Installed my Maximus-3 Winch Plate and Hoop Today - JeepForum.com
post #1 of 15 Old 11-24-2013, 08:17 PM Thread Starter
gwar11d2
2009 JK Wrangler
Wanted to write up a quick picture/ install thread I did today with my buddy. I wanted something simple and a low cost alternative to buying a full bumper for lights and a winch. This isn't your grandma's hoop either, it is very strong and very well built.
Here we go...start buy mounting the hoop to the winch plate which attaches to the frame brackets sandwiching the winch plate between the two. Here is a closeup:
Another view:
Here it is all pre-assembled which can be done in the warmth of your living room
Here are the 'front of bumper brackets which attach between the plastic bumper and your factory tow hooks':
Remove the plastic air dam and upper plastic plate that goes between the frame rails.
Then you take off your bumper with an 18mm socket...and wear some gloves if it is cold:
Then you take the fog light wiring harness and take everything off. You then place the brackets that look like the tow hooks and put them between the plastic and the metal bumper.
Then you set the bumper assembly on top without the bumper and put frame bolts in loosely (need to still need to move the assembly around a bit while putting to bumper on:
Then you move the bumper into place:
Then you bolt the plate to the front bracket (this is where you need a 7/16 allen wrench cut short on one end) We ended up using bolt cutters on the allen wrench and then using a bench grinder to clean it up.... basically it needs to be short enough to go under the tow hook.
Then you tighted bumper bolts up, and make sure everything is all lined up and TIGHT:
Once everything is all done, you take your Jeeps out to an empty parking lot and snap pictures! Paul's Jeep he just went with the light mounts and hoop...I went with light mounts, hoop and winch plate with fairlead bracket. Both installs are similar.
Maximus-3 is a awesome company. Everything is very strong and looks very OEM matching up with the factory bumper perfectly. Now I get to start shopping for winches and lights!!!
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #2 of 15 Old 11-25-2013, 05:21 AM
Argent33
2014 JK Wrangler
Beavis - your images don't work
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #3 of 15 Old 11-25-2013, 07:02 AM Thread Starter
gwar11d2
2009 JK Wrangler
Images fixed! Woops. Google...
Thanks to my buddy Paul who took these! (He's the Hydro-Blue 2014 JK that has the other Maximus hoop)
My Build Thread:
gwar11d2 is offline
post #4 of 15 Old 11-25-2013, 07:36 AM
RogueStatus
that looks reall good, and a nice alternative to those who dont want a full bumper. I'm gonna look into it, i want a solid light/winch mount but dont want to ditch my factory bumper.
Jeep-less again
RogueStatus is offline
post #5 of 15 Old 11-25-2013, 07:50 AM
bogleparsons
pretty sexy man, good job
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #6 of 15 Old 11-25-2013, 07:58 AM
Argent33
2014 JK Wrangler
Ah yes there you go all better (my bad!)
~Paul
Argent33 is offline
post #7 of 15 Old 11-25-2013, 08:04 AM Thread Starter
gwar11d2
2009 JK Wrangler
Also, the pictures don't do it much justice...it looks WAY beefier in person
My Build Thread:
gwar11d2 is offline
post #8 of 15 Old 11-25-2013, 10:25 AM
1222
RIP John
1222's Avatar
Nice, I like the fact that it looks somewhat factory looking.
1222 is offline
post #9 of 15 Old 11-25-2013, 10:51 AM
Argent33
2014 JK Wrangler
yes they did an excellent job of matching the color and texture of the stock bumper to make it look very OE
~Paul
Argent33 is offline
post #10 of 15 Old 12-17-2013, 06:24 PM Thread Starter
gwar11d2
2009 JK Wrangler
Added some Hella's... Winch to follow:
My Build Thread:
gwar11d2 is offline
post #11 of 15 Old 12-22-2013, 08:04 AM
jeepwrnglr92
2015 JK Wrangler
i like this keep the factory bumper and still get a winch plate and light mounts.
looks nice.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #12 of 15 Old 04-15-2014, 08:43 PM
lonsjeep
Did you keep the stock filler between the bumper and grill with the winch plate install?
Thanks
Lon Briscoe
lonsjeep is offline
post #13 of 15 Old 04-16-2014, 07:52 AM
Godholio
That looks great...it's cool to see some alternatives for people who like the plastic bumper.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #14 of 15 Old 04-16-2014, 01:14 PM Thread Starter
gwar11d2
2009 JK Wrangler
Originally Posted by lonsjeep
Did you keep the stock filler between the bumper and grill with the winch plate install? Thanks Lon Briscoe
No I did not. No gap really with the winch plate. Just the light mount version there is a small gap on my buddies 2014 but he used the plastic filler piece.
It is not needed though.
My Build Thread:
gwar11d2 is offline
post #15 of 15 Old 04-17-2014, 05:13 PM
lonsjeep
I have the hoop but have decided to add winch plate and a warn 8000s.
Thanks.
lonsjeep is offline
bumper , light brackets , winch plate
