Installed 1" front spacers now jeep is higher on one side! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Installed 1" front spacers now jeep is higher on one side!
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 02-15-2015, 04:58 PM   #1
krazymatt
So I installed front teraflex front spacers to help out with leveling out my 2014 Jku Rubicon after installing a front bumper and winch. I did everything right as far as I know. Made sure the spring seated accordingly. Could I have maybe put one spring upside down?? Thanks
krazymatt is offline   Reply With Quote Quick reply to this message
Unread 02-15-2015, 05:02 PM   #2
ncb
The shape of the springs won't allow one to be upside down. Did you loosen the control arm hardware and torque to spec with the Jeep on level ground?
ncb is online now   Reply With Quote Quick reply to this message
Unread 02-15-2015, 05:29 PM   #3
krazymatt
Didn't find a need to mess with control arm hardware. I just removed and replace it again on the low side and same thing. Can't figure it out! It's like the passenger spring is like extra compressed.
Unread 02-15-2015, 05:34 PM   #4
SLADE
Recheck everything to make sure the spacers and coil are seated correctly.
Where are you taking the measurement?
Best place to check is at the coil spring. Measure from the flat part of the coil perch to the lip of the coil bucket on both sides and compare.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 02-15-2015, 05:40 PM   #5
ncb
If the spacers/isolators/springs are seated and correctly indexed I was thinking maybe the control arm bushings might be in a bind from the ride height change.
Unread 02-15-2015, 05:50 PM   #6
krazymatt
I'm at a loss. I guess I'll take them off! I can't believe that a 1" spacer could prove so problematic! I've triple checked and can't figure it out! I'm on a level concrete slab and the jeep is visually leaning. I even went for a ride to assure it needed any settling. Tryed putting it in 4wd and disconnected the sway bar automatically and 're engaged.
Unread 02-15-2015, 05:53 PM   #7
SLADE
Good idea!
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 02-15-2015, 05:55 PM   #8
SLADE
What are the coil spring part numbers on front and rear (driver vs pass. Side).
How much lean do you actually have (measured at the coil)?
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 02-15-2015, 06:24 PM   #9
krazymatt
Both front springs show a 5212 as the four digit number on the tag. I've been wrenching since I was a kid and I'm 42 and this is the weirdest thing I've ever seen. The only thing I can think of is I have a bad spring or something is weird with that autosway bar discount.
Unread 02-15-2015, 06:42 PM   #10
SLADE
What are the last 2 numbers on the coil tag (there are more than 4 for example 52126314AC that would be a "14")?
How much measured lean do you have at the coils?
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 02-15-2015, 07:18 PM   #11
krazymatt
6318ac and at the coils I was looking at about 3/4" difference. At around 10" from the tower lip to the axle spring perch
Unread 02-15-2015, 07:31 PM   #12
krazymatt
So back to stock and in the end the right still sits lower than the left by about 1/2". So I've likely always had a weak spring. Unless the weight of the fuel tank has something to do with it?
Unread 02-15-2015, 07:39 PM   #13
SLADE
JK lean is common. Its not uncommon to have different coils left to right from the factory.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 02-15-2015, 07:51 PM   #14
krazymatt
Hmmm. Makes perfect sense since 18 or so gallons of fuel resides on that passenger side. So do coil lifts compensate for the Jk lean?
Unread 02-15-2015, 09:28 PM   #15
1222
Make mine a Jeep!
1222's Avatar
Originally Posted by SLADE View Post
JK lean is common...
Got here late in the thread but this is what I’m guessing too. If you would have looked at your Jeep head on before the spacer install you most likely would have seen the “factory lean” was already there. Lifting the front end up just makes it more visible. In time you’ll learn to live with it.
1222 is offline   Reply With Quote Quick reply to this message
