Installing rocker switch.... - Page 3 - JeepForum.com
post #31 of 38 Old 01-18-2010, 05:54 AM
bigdaddyh
2009 JK Wrangler
Open either the driver or passenger side door and take off the end panel. There is a hole there with insulation that you can poke through with a coat hanger to get wire under the hood.
2009 Wrangler Unlimited X 4 dr auto 4X4 w/ black accent package; Spidertrax 1.5 spacers; Midland 75-822 handheld with 3rd brake light antenna mount -Uconnect enabled (Ipod control is sweet)
bigdaddyh is offline
post #32 of 38 Old 01-21-2010, 09:05 AM
riptide
I just ordered these from polycase.com. While it won't fit the conture rocker switches I was initially going to use, I believe this will work quite nicely. I plan on making/getting some L or V shape strips of metal to secure the case to the section above the mirror. With one of these I figure I can get between 6-9 switches up there.
Length (A) 7.620
Width (B) 4.620
Height (C) 2.255
Length (A) 8.740
Width (B) 5.750
Height (C) 2.170
riptide is offline
post #33 of 38 Old 07-27-2010, 03:49 PM
SemperFIsh
2010 JK Wrangler
Nice BigDaddyh,
Its so amazing that ideas are shared on the internet, I had this idea after shopping at Advanced Auto and was going to mount it in the same place and everything, then I got on here to check out other ideas. I like the daystar up on top of the mirror too.
SemperFIsh Tampa FL
2010 Jeep Wrangler white 2 dr, blk soft top,
SemperFIsh is offline
post #34 of 38 Old 07-27-2010, 04:00 PM
fernjack
Originally Posted by ge2 View Post
I can attest to that also. I ran the Daystar panel for about a year and it just doesn't work with a manual. You can push the boot down and hold it in place with a ziptie, but you shouldn't have to do that.
I removed the daystar panel and moved my 4 switches to the middle of the center stack, where the power window switches would be (I don't have power windows). I used a dremel for this.
Then I have 6 switches up top, using an sPOD (which is probably one of the single best mods I've seen in 18+ years of modifying vehicles).
That's a great spot if you don't have power windows ........
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #35 of 38 Old 11-21-2010, 12:17 PM
4xar
2011 JK Wrangler
extremely well done
4xar is offline
post #36 of 38 Old 11-21-2010, 12:41 PM
4xar
2011 JK Wrangler
good install...1.How does the mount attach? 2. How did you route the wires? Thx
4xar is offline
post #37 of 38 Old 11-21-2010, 02:40 PM
labgeek
2010 JK Wrangler
I'm looking forward to this becoming available:
Past: 2010 JK Unl. Islander, ORH Whisper Top (for now)
70-something DJ-5 RHD (years ago - never got over the thief who tried to steal it burning it)
labgeek is offline
post #38 of 38 Old 11-21-2010, 06:36 PM
wmphoto
2009 JK Wrangler
Originally Posted by bigdaddyh View Post
I got the idea from a guy on the other forum. Thought I'd post here to help someone out.
I took the console panel apart and removed the hazard light/ESP switch panel out (I have an X so plenty of spare switch openings).
This is a great place for switches but these switches are tight fitting in here. I even had to cut the end of the tabs because it was too deep and hitting the circuit board. I found this switch at Autozone.
WOW... You sold me... Thats awsome...
wmphoto is offline
install , JK Wrangler , switch , switch location , wrangler
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
Installing TNT Rocker Guards wrangler2007 TJ Wrangler Technical Forum 15 02-18-2009 05:17 AM
Installing SFW Rocker Panels jinx44 TJ Wrangler Technical Forum 2 01-20-2009 11:33 AM
Installing Rocker Guards zener6 TJ Wrangler Technical Forum 6 09-26-2008 10:22 PM
Installing ignition rocker switch wesley75 YJ Wrangler Technical Forum 10 08-17-2008 09:23 PM
