Installing rocker switch.... - JeepForum.com
post #1 of 38 Old 01-13-2010, 03:15 PM Thread Starter
hmartinez
2009 JK Wrangler
Installing KC slimlights and was wondering the best way to
cut a hole in the panal. Small bit to start but what do u
guys usually use to install rocker switch?
hmartinez is offline
post #2 of 38 Old 01-13-2010, 03:27 PM
Xtremjeepn
Mine. Daystar switch panel.
Cole Ford
Xtremjeepn is offline
post #3 of 38 Old 01-13-2010, 03:29 PM
rwmjeepjk
usually a drill bit, but depends on the type of rocker switch too. if square, you can use a drill to get a hole big enough and then a utility knife or body saw to square it off.
Also, I tried the Daystar switch panel like above, but with a manual, third gear turned the switches on.
'07 Unlimited X - RED - winch, mod front bumper, 2.5" lift, 35" BFG KM2's, skid row skid plate, BackUp Camera, Custom Switch Pod, CB / PA, Congo Cage customized to full rack with light bar and rear ladder, more to come! (roof tent is not too far off, getting ready for next Easter Jeep Safari trip)
rwmjeepjk is offline
post #4 of 38 Old 01-13-2010, 03:37 PM
beamme84
2009 JK Wrangler
i use a dremel.
beamme84 is offline
post #5 of 38 Old 01-13-2010, 03:52 PM
2jk1cjtj
lites
say how did you get the panel off to get the leds installed in the panel that looks good
2jk1cjtj is offline
post #6 of 38 Old 01-13-2010, 04:17 PM
Xtremjeepn
The top panel (above the radio) and the bottom panel (where the daystar switch panels is now) just snap out. Lift one corner of each and pull, they will just snap off.
That will expose the screws to get the rest of the panel off to install LED lights.
Cole Ford
post #7 of 38 Old 01-13-2010, 04:17 PM
riptide
Really!? ****... I was going to get that... sigh...
riptide is offline
post #8 of 38 Old 01-13-2010, 04:37 PM
ge2
Gold Member
ge2's Avatar
I can attest to that also. I ran the Daystar panel for about a year and it just doesn't work with a manual. You can push the boot down and hold it in place with a ziptie, but you shouldn't have to do that.
I removed the daystar panel and moved my 4 switches to the middle of the center stack, where the power window switches would be (I don't have power windows). I used a dremel for this.
Then I have 6 switches up top, using an sPOD (which is probably one of the single best mods I've seen in 18+ years of modifying vehicles).
ge2 is offline
post #9 of 38 Old 01-13-2010, 05:01 PM
riptide
Yeah... I was going to put a kill switch there (controling the switchs on the DS panel), then have the daystar panel down below...
How far down would one have to push the boot down for it to clear the switches down there? Would it look retarded if done?
riptide is offline
post #10 of 38 Old 01-13-2010, 05:07 PM
ge2
Gold Member
ge2's Avatar
Here are a few shots I took back when I had the panel in.
ge2 is offline
post #11 of 38 Old 01-13-2010, 05:28 PM
1222
RIP John
1222's Avatar
If you need a round hole, use a step-drill. It wonít grab and the hole will come out perfectly every time. If you donít have one, you can get a set of three at harbor freight for practically nothing.
If you use it correctly it will also chamfer the hole too.
(2011-2016)
1222 is offline
post #12 of 38 Old 01-13-2010, 06:33 PM Thread Starter
hmartinez
2009 JK Wrangler
one more question, there was a blue thing with the switch, it says 3M 804, 14-18 AWG.....do i need this if so where does it go?
post #13 of 38 Old 01-13-2010, 07:01 PM
riptide
Hmm I'm still tempted to get it anyway, without pushing down the boot. With a kill switch up by where the power windows go (I don't have power windows), it shouldn't matter if third gear turns them on or off (other than wear on the switches), as these will be lights (a couple different sets) and will all be controlled by the kill switch. As long as that's off nothings gonna turn on anyway...
riptide is offline
post #14 of 38 Old 01-13-2010, 09:33 PM Thread Starter
hmartinez
2009 JK Wrangler
Thanks guys for all your help...finished the install of the lights. Dremel was a great idea! work good.
post #15 of 38 Old 01-13-2010, 10:51 PM
ge2
Gold Member
ge2's Avatar
Kill switch won't matter. The boot turns the daystar switches to the OFF position, not ON. So if the kill switch is not engaged, and you want your lights on..... the boot will keep turning them off.
(Unless I'm misunderstanding)
ge2 is offline
install , JK Wrangler , switch , switch location , wrangler
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 10:21 PM
Installing TNT Rocker Guards wrangler2007 TJ Wrangler Technical Forum 15 02-18-2009 06:17 AM
Installing SFW Rocker Panels jinx44 TJ Wrangler Technical Forum 2 01-20-2009 12:33 PM
Installing Rocker Guards zener6 TJ Wrangler Technical Forum 6 09-26-2008 11:22 PM
Installing ignition rocker switch wesley75 YJ Wrangler Technical Forum 10 08-17-2008 10:23 PM
