Installing Recon front turn signals? - JeepForum.com
post #1 of 2 Old 01-02-2013, 02:03 PM Thread Starter
NWJeepster
2011 JK Wrangler
So I got a pair of Recon smoked front turn signals to put on my 2011JK. Got the old ones out and put the new ones in only to then see the lights are not the same connector as the ones on the Jeep. Am I missing something? Please help. The Recons have glue around the hole on the back that if that were to come off, it would probably break the light and because it is glued, I am assuming the lightbulb is already included.
NWJeepster is offline
post #2 of 2 Old 01-02-2013, 02:07 PM
donny90yj
You have to pull the old connector out, take out the bulb and use that on the recon's. Also the blinker only mounts one way in the grill, so if it don't work just flip the connector. My P/S was backwards causing it to fit tight but works. Just makes mounting the resistor a little harder because of lack of slack in the wire.
donny90yj is offline
