-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   I need an extra key for my 2013 JKU... What are my options? (http://www.jeepforum.com/forum/f96/i-need-extra-key-my-2013-jku-what-my-options-1531300/)
Dead-On 06-02-2013 09:14 AM
*** UPDATED *** I need an extra key for my 2013 JKU... What are my options?
Ok I have a 2013 JKU Sport (not the base) and I would like to have an extra key made. Both dealers are telling me it will cost 150 to 200 dollars for just one remote key. I think that is just ridiculous, do I have any aftermarket options?
Secondly, is it possible to get a key that will start and open the Jeep that is not a remote key? My old Rav4 had this type of a key and they were considerably cheaper to make. The dealer tells me this type of key is not an option for the sport but it is available on the Sahara and Rubicon. How would I go about acquiring this type of key for my Sport?
Jared89 06-02-2013 09:29 AM
Do a search this question has been covered alot.
Dead-On 06-02-2013 09:51 AM
Muchos Gracias Sherlock...
Filthy-Beast 06-02-2013 10:15 AM
Yes there are aftermarket keys, search will find threads with details of keys other have bought from ebay. You must already have two keys that work to be able to program a third. If you only have one then a dealer must do the programming.
RockyClymer 06-02-2013 12:47 PM
Yup, my wife lost her remote sensor key and the dealer needs the JK, the remaining key, and $170 to program a new remote sensor key...sucks, but not much else I can do at this time.
Deuskid 06-02-2013 03:22 PM
related question:
if one programs a 3rd key... then loses one of the original 2... can the other original and the 'clone' be used to make another clone or must the 2 keys be the originals?
Filthy-Beast 06-02-2013 04:14 PM
Originally Posted by Deuskid (Post 15510749)
related question:
Yes, you just need two keys that it will recognize to program the third. that's why I always get a third.
Dead-On 06-02-2013 04:15 PM
related question:
I went back and read the threads on this and it appears you only need two keys with a transponder chip regardless of if they are the originals or a clone/copy.
Now here is what got me worried. According to the dealer I can't use the valet type key with my JKU Sport S. Only the Sahara and Rubicons have those. Both dealers told me I could only get the remote type and not the valet with no key fob. I'm going to buy these from Ebay and keep my fingers crossed hoping the dealer is full of ****.
http://www.ebay.com/itm/2-NEW-CHRYSL...1f6d53&vxp=mtr
donny90yj 06-02-2013 05:07 PM
You'll be good with that, I bought 2 for my 07. Dealer cut and programmed 1 for $65, and cut the other for free. I still haven't programmed the 3rd one but I use it to unlock the door. I'm not too worried about someone stealing it because it wont start the Jeep.
JKPaul 06-03-2013 08:49 AM
With corrections:**
Spare Keys
To all: As soon as you can go to a reputable key shop. Have one key made, no chip or programming, a simple door key only. Have a third ignition key made, assuming you still have 2. Hide the simple non starting made key somewhere in the engine compartment, use a magnet, wire, whatever. Then, hide an ignition key inside the Jeep in a spot where only you can find it, even if you have to work to get at it. Now, the hidden key gets you in, the ignition key gets you going. My cost was $50. Been doing this for years....soon as I get a new Jeep. When I sell my Jeeps I inform the new owner of the hidden keys location and at that point its up to them to do as they please with the keys.
toxicwaste29 06-03-2013 10:51 AM
Let me know if this works. I only have a remote key and want to get a plain jane key for my second set. Will the valet key allow me to turn on the jeep and also open the doors by using the key?
Jiblet 06-03-2013 02:47 PM
I don't know if what the dealer says is true but I do know some people in the thread are misunderstanding what a valet key is. A valet key opens doors, starts ignition but can't open trunk or glove box, unless Jeep has re-defined what a valet key is.
I can't believe the base model has different lock cylinders than the higher model so I can't see why you couldn't have the feature. It's usually just a difference in how the key is cut that makes it a valet key. But I don't know...
As long as you have any two coded-transponder keys, you can program up to 8 (?) more transponder keys yourself. Whether or not they are cut and whether or not they have the electronic guts needed for power locks, remote start, or alarm.
Note that transponder is a passive system and has nothing to do with the power features of a key fob that has various buttons and a battery, etc.
A blank transponder key cost about $15-20.
A blank transponder key with an empty shell for electronics is about the same.
A blank transponder key with three or four-button electronics runs about $125.
Any key place can cut the blanks to match an original key.
A good locksmith can code a transponder for you if you're down to only one key. Otherwise, you have to go to the dealer. The prices may or may not be much different.
I'll note that for those with automatics, the cost of an oem remote start kit is not much over $200 and comes with two four-button keys. And the original three-button keys would still work (just not for remote starting)
Dead-On 06-03-2013 03:21 PM
Yes. The valet key is just what it says. It will allow someone who is parking your vehicle (valet parking) to open your door and drive the Jeep but not have access to your glove box etc... It's not a regular $1.00 copy from Home Depot, it has a transponder in it to communicate with the Jeep and allow you to start it.
That's what I thought but the service department asked what type of key I had when I scheduled the apointment. He said the base models with the black key fob heads did not allow a valet key. He said the higher end models have a grey key fob head have a different mechenisim in the vehicle than the base Sport and Sport S. I hope he's wrong. I bought the one off of Ebay for $15 shipped and it includes two uncut transponder keys for a 2013 Jeep Wrangler.
Jiblet 06-03-2013 04:26 PM
Maybe someone with knowledge of this new feature will chime in....
Let us know how your new key-blanks turn out. Good luck.
EagleRiverDee 06-03-2013 05:00 PM
Talk to your car salesman. They have a vested interest in keeping you happy, you may recommend them to a friend. Mine got me a third key (my Jeep came with two) for $70. Still not cheap, but it's a fully functional key. If you just need one that will open the door but doesn't need a chip to start the car, any key maker can do that.
The time now is 12:20 AM.
