I need some help here! - JeepForum.com
post #1 of 7 Old 10-13-2013, 09:40 AM Thread Starter
Xd_shooter676
1947 CJ2A
Ok so i just bought a 09 rubicon 4 door jk with 35s and a 4 inch teraflex lift. Drives great until you do a turn over 50 then coming out of turn its like the front just wants to keep turning like the chassis is going a diffrent way than body. Any ideas? Please help it's scary to drive over 55 i know it's lifted it's not my first jeep and not my first lifted veh. Also I am a jeep tech i work at a dealer but never ran into this before.
Xd_shooter676 is offline
post #2 of 7 Old 10-13-2013, 10:17 AM
JTPhoto
JTPhoto's Avatar
Is the steering wheel returning to center on its own after a turn or do you have to steer it back.? Are the rear brakes activating and ABS/ESP light coming on? At 4" lift you will loose caster ...
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #3 of 7 Old 10-13-2013, 02:04 PM Thread Starter
Xd_shooter676
1947 CJ2A
Yea esp light on and I have to force back to center
post #4 of 7 Old 10-13-2013, 02:10 PM
ncb
Is the steering wheel centered?
ncb is offline
post #5 of 7 Old 10-13-2013, 02:32 PM
JIMBOX
Sounds to me like the BIG lift took all of your positive caster-
Now the steering has no input for it's "return to 0" (straight) position-
Probably need adj Lower Control Arms (LCA)-and re-ctr steering as ncb says-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #6 of 7 Old 10-13-2013, 04:21 PM Thread Starter
Xd_shooter676
1947 CJ2A
Steering wheel not center yet no
post #7 of 7 Old 10-13-2013, 04:30 PM
JTPhoto
JTPhoto's Avatar
The steering wheel not centered, alone will drive the system nuts. Center steering wheel first before doing anything else.
Drive forward into repair area keep front tires as straight as possible. Notice the orientation of the steering wheel spokes. With a w15mm wrench loosen 2 nuts on collar on draglink ( just off steering box). Turn collar 1/2 to one turn, check steering wheel orientation, if the steering wheel is going the wrong turn the draglink collar in the opposite direction. Repeat until the steering wheel is centered. Take for a test ride, you may have to do this procedure a couple times till its dialed right in.
^^Jeff^^
JTPhoto is offline
