Installation KC Slims on Windshield help
| 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
Hello everyone, well I finally purchased some driving lights for my windshield area. It seems like an easy install, but I'm trying to find a good access hole from the cab into the engine compartment to install my switch. One of the threads here showed a hole on the right side of the dash (need to remove panel first) which has foam in it. I'm just having a difficult time routing the wires through....any suggestions...thank you
#2 |
http://www.quadratec.com/products/12500_231.htm
http://www.cooltechllc.com/jeep/jk_switch_mount.htm both of these seem like good options. I like cooltech's switches better but i like quadretecs prices more. hope this helps! |
#3 |
I think the OP was asking where to route the wires from the lights through the firewall and to the switches. I use the hole to the right of where the steering column comes out from the cab. I wish I had a pic for you but I'm at work.
Facing the front of the Jeep, under the hood look to the right of the steering column for a circular black grommit. I had to trim the hole in the grommit a bit to get my wires through, but its worked great for both of my light applications because I have my switches mounted on the front of the dash right next to the left of the steering column. You'll prolly find a hole before I can get you pics, but if you need them I can send you some around 6.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way. 2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(My Build Details) |
#4 |
On the drivers side if you take out the pannel right on the dash by the drivers side door you will see some foam. what I did is from under the hood I used a metal coat hanger and bent it straight and taped one end of the switch wire on the coat hanger and pushed it right through the foam. And just repeat on all your wires.
2008 Rescue Green 4 door. Rusty's 3.25 coils. Rough Country 2.2 shocks. JKS adjustable track bars. Teraflex lower adjustable control arms. BFG 315/70/17all terrians. Teraflex stablizer. KC slim lites. Rugged Ridge wheels. |
#5 |
Switch, same place as above post.
Wires through the rubber grommet behind the master cylinder. ![]()
07 Black Sahara Unlimited 2.5" Skyjacker suspension lift, RE quick discos, 3/4" front spacers, 16x8 soft 8's, BFG 33x12.50's MT's, Shrockworks rock rails. Bulldog rock crawler winch bumper, Warn M8000 and lot's of armor! (Mine) 08 Redrock X Unlimited (Hers) ____________________________________________ Driving a Jeep to work makes it feel like you're going camping! http://www.novajeepers.com Last edited by BirdsFanVa; 02-06-2009 at 03:24 PM.. |
#6 |
my bad.....
#7 | |
#8 | |
Do you think it would be easier if I removed the hood cowl? It seems like it would, but I don't know if i want to remove the wipers..... |
#9 |
I mounted my rocker switch in between the air vents (where the power window switches are on some models).
It looks professional like it should be there. As far as routing the wiring, i didn't even need to go through the firewall, you can tuck the wire along side the other cables on the driver's side, there is a hole in the A-Frame, so no drilling is needed. It's then super easy to tuck the wire along the windshield over to the center of the dash. I can provide pics if you contact me.
DANJEEP08 |
#10 | |
PICS Please
#11 |
I did not remove the hood cowl. But it probably would be easier. I just loosened it up to hide my wires in there.
#12 | |
Hope this helps, |
#13 |
pictures of kc lites install
Here's some shots from my install last year:
http://community.webshots.com/album/569983462PDWRPY
DANJEEP08 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
