Install LED Turn Signals - JeepForum.com
post #1 of 27 Old 07-02-2011, 05:11 PM Thread Starter
whitejeep2010
2010 JK Wrangler
Can anyone direct me to specific instructions on how to install the load resistors for my led turn lights on my JK? The instructions that came with them are not model specific.
Thanks,
whitejeep2010 is offline
post #2 of 27 Old 07-02-2011, 05:21 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Load resistors typically go in series with the wiring as LEDs do not offer enough resistance to the TIPM which will think something is awry with the system. Series resistors will add in the needed resistance so that the TIPM thinks everything is OK.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 27 Old 07-02-2011, 05:29 PM Thread Starter
whitejeep2010
2010 JK Wrangler
Maybe I am missing something, or I was not clear in my post. I understand what they do, and I am looking for instructions on how to install a set that I purchased. The instructions that came with them are not specific to my vehicle (a 2010 wrangler). Thanks.
post #4 of 27 Old 07-02-2011, 05:45 PM
nwbronco
2014 JK Wrangler
You worded it and RockyC explained it fairly well. In series means in the current path. So, when you replace the stock ones, place the resistor on one side of the wire or the other.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #5 of 27 Old 07-02-2011, 05:55 PM Thread Starter
whitejeep2010
2010 JK Wrangler
I have to betray my ignorance of all things electrical. I probably need it drawn in crayon.
If anyone has a picture of what the install looks like, that would be great; if anyone cares to explain what "in the current path" means, that would be welcome as well. I installed them at each location (IE, at each front blinker and at each rear blinker) and I am still getting speedy flashing.
post #6 of 27 Old 07-02-2011, 06:01 PM
nwbronco
2014 JK Wrangler
Blinker rear, yellow white is left rear white is right rear, black is ground. You will need the load placed in the yellow-white wire for the left rear, and the white wire for the right rear.
----yellow/white wire----resistor----yellow/white wire----connector to light.
Same for the white wire.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #7 of 27 Old 07-02-2011, 06:20 PM Thread Starter
whitejeep2010
2010 JK Wrangler
And what about the front?
post #8 of 27 Old 07-02-2011, 06:23 PM
nwbronco
2014 JK Wrangler
Rigs' not handy. So I cannot check on it right now.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #9 of 27 Old 07-02-2011, 09:03 PM
ThunderFoot
The way I understand the way the failed light sensors function is it measures current flow. If you wire a resistor in series with the LED it will lower the voltage going to the LED; while it WILL show a current as seen by the sensor the lower voltage will affect the LED output. The shunt resistor should be placed in parallel with the LED. This way the voltage will remain the same through the two parallel portions of the circuit with most of the current flowing through the shunt resistor.
If you deduce the resistance of the LED unit then you can determine the needed value of the parallel resistor. Ohm's Law is E=IR where E=voltage, I = current (amps), and R=resistance. The formula for parallel circuits use:
R(c) = 1/((1/R1)+(1/R2)) where R(c) = resistance of the whole circuit, R1 is the LED resistance (it has to be calculated), and R2 is the Shunt resistor.
2007 JK Wrangler X Steel Blue Metalic Gray Cloth 3.8L V6 6MT
Freedom Top (Black) Soft Top (Black) 285/75R17 TOYO Open Country AT Pro-Comp 3036 17x9 Alloy Wheels TUFFY Security Drawer Delta Quad-Bar Xenon Headlights JK 6-Switch sPOD Source SuperChips Flashpaq Tune
Diode Dynamics LED License Plate Cobra 75 WX ST 4' Wilson Antenna AIRAID SynthaMax Cool Air Dam Intake System Hella FF 500 Driving Lights Hella Black Magic Driving Lights Smittybilt G.E.A.R. Tailgate Cover
9" Billet Antenna RR XHD Bumpers Fore & Aft with Storage Ends and Spare Tyre Carrier XRC8 Winch 2.5" Pro-Comp Suspension Bilstein Shocks RECON LED Smoked Turn Signals & Fender Lens
Colorado Jeep Club Member #1958
ThunderFoot is offline
post #10 of 27 Old 07-03-2011, 06:27 AM
Unknown303
Thanks,
Resistors waste power. Just run more LEDs for the signal!
Or light ThunderFoot said you just have to wire the resistor parallel to the signal light and all is good from then on.
Unknown303 is offline
post #11 of 27 Old 07-03-2011, 08:50 AM
Swagger
You were very clear in your post!!
Simple way is to use a "Test Light" from any auto parts store. Very inexpensive and handy tool to have around. Turn on your left blinker and at the turn signal find which wire is blinking. Install the resister on that wire. Do the same for the other side.
You must cut the wire to install the resistor, you can not just piggy back it.
Swagger is offline
post #12 of 27 Old 07-05-2011, 05:18 PM Thread Starter
whitejeep2010
2010 JK Wrangler
To make this easier for yours truly, I have uploaded some pics to show what I have done. Hoping that I can receive some correction and get this done right.
Driver's side rear
http://imageshack.us/photo/my-images/813/photo4cs.jpg/
Driver's side front
http://imageshack.us/photo/my-images/838/photo3yl.jpg/
Passenger side rear
http://imageshack.us/photo/my-images/69/photo2viys.jpg/
I figure is someone can direct me on these, I can figure the 3rd one out.
post #13 of 27 Old 07-05-2011, 05:47 PM
Swagger
as nwbronco stated above, looks like the yellow/white wire is the blinker. So cut it into, then place the resistor in between the cut. Look at his explanation again. That's what I meant in my post by you must cut the wire and not just piggy back it. Electricity is like water, it will take the path of least resistance. So you ,must cut the wire and use the resistor to connect the wire back together.
Swagger is offline
post #14 of 27 Old 07-05-2011, 05:47 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Should only need to add resistor to either front or rear - once the resistance is there the flasher will work and flash the whole system.
Of course that said - on my 57 I replaced the flasher unit with an electronic that flashes at same speed regardless of load! ergo NO resistors installed inline.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #15 of 27 Old 07-05-2011, 05:52 PM
Swagger
Of course that said - on my 57 I replaced the flasher unit with an electronic that flashes regardless of load! ergo NO resistors installed inline.
I have seen some of the Mopar vehicles require resistors front and rear.
Swagger is offline
led , led flasher , LED lights , leds
CD install now no turn signals Brian2o0o TJ Wrangler Technical Forum 0 02-20-2010 07:09 PM
Side turn signals stopped working after TJ flare install YJSlave YJ Wrangler Technical Forum 21 05-16-2009 08:25 PM
Clicking noise when I turn on the turn signals ScJeepaholic TJ Wrangler Technical Forum 10 04-08-2009 02:40 PM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
LED Mirror Turn Signals Install Nickb1907 TJ Wrangler Technical Forum 9 07-30-2007 07:30 PM
