Install LED Turn Signals - Page 2 - JeepForum.com
post #16 of 27 Old 07-05-2011, 05:56 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Yea I just saw above reference to "failed lamp sensing". Dang computers (Mercedes has a loop system where one contiguous wire feeds all circuits and everything responds via pulse width - thats gotta be a real nightmare)
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #17 of 27 Old 07-05-2011, 06:48 PM
nwbronco
2014 JK Wrangler
Which lights did you end up installing? I'm thinking of adding some at some point.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #18 of 27 Old 07-05-2011, 08:35 PM Thread Starter
whitejeep2010
2010 JK Wrangler
Do I need to connect it to the negative wire as well?
whitejeep2010 is offline
post #19 of 27 Old 07-05-2011, 08:47 PM
Charles
2017 WK
A resistor acts like a load. A load is anything that consumes energy. A resistor consumes energy by converting electricity to heat.
You only need to put the resistor on one side of the wire.
And it doesn't matter where you put it. The load will be increased either way. Test it all before you button it up.
And do yourself a favor, solder those bad boys in and heat shrink them.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #20 of 27 Old 07-05-2011, 08:51 PM
Swagger
a
Swagger is offline
post #21 of 27 Old 07-05-2011, 08:54 PM Thread Starter
whitejeep2010
2010 JK Wrangler
Well, I cut the wire and installed the resistor on the back. Didn't work. Added the front, doesn't work.
Additionally, manufacturers instructions say to connect to the ground.
post #22 of 27 Old 07-05-2011, 09:31 PM
ThunderFoot
Connecting to ground would have the same effect as mounting the resistor across the lamp since one side of the lamp is going to ground anyway. Part of the current will pass through the LED unit and the rest will pass through the resistor to ground. The voltage across the LED will remain the same (see my post #9). You'll need to attach the resistor on the positive side of the LED.
2007 JK Wrangler X Steel Blue Metalic Gray Cloth 3.8L V6 6MT
Freedom Top (Black) Soft Top (Black) 285/75R17 TOYO Open Country AT Pro-Comp 3036 17x9 Alloy Wheels TUFFY Security Drawer Delta Quad-Bar Xenon Headlights JK 6-Switch sPOD Source SuperChips Flashpaq Tune
Diode Dynamics LED License Plate Cobra 75 WX ST 4' Wilson Antenna AIRAID SynthaMax Cool Air Dam Intake System Hella FF 500 Driving Lights Hella Black Magic Driving Lights Smittybilt G.E.A.R. Tailgate Cover
9" Billet Antenna RR XHD Bumpers Fore & Aft with Storage Ends and Spare Tyre Carrier XRC8 Winch 2.5" Pro-Comp Suspension Bilstein Shocks RECON LED Smoked Turn Signals & Fender Lens
Colorado Jeep Club Member #1958
ThunderFoot is offline
post #23 of 27 Old 07-05-2011, 10:03 PM Thread Starter
whitejeep2010
2010 JK Wrangler
I have followed Everyone's instructions. It still does not work. Any suggestions?
post #24 of 27 Old 07-06-2011, 05:48 AM
Hilldweller
2014 JK Wrangler
Originally Posted by Unknown303 View Post
Resistors waste power. ...
Originally Posted by cbloyer81 View Post
A resistor acts like a load. A load is anything that consumes energy. A resistor consumes energy by converting electricity to heat...
Wire in a capacitor and it will work better; call Rallylights and explain what you're doing and they could fab you some plug-n-play pigtails.
---- still won't reflect the light well though.
The housing was made for a filament bulb, not a glowing chip. The photometry will be wrong, especially off-axis.
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #25 of 27 Old 07-06-2011, 08:02 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by Hilldweller View Post
The photometry
I been waiting 27 years, 6 months four days and an hour or so to use that word in a casual conversation and you beat me to it! lol
Good point though...
post #26 of 27 Old 07-06-2011, 08:21 AM
Hilldweller
2014 JK Wrangler
I work in a chromatograph training lab; that word is almost as common here as coffee.
Safety fast,
post #27 of 27 Old 06-10-2012, 05:40 AM
Hvacwelder
2010 JK Wrangler
Originally Posted by ThunderFoot View Post
The way I understand the way the failed light sensors function is it measures current flow. If you wire a resistor in series with the LED it will lower the voltage going to the LED; while it WILL show a current as seen by the sensor the lower voltage will affect the LED output. The shunt resistor should be placed in parallel with the LED. This way the voltage will remain the same through the two parallel portions of the circuit with most of the current flowing through the shunt resistor.
If you deduce the resistance of the LED unit then you can determine the needed value of the parallel resistor. Ohm's Law is E=IR where E=voltage, I = current (amps), and R=resistance. The formula for parallel circuits use:
R(c) = 1/((1/R1)+(1/R2)) where R(c) = resistance of the whole circuit, R1 is the LED resistance (it has to be calculated), and R2 is the Shunt resistor.
I am having a similar issue with after market LED lights I just installed from Pilot auto, they included in their wiring, a load resistor, (value not listed) in their load wire for the turn signal, in series. This is supposed to work, and it does mostly. I noticed if you have the ignition on, engine off, the flash rate is normal either side, once the vehicle is started, the flash rate for either left or right will be rapid for the few seconds then flash at the normal rate for the duration of of that calling for the signal. If you were to use the turn signal again, say just a min or so after the first time it may flash OK, wait longer and it goes back to rapid flash for a few seconds before normal. So I'm guessing once the resister cools down between uses it no longer shows adequate resistance, (load) the first few seconds it's used. What do you think about adding that jumper wire either side of their resistor (the load wire containing the resistor), this would then make that resistor parallel. I'm only asking cause I can still return these and do not want to splice wires onto their harness just yet. I wonder if there is a faster acting load resistor out there?
Hvacwelder is offline
led , led flasher , LED lights , leds
CD install now no turn signals Brian2o0o TJ Wrangler Technical Forum 0 02-20-2010 07:09 PM
Side turn signals stopped working after TJ flare install YJSlave YJ Wrangler Technical Forum 21 05-16-2009 08:25 PM
Clicking noise when I turn on the turn signals ScJeepaholic TJ Wrangler Technical Forum 10 04-08-2009 02:40 PM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
LED Mirror Turn Signals Install Nickb1907 TJ Wrangler Technical Forum 9 07-30-2007 07:30 PM
