I threw away my key… - JeepForum.com
 1Likes
post #1 of 30 Old 07-29-2010, 02:45 AM Thread Starter
1222
RIP John
1222's Avatar
Well, here’s another “I lost something down my dash” gripe. I was out off-roading with my sister and niece and just before we hit the road to go home I stopped to air back up. I took my key out of the ignition as I always do before exiting the Jeep except this time was a bit different. Instead of holding onto the key, stupid *** me tossed it on top of the dash against the windshield. As soon as it made contact with the windshield I new I was screwed. Down it went never to be seen again.
Luckily I had my spare hidden on my Jeep and was able to use it. Good thing too as we were a couple of hours away from home in the middle of no where and it was late at night.
It's not the first thing I’ve lost down there. I don't remember what the other thing was now cause it was long ago but considering what a new spare would cost me I think I might try removing the dash. Anyone have an easy way of doing it before I tear into it?
(2011-2016)
1222 is offline
post #2 of 30 Old 07-29-2010, 03:47 AM
Warlord2
depends on where you lost it, the center is the hardest to get to. I had to dig for my lighter once but it was on the drivers side of the center dash. Just had to pull a couple of panels under the steering wheel and I found it wedged in some brackets. The pasenger side isnt bad either, just pull the glove compartment out and get a flashlight to hunt around in there. GL with the center part, lots of crap to have to pull to get under there, magnet stick might help along with a little flashlight...
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #3 of 30 Old 07-29-2010, 07:03 AM
2jk1cjtj
Best thing is to let the winshield down to get a good look down there while you try to fish things out.
2jk1cjtj is offline
post #4 of 30 Old 07-29-2010, 08:11 AM
Ajaxxx
2010 JK Wrangler
Sounds like a good mod would be to use some mesh to cover the dash vents to prevent large items from disappearing... I may need to prototype some mesh this weekend!
IowaAndy
IowaAndy
2010 JK Unlimited Deep Ocean Blue, Auto, Cruise, Softtop, Half-doors, A/C
Ajaxxx is offline
post #5 of 30 Old 07-29-2010, 09:13 AM
md41969
Foam pipe insulation does the trick. Costs about a buck and fits right in and fills the gap.
Current:
2008 Rubicon Unlimited
Sold:
1995 Wrangler
White Jeep Club Member #81
Originally Posted by FourbyFour View Post
"....you know what hurts the most, it's the lack of respect, that hurts the most.....and, and the the other thing hurts too, BUT not as much as the lack of respect..disgusting.."
Originally Posted by Rob99 View Post
Your dog's head doesn't look like it belongs on his body. Is it an aftermarket head?
md41969 is offline
post #6 of 30 Old 07-29-2010, 09:15 AM
Jiblet
IowaAndy
Its not so much the vents as the huge gap (I believe it is to allow the windshield to fold but IDK)
folks have put foam pipe insulation tubes (the split foam tubes for copper heating pipes) into the gap between the dash and windshield.
this stuff:
Pipe Insulation, Semi-Slit, 2 In, 6 Ft - Pipe Insulation - Pipe and Tubing - HVACR : Grainger Industrial Supply
Jiblet is offline
post #7 of 30 Old 07-29-2010, 10:30 AM
thegreatself
Does the pipe insulation block any airflow, either for defrost, or the intake for recirculate?
thegreatself is offline
post #8 of 30 Old 07-29-2010, 11:18 AM
McKBrew
JK Wrangler
All you need to do is lose the other key and that will preven getting locked in. Can't get locked in if you can't get in!
McKBrew is offline
post #9 of 30 Old 07-29-2010, 11:28 AM
Polkchop
2007 Silver JK Unlimited
1995 YJ: Wish I still had it...
Polkchop is offline
post #10 of 30 Old 07-29-2010, 11:43 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I can't help you with the R & R of your dash
But you can help others by doing a little write-up (with pic's) on the process so we can add it to the new F.A.Q.
While you're trying to find your key.
Good luck with your "Treasure Hunt"
Jim
JLC08JK is offline
post #11 of 30 Old 07-29-2010, 11:47 AM
tennistom1
2009 JK Wrangler
It's crazy and poor design to have a gap that wide, where eventually things are bound to fall into like keys, pens, credit cards, cigarette lighters, etc. I've had a couple of close calls and keep telling myself to fill the gap. I also wonder if there is any HVAC purpose to having the gap open? If a cigarette lighter falls in there it could possibly be a safety problem if it overheats from the defroster. I think this is worthy of a recall and Chrysler should come up with a filler piece to fix it. If anything falls in there, if should be fished out by the dealer as warranty work.
2009 JK Rubicon 4-Door
2006 TJ Rubicon Unlimited
tennistom1 is offline
post #12 of 30 Old 07-29-2010, 12:19 PM Thread Starter
1222
RIP John
1222's Avatar
Thanks for the reply’s guys. All of them are great ideas. I especially like the one about the foam insulation. I remember awhile back about someone on here suggesting that before. Can’t recall who said it but I was going to give it a try. Too much time went by and I forgot all about it.
About the write-up; I’ll give it a shot and see how things go. If it seams like it would be worthy I’ll do one. I’m kinda hoping it won’t be because hopefully my key will just fall out somehow. I’ll give it a shot though.
(2011-2016)
1222 is offline
post #13 of 30 Old 07-29-2010, 12:21 PM Thread Starter
1222
RIP John
1222's Avatar
That’s a good question. I’ll definitely check before I totally block the gap.
(2011-2016)
1222 is offline
post #14 of 30 Old 07-29-2010, 12:35 PM
DBA2GO
I laughed so hard at this post, I almost fell out of my chair! Good one, McKBrew!
You were beggin for this one 1222!
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #15 of 30 Old 07-29-2010, 02:48 PM Thread Starter
1222
RIP John
1222's Avatar
I know. It’s kinda embarrassing doing stuff like that but at the same time I like to keep the forum members amused, at my expense I guess. Anyhow, it just might help keep newbies from some unnecessary grief.
I’m still kinda laughing at myself and at the same time wondering what the hell was I thinking when I tossed the key up there in the first place.
(2011-2016)
1222 is offline
dash , dash board problem , gap , hole to nowhere , JK Wrangler , space , wrangler
I just threw up in my mouth a little~! MikeUnlimited04 Wrangler General Discussion 20 12-14-2009 04:22 AM
Engine threw a rod (I think)... ROLNOVR TJ Wrangler Technical Forum 11 04-19-2009 02:37 PM
Threw a rod. Now what? parrot5254 YJ Wrangler Technical Forum 12 03-11-2009 02:47 PM
threw some new meats on her DaMoose TJ Wrangler Technical Forum 12 07-10-2006 08:07 AM
threw a rod? what to do? JDEEEWP YJ Wrangler Technical Forum 26 01-02-2004 12:48 PM
