Hydrolocked my engine with dealer plates still on... - Page 12 - JeepForum.com
post #166 of 197 Old 11-25-2010, 06:42 PM
little_Jeep
Originally Posted by CTJeepWJ View Post
It makes a difference because if you had water sucked into the engine through the top of the engine, then it would actually lock the pistons up and keep them from moving. i.e. your engine wouldn't be able to try to crank hence the 'lock' portion of hydrolock. It literally locks up the engine.
Dealerships and insurance companies can/will generalized damage in order get paperwork processed.
Engine would only be locked until a hole was punched in a piston, or a connecting rod broke, or the water had time to drain into the pan, etc..
Generalize? Something caused internal damage to the engine. The dealer and the insurance company have the Jeep, they have seen the broken parts, and I would assume they know the signs of water ingestion to look for. JKtester isn't much help in providing information because he is not mechanically inclined and as far as I know, has not personally seen the damaged parts or the signs that led to the conclusion of water ingestion.
little_Jeep is offline
post #167 of 197 Old 11-26-2010, 12:59 AM
ultimo
I have a video that I hope to post up this weekend on the WJ splashing through water
Build Thread-- http://www.jeepforum.com/forum/f197/ultimos-build-1477712/
ultimo is offline
post #168 of 197 Old 11-26-2010, 01:55 AM Thread Starter
JKTester
2011 JK Wrangler
JKTester, when you tried to restart it, did the starter activate and try to turn over the engine?
Yes, the starter would activate but nothing would engage.
JKTester is offline
post #169 of 197 Old 11-26-2010, 02:02 AM Thread Starter
JKTester
2011 JK Wrangler
You are right in every case, I am not the most mechanically inclined. I do, however, know exactly how an engine works and understand the inner workings well. When I say I'm not mechanically inclined I could not jump under the hood and tell you what was broken unless it was actually something broken, now doing engine work myself...if I had the tools and the time, it wouldn't be a problem. I have not seen the damaged parts but will be bringing them home with me when I pick her up. Hopefully tomorrow or Saturday. Once I get them home I will be able to tell a little more about what happened. I did not get a clear understanding from my service advisor as he was not the mechanic and he was basically reporting to me what the mechanic reported to him. I will gladly post a list of everything that they replaced as well as pictures of the damaged parts.
JKTester is offline
post #170 of 197 Old 11-26-2010, 05:35 AM
LuckRider
LuckRider's Avatar
I don't know if anyone has noticed, but this is a story on Jalopnik. They have the video posted, and after watching that, there is no reason why they shouldn't warranty it: Why Did A New Jeep Wrangler Die In Ten Inches Of Water?
Edit: I should also mention that I have splashed through puddles that deep with the water coming up 20 feet above my Jeep. Yes, that was in 2 different TJs, but honestly, it shouldn't matter. I hit them so hard that the Jeep threw us into the seatbelts when we hit the water.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #171 of 197 Old 11-26-2010, 09:27 AM
little_Jeep
I am sorry that I said you were not mechanically inclined. I hope that I didn't offend you. That was not my desire. Photos of the damaged parts and possibly a copy of the work order and parts that were replaced would provide a lot of information. I just find it odd that people are still debating your engine problems being nothing more than a wet electrical component. We are so far past this point it isn't funny.
Posting stories about I did this or that in my CJ, YJ,TJ,XJ, or whatever non JK there is, isn't a help. It seems that JK's have a real issue with water ingestion. Is it cause by inexperienced driver?, or is there an issue with the design or location of the airbox?, or maybe a vacuum line disconnected that sucks water into the engine? Maybe it's a combination of these issues. Yet, there are Jeepers who have been in far deeper water than JKtester did and they didn't have any water ingestion in their engine. Whatever is causing the issue, a snorkel appears to be a wise investment if you own a JK.
post #172 of 197 Old 11-26-2010, 09:32 AM
Washi
Rockbiter
Washi's Avatar
2009 JK Wrangler
...or maybe a vacuum line disconnected that sucks water into the engine?
...Whatever is causing the issue, a snorkel appears to be a wise investment if you own a JK.
Unless it's a vacuum line, in which case we are all still screwed.
Washi is offline
post #173 of 197 Old 11-26-2010, 10:50 AM
ncb
Normally an open vacuum line will give you issues such as rough idle.
ncb is offline
post #174 of 197 Old 11-26-2010, 10:51 AM
LuckRider
LuckRider's Avatar
If it is a vacuum line, you should be able to extend it with that clear water hose that is used fro hooking up the ice machine on refrigerators.
Support Our Troops!
JFI Member #7:
post #175 of 197 Old 11-26-2010, 12:08 PM
markw8
I think this can be chalked up to it was not his luckey day. The planets were not aligned.
Mark
markw8 is offline
post #176 of 197 Old 11-27-2010, 02:51 AM Thread Starter
JKTester
2011 JK Wrangler
I took no offense at all. No worries. One of my initial thoughts, the .5 seconds that it went through my head, was the potential of it being an electrical issue only to see that everything electrical was still working. While we were stuck out there trying to figure it out we disconnected the battery to see if it would reset anything. It obviously didn't work. In my lack of mechanical skills and not understanding how a starter worked I wondered if possibly the engine just stalled and the started drive snapped making it not turn the engine over. No matter the case it was not anything we could fix while we were out there and I honestly thought that after seeing what I had gone through the dealership would also see that this was an unusual event. If I get nothing more out of this, hopefully my calls to Chrysler and to the management will get them to take a look at the intake to see if there are improvements to be made. Best case scenario they take care of it for me with a "Hey, sorry this happened, we'll cover it this time." But they're covering their butts. In my discussion with the Area Manager he stated that it was an insurance claim because they can't cover water damage. I stated, that this discussion would not even be taking place if I intentionally drove a Seabring into a puddle...but I took their most "capable" offroad vehicle into a puddle it should have handled. That's just my thoughts on it.
I do have to add that so far, Jill (my Jeep) has been unstoppable. I have had her going up some crazy hills and seeing exactly what her capabilities are. When it comes to hills, rocks, or even bush, she has handled it all with easy. Water...not so much.
JKTester is offline
post #177 of 197 Old 11-27-2010, 08:55 AM
little_Jeep
--snip--
Don't hold this against Jill..... just get her a snorkel, and make sure all the joints in airtube are water tight. Then be gentle with any future water crossings.
post #178 of 197 Old 11-27-2010, 10:32 AM
Dave88LX
I saw this on Jalopnik, and I thought that water looked familiar. I used to live in San Angelo, and used to play out at Twin Buttes all the time.
Should have bought a Bronco.
Looks like the water wasn't as deep when you went through it. Either way, there is no reason your "offroad" Jeep should hydrolock after going through that. That is sad.
Same path:
http://www.youtube.com/watch?v=WUU7ybrX7K4
http://www.youtube.com/watch?v=GpcfkCzvJ2I
http://www.youtube.com/watch?v=Xt6nc2yinI0
http://www.youtube.com/watch?v=6VpEq6HXnMA
http://www.youtube.com/watch?v=-e5H_SQ13i8
Dave88LX is offline
post #179 of 197 Old 11-27-2010, 01:50 PM
jmccormick
you would join just to post dave hahahahaahaa
2013 Jeep Wrangler Sahara Unlimited
2013 GMC Sierra 1500 4x4
1999 Jeep Cherokee Sport 4x4
jmccormick is offline
post #180 of 197 Old 11-27-2010, 02:22 PM
Dave88LX
<3 <3 <3
I was so excited when I saw it was at Twin Buttes.
Dave88LX is offline
If you hydrolocked your engine, I have some questions. Vin JK Wrangler Technical Forum 48 09-05-2010 08:16 PM
Engine Skid Plates? Fred007 YJ Wrangler Technical Forum 7 08-27-2008 11:29 AM
hydrolocked engine... Baller_63 TJ Wrangler Technical Forum 16 04-12-2008 04:40 PM
Engine and TC plates jeeperslax TJ Wrangler Technical Forum 3 08-08-2005 03:56 PM
Hydrolocked....new engine time raZe YJ Wrangler Technical Forum 5 09-23-2004 11:25 PM
