cluster out and removing the factory bulbs and replacing them. Aside from soldered in, indivdual LEDs...the most common replacement sizes are 194-based bulbs and 74-sized bulbs.
You may want to check your fuses also
Nick C.
Your Source For Jeep Lighting
We provide the highest quality products around! check us out! >
Diode Dynamics is offline
post #10 of 11 Old 01-09-2014, 02:59 PM
MrsSmithL
Thank you Nick, that was helpful!
post #11 of 11 Old 01-09-2014, 03:18 PM
Diode Dynamics
2011 JK Wrangler
I do my best
Nick C.
