#1 | |
Installation Advice; RC 2.5" lift
Ok First, I'm gonna eat some crow on this one so I'll kick myself before anyone else gets a decent chance to do so. Yes, I said I never wanted to lift my rig. Yes, I have even argued why NOT to lift a rig. Yes, I've been a bit judgemental of lifts in the past. For all of these things, and to all who've lifted their JK (rubicon or otherwise)...I am sorry.
That said, I have decided that I need a lift to get the wheels I want on my '08 2dr Rubi. **** Cepek DC1 in black. After reading a whole slew of threads I've settled on the Rough Country 2.5" progressive coil spring lift with the 2.2 shocks. Thank you N2Rock, as you're comments on this lift kit have been most instrumental in my decision. Now, the questions. Please answer as if you were telling your 4 year old daughter. 1. What tools do I have to have to install the lift? 2. With this lift, are there any other adjustments I should do that aren't included in this kit? (i remember something about a brake line relocation brkt) 3. I'm only looking to get 33" tires under my Rubi, is everything else on the rig up to par to run 33s? (all my research says so, but I want your opinions) 4. How long would it take 2 people to do the lift? 5. Does anyone think I don't need this lift to get DC1 wheels on my rig and if so, why not? 6. Should I tackle this myself or have it installed professionally? (i'm reasonably mechanically inclined with a decent tool outfit) 6A. What should I expect to pay for installation in the central PA area? 6B. Anyone have suggestions on installation shops in central PA? 7. Will this lift interfere with the electronic Disco or anything else on the '08 Rubi 8. Oh, AND, if you have this lift, could you either PM me or post the instructions for installation. I can't find anything anywhere on the step-by-step on this lift. That's long enough, i'm sure the answers will pose more questions. Thanks guys for the assist. ![]()
"The World was large, now it is small. It was lonely, now it is crowded. It was dark, now the lights are on. Some day the old will be new again. Keep your guns close but your sword closer. For one day Man will again fear the dark of the World." --The Zombie Prophet Last edited by FC2TurboMSS; 01-05-2009 at 05:14 PM.. Reason: add stuff |
#2 |
Since this is a spring lift the process will be similar to a BB lift. Here's what you will need:
18mm socket and wrench to remove swaybar links and also lower shock mount. 16mm & 19mm wrench to remove top shock mount. 10mm to remove brake line mount. Jack & stands Whole job can be done in less than three hours with one person. I'd suggest someone to help insert the new springs. You may need spring compressors but someone else would have to answer that. I didn't relocate the brake lines with my 2.5 BB but am probably going to put on longer lines since they take strain at full flex. I'm also going to add an adjustable trackbar to mine soon but not essential with a 2.5 lift. Make sure to get the alignment done afterwards to get the toe-in back in spec. This seems to be a cause for the DW that sometimes occurs.
2007 Sahara Unlimited 4x4, Auto, Jeep Green, Tow Package, Soft top With guns, we are citizens, without them we are subjects! |
#3 |
Not sure why you need an adjustable trackbar. What effect does the lift have on the trackbar and will adding an adjustable one prevent some early wear on components? I don't have any experience with suspensions, so I'm not sure what all the components are. Also, you mentioned getting the alignment done post lift. To anyone's knowledge, will I have any warranty issues putting on a 2.5" lift.
"The World was large, now it is small. It was lonely, now it is crowded. It was dark, now the lights are on. Some day the old will be new again. Keep your guns close but your sword closer. For one day Man will again fear the dark of the World." --The Zombie Prophet |
#4 |
Glad to see you are seeing the light, and putting some lift on the jeep ! 33s are a great size tire to start out with!
You dont need to worry about the trackbar, you will be fine. I am thinking of adding the currie control arms and trackbar with double johnny joints in order to get better slinky effect when off road. other than that, those parts arent really needed with the 2 1/2 in kit. I have the 4 door rubi, and put this kit on it, with the stock tires and wheels. (Im too cheap to pay for more when these are good for now) I just needed to get the low belly off the ground. No problems with the sway bar, or the ESP. the warranty stuff is purely up to the individual dealers, and most are leaving the 2 1/2 the limit, in reality you only void the warranty on the parts you change. as far as that goes, you should be just fine with the progressive coils! the instructions are really straight forward with good pictures, grab a beer, a friend and well just take your time. Good Luck.
09 JK 4 Door Rubicon, Jeep Green 35" Goodyear Duratrac, 3.5" Rock Krawler springs and control arms , RC 2.2 Shocks. TNT customs front stubby bumper with Warn 9000 lb winch If I Wanted A Hummer I Would Have Asked Your Mom For One |
#5 | |
When the suspension flexes, the track bar rotates on a perfect radius at the pivot point on the frame. As the passenger side wheel lowers the bar is not able to reach out further, so the lower it goes, the track bar essentially pulls the axle to the left side of the rig. The same principle applies in a lift. When you lift a Jeep, you're lowering the axle from the frame and the fixed arm of a trck bar prevents both sides from lowering straight down from the frame. An adjustable track bar offers a longer extension that will "push" the axle back to the right side of the Jeep and keep it centered. The lower it goes (or more lift you use) you'll need to adjust the track bar to have more reach. The more the lift, the more need there is to correct this problem. Its not a big deal on 2" lifts because the amount of shift is minimal. Consider that the back side has a track bar too that goes the other dirrection, so as you lift the axles are moving left to right in an opposite direction and a lift of much more than 2" can create a significant shift in axle alignment. Not sure if that's the response you're looking for, but hope that helps you understand. |
#6 | |
#7 |
Also, are there any indicators that I need to adjust/buy an adjustable track bar? Weird handling, tire wear etc.?
#8 |
I have a lot of trouble with the death wobble after my lift. Removing the lift eliminated the DW for the most part. I'm putting on the adjustable track bar to see it resolves the problem. Can't say I've seen any abnormal tire wear or anything else.
#9 |
Sway Bar disco's are good, especially when you need to full flex.
#10 |
I've got electronic ones stock on the rig, I'm wondering if the 2.5" lift will interfere with it.
#11 | |
I'm not sure what was being implied, but the sway bar has nothing to do with the track bar's duties. The sway bar keeps the Jeep stable through a spring-like connection to each end of the axle through the frame - it minimizes sway and that's about it. When disconnected you get more flex beecuase it lets one end of the axle move without any counterforce from the other side. It has nothing to do with alignment or axle positioning. I'm not suggesting that anyone do this, but I have an 08 Sahara with 35K miles. I've had my SB disconnected for nearly 20,000 miles now. The Jeep isn't a vette, so handling isn't a huge deal for me. You've got to flog it pretty hard for there to be a safety compromise. Besides, its actually fun driving w/o it connected. I wheel my rig a lot for both fun and work, so its never been a big deal. I contemplated an e-disco a while back, but I've heard of too many issues to justify the expense. I've gotten so used to it that I don't care anymore. Long story short - sway bars are over rated ![]() |
#12 |
not possible in the '08 Rubicons (without adjusting the computer or doing it the old fashioned way). The electronic sway bar won't disengage unless you are in 4WD Hi/Lo and under 18 (or maybe 20) MPH. Not sure I'd want to run discod, but I don't see it being a problem if I could. Like you said, she's not a vette.
#13 | ||
The flex on pavement is almost non existent simply because there is no real need for flex. The swaybar will limit the down travel, but again on pavement there isn't going to be any real flex in normal situations.
for details and info on our JK's, check out http://n2rock.com His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list Hers: '08 X Red Rock, soft top, auto. Bunch of mods Quote:
#14 |
Cosmetic huh?
will the installation of adjustable trackbars fix the cosmetic issue? As you stated, ONLY the driver will notice. However it will drive THIS driver absolutely bonkers knowing his jeep isn't 100% perfectly symmetrical...LOL. I guess, since you have the same lift I want...Did YOU get adjustable trackbars, N2Rock?
#15 | |
If you do not install the adjustable track bars, other issues that may arise include the tires rubbing in places they normally would not (inside fender flares, control arms, etc.) when your suspension is flexed out.
Visit My Homepage! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
