Installed cb today - JeepForum.com
post #1 of 20 Old 08-26-2013, 03:41 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Installed cb today
Installed the CB today. Tomorrow I'll go to an open area and hook an swr meter up. Happy with the mount. Check it out!
Compact cb in console
Side mount antenna on rear
FIRECAPT is offline
post #2 of 20 Old 08-26-2013, 03:50 PM
Jeepit85
I used the same mount on my TJ. They look real nice.
85 CJ7, Howell TBI, Twin Stick, 4:10's, 35" Pitbull Rockers, Clifford 6=8, Detroits, Matkins Level II, BDS 4", Summers Brothers. Skynyrd rocks.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #3 of 20 Old 08-26-2013, 05:46 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Also mounted a small wedge snapped external speaker. I used a long Velcro strap that I attached to the speaker with a couple of small screws. I then wrapped the strap around the roll bar area
FIRECAPT is offline
post #4 of 20 Old 08-27-2013, 12:48 PM
Phool
Nice. Where did you run the wires?
Phool is offline
post #5 of 20 Old 08-27-2013, 04:51 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Down the B post, under the carpet, under lower edge of console. I had a small hole drilled in the bottom of console. Lining that up took a few trys
FIRECAPT is offline
post #6 of 20 Old 08-27-2013, 11:55 PM
djm
I like the antenna mount - please tell me a little about it ? What model / Where did you get it ? Difficult to install ?
Thanks
Dan
djm is offline
post #7 of 20 Old 08-28-2013, 04:12 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Well swr was horrible. Went to a large empty parking lot. Hooked up meter and went through channel 1 and 40. 1 was at 4.2, 40 was at 5+. I came home got on the Firestik web page (mount is a Firestik side mount, antenna a 3ft Firestik) they have a swr troubleshooting section. Most all of the suggestions dealt with checking continuity and good grounds. Everything checked perfect. I called Firestik for suggestions. They were very helpful. After verifying my ground and continuity checks, he asked about antenna location on my Jeep and how much antenna was above roof line. He felt the problem was likely due to it being mounted on rear and only six inches of antenna above roof. He said the fiberglass top would not be a huge problem, but the jeep has vertical and horizontal roll bars and they are in such a proximity to cause swr problems. His suggestion was a 4 foot antenna. This would put more antenna above roof and roll bars. Anyone else with a similar set up have this issue.
FIRECAPT is offline
post #8 of 20 Old 08-28-2013, 04:23 PM
duneslider
Was this ant adjustable? Adjustable tip?
You should be able to get better then that in the location you are mounting it. Still makes me think there is a grounding issue. Is the mount/ant assembled correctly? Do you by chance have another ant you could try, maybe a magnet mount?
I haven't even mounted my cb since getting my ham lic. I should go dig it out and see what is missing, it was in my YJ when my brother totalled it. My dad went to the junk yard and pulled what he could before the insurance took it.
duneslider is offline
post #9 of 20 Old 08-28-2013, 04:42 PM
LoneWolf
LoneWolf's Avatar
2009 JK Wrangler
Borrow a friend's SWR meter to get a 'second opinion'. My meter shows a consistently high reading across all channels -- approaching 6! -- but my ground and continuity are fine. Since I get similar readings with different antennas, I'm thinking my meter is bad. (From what I've read, it's fairly common.)
'09 JKX:
33" Duratracs│TF leveling kit│CC bumpers
LoneWolf is offline
post #10 of 20 Old 08-28-2013, 04:50 PM Thread Starter
FIRECAPT
2010 JK Wrangler
That's an option. Just gotta find someone with one.
FIRECAPT is offline
post #11 of 20 Old 08-29-2013, 05:58 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Well my original antenna was not one of the Firestiks with a tunable tip. After speaking with a tech at Firestik he felt that the 3 ft antenna I was running would have worked if it had a tunable tip. He felt based on his experience that being on a Jeep, the best I could hope for would be in the swr 2 range and distance would still be an issue, but would be fine for trail purpose, if it were a tunable tip. I ordered a 4 ft firefly(very light weight) with a tunable tip. I also ordered a heavy duty 3inch spring. Well now instead of 6 inches above the roof, I have 21. The SWR, using the tunable tip, tuned to 1.5, channel 1 thru 40. I believe for those not looking this much antenna above the roof, a 3ft firefly w/tunable tip and a 3 inch spring would be perfect. The techs at firefly were awesome , helpful and patient. Hats off the good customer service. As mention in an earlier post, I did not have to grind paint off to bear metal behind the support plate of the mount.
FIRECAPT is offline
post #12 of 20 Old 08-29-2013, 07:01 PM
AEVBrute
I did a cross country trip and the cb was the most important aid next to the nav. I played around with the firestiks for a while until I ran in to a 3 foot adjustable tip k40. It was night and day compared to any of the firestiks. I run a firestick on my pick up but the Wrangler loves the k40.
When I take my hard top off the meter readings change so keep that in mind.
Here is a link:
http://www.k40antennas.com/products/...itswhips-tips/
pretty sure this is the one I ended up getting as I didn't want it much higher than the vehicle
http://www.k40antennas.com/products/...0-watts-black/
AEVBrute is offline
post #13 of 20 Old 08-29-2013, 07:18 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Here is a link:
Thanks for the tip. I'll keep the K40 in mind
FIRECAPT is offline
post #14 of 20 Old 08-29-2013, 09:28 PM
duneslider
I really think a tunable tip is mandatory to get it tuned right.
Back in the day my fiberglass ant I had to just cut a little off at a time until it got to where it needed to be and then it was done. If you went too far, oh well.
Glad you got it figured out.
post #15 of 20 Old 08-29-2013, 11:44 PM
Godholio
There was a recent discussion about this in a local forum, and it matches what you got from talking with the Firestik folks.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
