Input needed on J4611SSV Trailmaster Suspension 5"F / 3"R Lift Kit with SSV Shocks - JeepForum.com
post #1 of 7 Old 07-22-2010, 01:47 PM Thread Starter
IICON
Any experience, thoughts, or ideas with this system? I only do ocassional off roading when looking for a good camp/fishing site, but I'm more after appearance than anything, and plan to add 35" tires and regear soon after.
For 07-10 Jeep® Wrangler Unlimited JK 4 Door
$354.99
This item has an additional $24.99 shipping surcharge.
Quadratec Part No: 16106.200
Manufacturer Part No: J4611SSV
Trailmaster Suspension 5" Front and 3" Rear Lift Kit with SSV Shocks for Jeep® Wrangler JK. An affordable package for the casual off road enthusiast. Made in the U.S.A.
Limited Lifetime Warranty.
Installation Notes
Install Time: 3-5 Hours
Need tools? Click here
Additional Images
Fits these Vehicles
07-10 Jeep Wrangler Unlimited 4-Door (JK)
Parts Included
Front Coil Springs
Rear Coil Spring Spacers
Front & Rear Shocks
Product Details
5" Suspension lift using new front coil springs and rear polyurethane spring spacers.
Retains factory control arms and track bars.
Complete with SSV shock absorbers.
Retain factory steering geometry.
Easily accomodates 35" tall tires.
Made in the U.S.A.
IICON is offline
post #2 of 7 Old 07-22-2010, 08:06 PM
Warlord2
Sounds really cheap, with 5" of lift up front you will need/want adjustable trackbars front and rear. Stock would work for a smaller lift but 5" its waayy too much. If you are only planning on 35" tires a 2.5-3" lift is what you are going to be after.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #3 of 7 Old 07-22-2010, 08:21 PM Thread Starter
IICON
what are the track bars going to do, what are some suggestions on which one's to avoid/get, or should I choose a different means of complete suspension system set up that will help me add the 35"s that plan to add soon after? There just seems to be so many options from so many companies.
IICON is offline
post #4 of 7 Old 07-22-2010, 11:06 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
AT 5 inches, You WILL need:
1. Adj track bars to recenter your front and rear axle
2. Front drive shaft esp if you have an auto
3. Either cam bolts or adj control arms to reset caster angle
4. The cost seems way too low for such a lift to be considered complete - do some reading and study on this forum - I think you may be missing some critical parts to make this work...just my 2 cents of experience.
And....why go to such a high lift if you don't off road much and only want to go to 35 inch tires? A stock jeep will run 35's with no lift and a little work on wheel spacing, etc. Keep in mind that with such a high lift you are significantly changing the center of gravity/roll center and may actually make the vehicle less stable in a side to side situation...
Search is your friend and also the sticky at the top of this forum "Will it rub?"
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 7 Old 07-23-2010, 10:49 AM Thread Starter
IICON
Good point! If using my stock 17" Rubicon wheels will work with 35" tires, what kind and size of spacer is recommended? I also plan to replace stock fender flares with the Smitty Built XRC Road Armor fender flare kit. I wonder if this combination with the wheel spacers will help eliminate any rubbing issues?
In addition, aside from swapping gears, are there other mods I should do in order to enhance/maintain driveability for our six speed daily driver?
IICON is offline
post #6 of 7 Old 07-23-2010, 01:59 PM
RockyClymer
RedRock4Wheeler
Some of the people I know running the 35 inch KM2s on stock rims use a 1 3/4 or 2 inch spacers - you really need about 4.5 inches of backspacing...this seems to work for them. I believe the flat fenders and spacers will pretty much eliminate rubbing problems - regearing is recommended to maintain some level of acceptable power (putting the engine back into the power band) - the forum consensus seems to be 5.13 for the auto and for your manual 4.88 gearing when going to 35s - that is what I went with.
NRA Life member
post #7 of 7 Old 07-28-2010, 03:29 PM
Gawdger
I just bought the same kit, though mine came with upper & lower adjustable arms and trackbars, etc ($1200). It's sitting in the garage while I save for new tires and I'm having the same dilemma on tire size. From my conversation with TM the rear is 3" and the front is 5". Expect a 1" droop from steel bumper and winch weight. Also, take into effect the stock JK has about an 1" rake to the front and the new front ride height is about 3" depending on how much weight you attach with your bumper choice.
I've got time, due to limited tire funds, so I hope to see some photos of the kit installed with various tire sizes before I purchase. I'm willing to deal with 35's on 4:10 gears to avoid re-gearing; at this point.
2008 Black JK Rubicon
2007 XK Limited
2006 LJ - Sold =(
Gawdger is offline
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 01:44 AM
Trailmaster 4" Suspension System with SSV shocks reecep14 TJ Wrangler Technical Forum 2 07-02-2009 11:48 AM
advice needed: 2"-2.5" suspension lift...which one? b_c JK Wrangler Technical Forum 21 01-04-2009 12:37 PM
Which shocks to a 2,5" suspension lift, soa and 2"bl. dekarson YJ Wrangler Technical Forum 8 05-23-2007 01:10 PM
Selling Trailmaster 2" suspension lift! johnboy77 YJ Wrangler Technical Forum 2 04-24-2005 11:01 AM
