Ignition Issue or bad key?? - JeepForum.com
post #1 of 18 Old 12-03-2007, 07:25 PM Thread Starter
chico166
chico166's Avatar
This has happened three times in the last month. I go out to start a cold Jeep (JK) and the key gets stuck in the forward/starting position where it will just stay and click as if trying to start. Once I turn it back off and re-crank it, its fine. I did notice that the ignition seems a little loose but maybe it is supposed to be that way I don't know. One variable here is that I am using a "Rock" key that I bought from Quadratec and had cut at a local locksmith. I have been using that key for about 3 months though with no problems. Anyone else experienced this or have any thoughts and ideas? I do have an appointment for it on 12/05/07 at the dealer.
2013 JK Unlimited Gecko Green, 4" Skyjacker lift. Pro-Comp 35" Xterrain tires
chico166 is offline
post #2 of 18 Old 12-03-2007, 08:20 PM
AJ in Japan
Jeeps and Bikes - Yea!
Manual or automatic?
AJ in Japan
2007 2-Door Sahara in Black - "Sarah"
2004 Vulcan 2000 - "The Dude"
Mods:
3.5” Skyjacker lift / Currie adjustable control arms (all 8) / Skyjacker dual steering stabilizer /
Poly Performance front and rear track bar relocation kits RHD / Poly Performance high steer kit with drag link flip adapter / 35/12.50/18 BFG Mud Terrain tires on stock painted rims with 1.5” Spidertrax wheel spacers / 5.13 Superior Gears front and rear /gear ratio, tire size and 91 octane performance adjusted with Superchips controller / ARB differential covers / Skid Row front skid plate / Mopar undercarriage skid plates (stock in Japan) / Mopar Rock Crawler bumpers front and rear with rear tire carrier / High Lift Jack mounted on rear bumper (when off roading) / Smittybuilt black D-Rings front and rear / Rampage Products Convertible Side Bar/Rocker Guards / AEV Heat Reduction Hood with AEV Snorkel / 1” over fender extensions / KC running lights on windshield and front bumper / Stubby antenna in black/ Warrior Products Mirror Relocation Brackets when doors are off / Meiwa Ultra Performance Muffler / B & M transmission cooler / Quadratec Ultimate Front Floor Liners / Off Road Heroes Soft Top / Daystar Hood latches and spare tire bump stops / Glass lens headlights with H-4 bulbs (stock in Japan) – headlight and fog bulbs changed to Sylvania Silverstars / Off Road guards for headlights, fog lights and tail lights / MS Plus Navigation System / rear seat removed (1st mod) / and other stuff I can’t remember now
Next: Change the junk Skyjacker Nitro shocks to Bilstein 5100s (on back order now per Dave at Northridge) and change the junk Skyjacker sway bar disconnects to JKS.
Doing it on the left side in Kanazawa, Ishikawa Japan.
Riding a motorcycle is the only time in my existence when I can completely lose myself only to find myself.
It's not the destination.........
It's the ride!
AJ in Japan is offline
post #3 of 18 Old 12-03-2007, 08:22 PM
TheGillz
Have you went back to the stock keys? I would do that for a couple days.
2008 Unlimited X-Jeep Green:Dual Top:6-Spd:Tow-Group:Trac-loc Lim Slip:Hauls: HOT wife, two girls (11&7), Newf
.....|――――|―|―|――|__|¬|._|__
0lllllll0¬
.....|―/―――\―\_|__|――ΊŒ---------¬<=##=>
.....― (o)_)-)_)........…(o)_)χ)_(o)_)χ)_)
TheGillz is offline
post #4 of 18 Old 12-03-2007, 08:24 PM
murray8144
Occasionally, my starter will remain cranking for two or three seconds as opposed to the usual one second to start the jeep.
Rooting for the Yankees is like Rooting for the House in Blackjack.
murray8144 is offline
post #5 of 18 Old 12-03-2007, 08:37 PM
norok2big
here also
We have the issue where you go to turn on the car and the starter seems to continue cranking the car for 2 to 3 seconds. I immediatley turn off the car and then start it again and it's fine. Seems to me there is a bug/defect somewhere that is causing this. Have to find time to take it into the dealer. Our second jeep should be here soon, hope it doesn't have the same issue.
norok2big is offline
post #6 of 18 Old 12-04-2007, 12:16 AM
AJ in Japan
GRRRRRR
One more time:
AJ in Japan
Mods:
It's the ride!
post #7 of 18 Old 12-04-2007, 03:23 AM
wrnglrguy
wrnglrguy's Avatar
I have the exact same issue. It is because the engine starting is all controlled by your computer now. There is a "glitch", and if you turn the key too far, then the starter will turn over but the engine will not actually fire. In previous cars, you had to turn the key all the way and when the car fired up, you released it. This is what I did to "by-pass" the problem........
When you hit the point of the "key turn" where you are about to start the Jeep, simply DO NOT turn the key all the way until it stops. Barely turn it until the starter begins to crank and hold it there until the engine starts. It seems like a pain in the butt, but it really isn't. You get used to doing this. I took mine to the dealer, and of course, they could not duplicate the problem. I figured this little tactic out that I just explained, and it works everytime. I have been doing this since September with no problems. I am just used to it now.
wrnglrguy is offline
post #8 of 18 Old 12-04-2007, 09:51 AM Thread Starter
chico166
chico166's Avatar
Originally Posted by AJ in Japan
GRRRRRR
One more time:
Mine is automatic Aj.
chico166 is offline
post #9 of 18 Old 12-04-2007, 09:55 AM Thread Starter
chico166
chico166's Avatar
Itake mine tomorrow and I will re-post here and let yall know what they tell me. I have already decided that if they tell me they can't dupilacte the problem, that I am going to try the OEM key for awhile. Wrnglrguy's explanation makes sense though.
chico166 is offline
post #10 of 18 Old 12-04-2007, 10:48 AM
DShizzle
My daughter is SAXON
DShizzle's Avatar
Every now and then (and always when engine and steering column is cold) after I release the ignition switch the starter continues cranking while engine is running...seems like it would go on indefinately (engine running while starter ingaged)...of course I would immediately turn ignition switch off then it would start normally w/no problem. I figured (over a year ago) that it was new and with some wear the key switch would loosen up and more freely return to the run position allowing the starter to disengage. Like I said...it has been over a year and it still occasionally does it. I have found that when this occurs if I turn the switch to the start position again and release it very quickly the starter will disengage and it continues to run normally. I am not sure if it is the same problem and I did not intend on posting such a lengthy discription and.........(drum roll).........it is an automatic...
"Political Correctness is a Doctrine, fostered by a delusional,
illogical, liberal minority and rabidly promoted by an unscrupulous
mainstream media, which holds forth the proposition that it is entirely
possible to pick up a turd by the clean end".
DShizzle is offline
post #11 of 18 Old 12-04-2007, 11:23 AM
ghostship
1978 CJ7
Are you guys aware that the JK is a Drive by Wire vehicle? You do not have to hold the Ignition key in the far-forward position until the engine starts. Just turning the key forward then releasing is all that is required, the Jeep's computer will continue to activate the Starter for as long as it takes for the JK's engine to start.
ghostship is offline
post #12 of 18 Old 12-04-2007, 04:25 PM
AJ in Japan
That's why I was asking if manual or automatic. It is my understanding that this "feature" is only on JKs with automatic trannys.
AJ in Japan
Mods:
It's the ride!
post #13 of 18 Old 12-04-2007, 05:24 PM
Slenny
Mines a manual and it does'nt do what Ghostship was describing.
Slenny is offline
post #14 of 18 Old 12-04-2007, 06:43 PM Thread Starter
chico166
chico166's Avatar
I admit to being slightly more than dense in the head, are you saying to turn it until it begins to fire and let it go instead of waiting until it actually starts before you let it go?
chico166 is offline
post #15 of 18 Old 12-04-2007, 08:32 PM
AJ in Japan
Yes, if it's an automatic tranny
AJ in Japan
Mods:
It's the ride!
ignition/electrical issue. romo1000 YJ Wrangler Technical Forum 11 09-24-2009 07:19 AM
Is this an ignition module issue? racerx8413 YJ Wrangler Technical Forum 5 09-15-2009 06:49 PM
Wet Ignition Issue wsroman TJ Wrangler Technical Forum 0 08-01-2009 08:59 PM
ignition issue help! jeep795 YJ Wrangler Technical Forum 4 06-03-2006 04:54 PM
HELP GUYS: ignition issue standnstillfast YJ Wrangler Technical Forum 9 01-07-2006 11:56 AM
