how to use hill descent - JeepForum.com
post #1 of 15 Old 12-31-2011, 11:30 AM Thread Starter
kade
not in user guide , how do you use it and when?
kade is offline
post #2 of 15 Old 12-31-2011, 11:48 AM
rubiwannabe
i believe for off road use.....when activated it decreases the need for use of brakes while descendind a downward slope......sorta like a engine or trans brake
rubiwannabe is offline
post #3 of 15 Old 12-31-2011, 11:51 AM
GunDude
2011 JK Wrangler
I believe you have to in 4lo and push the button on an 8% grade or steeper. I believe it uses the antilock brakes to slow crawl you down.
GunDude is offline
post #4 of 15 Old 12-31-2011, 12:04 PM
08Titan
In a rubicon just put out in 4lo and first gear. Lol. It'll just about bring you to a stop even on pretty steep hills.
2007 JK unlimited rubicon, red rock crystal pearlcoat, rc 2.5" spacer lift, 35x12.50 goodyear mtr/k mounted on black 15x8" mb72's. (Mine)
2005 WK Limited 4.7, QTII, Midnight blue pearlcoat. (Hers)
08Titan is offline
post #5 of 15 Old 12-31-2011, 12:28 PM Thread Starter
kade
so you have to be in 4lo ?
y is this not in the manual!!!!!!
kade is offline
post #6 of 15 Old 12-31-2011, 07:46 PM
Karl
Hill Descent Control IS in the Owner's Manual (the one that is on the DVD, not in the User's Guide which is provided in print form at purchase). Here is what it says:
Hill Descent Control (HDC) – If Equipped
HDC is only intended for low speed off-road driving. HDC maintains vehicle speed while descending hills in off-road driving conditions by applying the brakes when necessary.
The symbol indicates the status of the Hill Descent Control (HDC) feature. The lamp will be on solid when HDC is armed. HDC can only be armed when the transfer case is in the “4WD LOW” position and the vehicle speed is less then 30 mph (48 km/h). If these conditions are not met while attempting to use the HDC feature, the HDC indicator light will flash on/off.
When enabled, HDC senses the terrain and activates when the vehicle is descending a hill. HDC speed may be adjusted by the driver to suit the driving conditions. The speed corresponds to the transmission gear selected.
Gear Approximate HDC Set Speed
1st 1 mph (1.5 km/h)
2nd 2.5 mph (4 km/h)
DRIVE 7.5 mph (12 km/h)
REVERSE 1 mph (1.5 km/h)
However, the driver can override HDC operation by applying the brake to slow the vehicle down below the HDC control speed. If more speed is desired during HDC control, the accelerator pedal will increase vehicle speed in the usual manner. When either the brake or the accelerator is released, HDC will control the vehicle at the original set speed.
Enabling HDC
Shift the transfer case into 4WD LOW range. Refer to “Four-Wheel Drive Operation” in “Starting and Operating” for further information.
Press the “Hill Descent” button. The “Hill Descent Control Indicator Light” in the instrument cluster will turn on solid.
Note: If the transfer case is not in 4WD LOW range, the “Hill Descent Control Indicator Light” will flash for five seconds and HDC will not be enabled.
Disabling HDC
Press the “Hill Descent” button or shift the transfer case out of 4WD LOW range. The “Hill Descent Control Indicator” light in the instrument cluster will turn off.
Karl is offline
post #7 of 15 Old 09-23-2013, 06:29 PM
73azbronco
Hate to bring this back up but one question about operation during HD, when its engaged, going downhill, and going slowly, if I apply slightly more braking, I get the feel of the antiskid working through the brake pedal, and the sound of anti skid like a rumble sound, is this normal?
73azbronco is offline
post #8 of 15 Old 09-23-2013, 06:52 PM
Lehman26
2012 MK Compass
I believe that's normal my compass when using hill descent control and adding any braking makes that weird abs sound.
Lehman26 is offline
post #9 of 15 Old 09-24-2013, 08:06 AM
jenniferjeep
2010 JK Wrangler
Does the Rubicon come with the HDC or is it an option?
jenniferjeep is offline
post #10 of 15 Old 09-24-2013, 08:26 AM
GreenRenegade
All newer Wranglers have this feature. BTW, did you know that when your HDC is working, your two normal brake lights come on but not your high mounted brake light. Just a little worthless trivia...
Dan
2013 Wrangler Rubicon 2dr
GreenRenegade is offline
post #11 of 15 Old 09-24-2013, 10:44 AM
jpin321
2015 JK Wrangler
Dan
I have a 2013 sport and I'm pretty sure I don't have this feature. The only button I have is the esc button. Am I missing the location of the button?
"Anyone who has never made a mistake has never tried anything new." ~Albert Einstein
My Jeep History -- 1980 CJ5 > 2005 TJ X> 2013 JK Sport> 2015 JKU Rubicon > ?
jpin321 is offline
post #12 of 15 Old 09-24-2013, 11:09 AM
AlbertaJeeper
I can't see your profile, but I'm guessing you have a stick. No extra feature required!
AlbertaJeeper is offline
post #13 of 15 Old 09-24-2013, 11:13 AM
jpin321
2015 JK Wrangler
Yea its a stick. Guess that explains why I don't have the feature. Thought it was something else I was going to have to enter a konami code to disable
Thanks for the clarification....
jpin321 is offline
post #14 of 15 Old 09-24-2013, 11:13 AM
wilgeno
wilgeno's Avatar
My 2013 JKU Sport has this feature. It may have to have an automatic transmission to have this feature. On the bill of sale from my dealer this feature is listed as a sub-item of 5-Speed automatic transmission.
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #15 of 15 Old 09-24-2013, 12:18 PM
robplumm
Dan
With automatic transmissions...no HDC with std transmission
ETA: 4LO and 1st gear...BOOM! HDC engaged!
robplumm is offline
shifting to 4wd on hill? 01TJMudder TJ Wrangler Technical Forum 8 01-21-2009 07:06 AM
Hill Descent firefly JK Wrangler Technical Forum 12 12-09-2008 03:40 PM
Opinions for quality lift at a descent price? tanewsome TJ Wrangler Technical Forum 0 10-17-2008 09:09 PM
Stalling on hill Vesper0013 TJ Wrangler Technical Forum 12 09-02-2007 10:42 AM
Lurching under steep descent Dale White TJ Wrangler Technical Forum 1 11-17-2001 05:55 PM
