-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Infinity Amp (http://www.jeepforum.com/forum/f96/infinity-amp-1828738/)
porrsher 11-25-2013 07:27 PM
Infinity Amp
Would someone tell me:
A-location of the amp
B-have you successfully upgraded the factored head unit and able to keep/power up the amp
Thanks guys.
gunner_79 11-25-2013 07:38 PM
A: Behind the knee panel under the steering wheel.
B: Not and easy answer. I believe there is a Kicker amp upgrade, but since the amp is connected to the Can bus system, there aren't any other off-the-shelf amps that are plug-and-play with the JK stereo system
porrsher 11-25-2013 07:51 PM
Thanks gunner. I'm wondering if I can upgrade the head unit and speakers only and still use the same amp without modification. Will it work with an aftermarket head unit
Psycho-X-Jeep 11-25-2013 08:12 PM
Yes, but you need the correct wiring harness. Here is what I found using a quick search. Prob only works with Sony head units, but my guess is other manufacturers are on board with similar harnesses.
http://www.quadratec.com/products/96082_421.htm
Psycho-X-Jeep 11-25-2013 08:25 PM
Here is a generic one for the infinity system that can be connected to any aftermarket stereo.
http://www.crutchfield.com/g_751/Fac...s.html?tp=3486
The time now is 11:16 AM.
