Installing side rockers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Installing side rockers
Bds fox ipf 2.0 racing series shocks now available at rockRubicon express discounts from oconee off-roadRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 08-28-2014, 05:23 PM   #1
bsteeves86
2009 JK Wrangler
I am installing side rockers that attach to the frame via the 4 bolts.
Unfortunately all the bolts were seized and rusted. I tried everything but in the end even with patience the bolts broke.
What's my best approach to get then out now? Arghhh
bsteeves86 is offline   Reply With Quote
Unread 08-28-2014, 07:23 PM   #2
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Go to the auto parts store. There are special drill bits that have the pattern reversed. You drill those into the bolt, and then put the drill in reverse, thereby making the bolts come out. There may be other ideas out there that work better, though.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel lift, Fox 2.0 shocks, 37" Nittos, 5.38's, River Raider skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Re-inventing the circle and straight line.
HappyTrails is online now   Reply With Quote
Unread 08-28-2014, 11:24 PM   #3
mtnbiker995
Livin the dream
mtnbiker995's Avatar
2009 JK Wrangler
Weld a nut onto the shank of the broken bolt
My rebuild
mtnbiker995 is offline   Reply With Quote
Unread 08-29-2014, 03:46 AM   #4
bsteeves86
2009 JK Wrangler
Unfortunately it broke off almost flush with the frame.
Unread 08-29-2014, 05:41 AM   #5
bogleparsons
Thats OK as long as it's flush or very close. put the nut up against the hole and fill it in, it's worth a shot.
Otherwise I would try drilling it out with a left handed (reverse) bit as mentioned above. If all else fails drill the hole out and weld in a nut or use a nutsert.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is online now   Reply With Quote
Unread 08-29-2014, 03:06 PM   #6
222Doc
they make a nutcert that large? i ,i was looking at a selection on line the largest i found was 3/8. Those body bolts are much larger. welded nut is your best bet as it heats it too. the heat alone will do a lot.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is online now   Reply With Quote
