Indicator Lights After Lift - JeepForum.com
post #1 of 10 Old 07-19-2010, 07:44 PM Thread Starter
TGuiles
2010 JK Wrangler
Thursday, I lifted my Jeep with a 2.5" suspension lift. A couple indicator lights came on Saturday, went off, then came back on today. The Electronic Stability Control malfunction light and the Electronic Stability Program/Brake Assist System warning light.
Does anyone have any suggestions as to what I should be looking for? Everything *appeared* to be installed soundly.
All stereotypers suck.
TGuiles is offline
post #2 of 10 Old 07-19-2010, 07:49 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
The most common cause of this is the steering wheel not being centered.
The other possibility is that one of the censor wires got pulled when the axles were dropped.
Jim
JLC08JK is offline
post #3 of 10 Old 07-19-2010, 07:50 PM Thread Starter
TGuiles
2010 JK Wrangler
Thanks. We did center the steering wheel, but it is off center again. So we must not have centered it good enough.
I'll check that tomorrow.
Thanks again!
TGuiles is offline
post #4 of 10 Old 07-19-2010, 07:57 PM
JLC08JK
JLC08JK's Avatar
Sometimes it takes a few try's to get it right!
Even a quarter turn will move the wheel a significant amount.
Good luck and show us some pictures!
Jim
JLC08JK is offline
post #5 of 10 Old 07-19-2010, 08:06 PM Thread Starter
TGuiles
2010 JK Wrangler
I already posted some in the what did you do to your JK thread. Here's the link to the post.
http://www.jeepforum.com/forum/f96/w...ml#post9814678
TGuiles is offline
post #6 of 10 Old 07-19-2010, 09:19 PM
Blu-Jacket
2009 JK Wrangler
Not sure if you used the Procal after the lift, but it does have a setting to check the steering alignment once you adjust it.
Blu-Jacket is offline
post #7 of 10 Old 07-20-2010, 03:42 AM Thread Starter
TGuiles
2010 JK Wrangler
Nope, sure didn't. My Superchips arrives today, though, but I don't see where the dead center steering wheel is listed. Do you know if it has it?
TGuiles is offline
post #8 of 10 Old 07-20-2010, 11:19 AM
Blu-Jacket
2009 JK Wrangler
sorry, can't help with the superchip.
post #9 of 10 Old 07-20-2010, 03:40 PM
yukonmuscle
2009 JK Wrangler
I dont think the superchip has a steering wheel centering feature. Just the procal does.
so much sunshine, the jeep gods are smiling at me
yukonmuscle is offline
post #10 of 10 Old 07-20-2010, 04:42 PM
1222
RIP John
1222's Avatar
Even with the ProCal you still might have to do it again. I did.
(2011-2016)
1222 is offline
after lift , indicator light , JK Wrangler , new lift , traction control light , warning lights , wrangler
Indicator Lights dont come on Barkeepa Wrangler General Discussion 1 12-31-2009 10:05 PM
4wd indicator lights andrewnovell TJ Wrangler Technical Forum 4 11-27-2009 09:29 PM
Dash and Indicator lights denalione YJ Wrangler Technical Forum 0 05-17-2008 08:39 AM
4WD Indicator Lights on Dash CTKen TJ Wrangler Technical Forum 12 12-31-2007 02:46 PM
02 TJ 4WD indicator lights domano 68 TJ Wrangler Technical Forum 13 03-06-2006 09:17 PM
