I am lost. - JeepForum.com
post #1 of 12 Old 06-17-2010, 07:01 AM Thread Starter
troy32323
2010 JK Wrangler
I am lost.
My electronic compass in my JK always says S or SW. Anyone have this problem? Do I need to just get a new one or is there some way to fix it?
troy32323 is offline
post #2 of 12 Old 06-17-2010, 07:13 AM
ronjenx
ronjenx's Avatar
Is anything sitting on top of the center of the dash, above the radio?
ronjenx is offline
post #3 of 12 Old 06-17-2010, 07:18 AM Thread Starter
troy32323
2010 JK Wrangler
Yea. I checked it to make sure the connection was tight etc. Still always has me facing South.
post #4 of 12 Old 06-17-2010, 07:22 AM
plac
he means do you have an upper tray, and if so, do you keep your phone in it.
2015 Subaru WRX
plac is offline
post #5 of 12 Old 06-17-2010, 07:25 AM Thread Starter
troy32323
2010 JK Wrangler
Oh. No I never put anything near the compass. I do not have an upper tray.
post #6 of 12 Old 06-17-2010, 07:30 AM
plac
Easiest thing to try first if you cant already, disconnect your battery for a few mins.
Then there is some setup procedure for the compass i think i have read somewhere..
2015 Subaru WRX
plac is offline
post #7 of 12 Old 06-17-2010, 07:32 AM
JIMBOX
Heh Heh, mine is always off, I've got the Rockhard crossbar in front of the sensor
Just start looking for some moss on the side of trees, you'll be OK
Don't forget to watch the Geese flying-V-faces South
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #8 of 12 Old 06-17-2010, 07:50 AM
N2rock
N2rock's Avatar
owners manual is your friend:
Manual Compass Calibration
NOTE: Before attempting a manual compass calibration,
the engine must be running and the transmission
in the P (Park) position (if equipped).
Compass calibration can also be requested. To manually
calibrate the compass, you must first enter the variance
mode. Press the and hold the left button (located on the
instrument cluster) for approximately 10 seconds to enter
the variance mode, and release the button when the VAR
(Compass Variance) symbol appears. The current variance
value will also be displayed. Once in the variance
mode, it is necessary to release the button, and then press
and hold it again (approximately 10 seconds) until CAL is
displayed (solid not blinking). Manual compass calibration
has been initiated. Drive the vehicle slowly in one or
more circles under 5 mph (8 km/h) in an area free from
large metal objects until the CAL symbol is extinguished.
When the CAL symbol no longer is displayed, the
compass is calibrated and should display correct headings.
Verify proper calibration by checking North (N),
South (S), East (E), andWest (W). If the compass does not
appear accurate, repeat the calibration procedure in another
area.
Compass Variance (VAR)
Variance is the difference between magnetic North and
geographic North. For proper compass function, the
correct variance zone must be set.
Setting the Compass Variance
Refer to the variance map for the correct compass variance
zone. To check the variance zone, the ignition must
be on. Press and hold the left button (located on the
the variance mode and release the button when the VAR
symbol appears. The current variance value will also be
displayed. To change the zone, press the left button once
to increment the zone. The default is Zone 8. After Zone
15, the values will wrap around to Zone 1. When the
correct zone is displayed (per the Compass Variance
Zone Map **look in your owners manual for the actual map)
for the zone that the vehicle is located in, wait
for about 5 seconds, then the trip computer will store the
variance value in memory and the compass will resume
normal operation.
NOTE: The US/Metric display will change from English
to Metric or Metric to English before the VAR
symbol appears, however, it will revert back to its
original setting after programming the compass functions.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #9 of 12 Old 06-17-2010, 07:50 AM
JKIslander
2010 JK Wrangler
try driving North?
JKIslander is offline
post #10 of 12 Old 06-17-2010, 08:09 AM
Abner
2010 JK Wrangler
beat me to it!
Originally Posted by JKIslander View Post
try driving North?
Abner is offline
post #11 of 12 Old 06-17-2010, 08:16 AM Thread Starter
troy32323
2010 JK Wrangler
Thanks Nrock. Never thought you would need to calibrate the compass.
post #12 of 12 Old 06-17-2010, 08:17 AM Thread Starter
troy32323
2010 JK Wrangler
I only drive South now so my compass will always appear to be working correctly.
Need help! Lost Key Prokop5588 TJ Wrangler Technical Forum 9 11-23-2009 07:42 AM
lost jake107 YJ Wrangler Technical Forum 12 10-19-2009 06:46 PM
Lost my vibes, but I also lost 2nd gear?? pookie TJ Wrangler Technical Forum 14 01-23-2006 09:34 PM
Lost 2wd!! rrust TJ Wrangler Technical Forum 5 11-28-2004 08:07 PM
lost jks QD pin JeepMud02 TJ Wrangler Technical Forum 6 03-06-2004 03:25 PM
