How unhappy would I be with 3.21 axle ratio? - Page 4 - JeepForum.com
post #46 of 58 Old 10-29-2013, 08:15 AM
CaptainEd
I have a 3.21 in a 13 automatic. Its made for mileage but it even seems to lug at low rpm just cruising around. I put a bumper/winch/sliders and if you are a mileage watcher you can see a difference. Personally I don't care but I don't fault you if you do. I am planning 35's and a 2.5 lift. I will regear after that. Its not an option for me as I can tell the difference even with stock tires. The 3.6 has lots of torque and horsepower and it will make up for 3.21's to some degree with an automatic. However for me I am going to 4.56. Mine is a 2 dr sport so I know the regear is a little more expensive. No ambition for lockers as Wisconsin doesn't have that many rock climbs for me to do at this point in my driving career. I will have a Rubi in the future (16-17?) and build from there. Its personal preference and driving conditions that will dictate if you will be happy with a 3.21. Its for the daily driver who wants mileage and still can have a little capability but the potential is just that with a 3.21, potential. Good Luck.
CaptainEd is offline
post #47 of 58 Old 10-29-2013, 06:51 PM Thread Starter
Zrider1967
Thanks for the feedback everyone. I couldn't pass up the deal - I bought the sport even though it has the 3.21 gears. I've decided to go with 33's and no lift for now. I'll wait a couple years to get the 35's, when I have enough $$$ for a both a lift and new gears. Besides the new wheels and tires, I've already got plans for new front and rear bumpers (leaning toward the Aries 15600 and 25600 right now) and a soft top (Trektop NX). I'll also put in a better radio, and I may also get a Procal. Any other recommendations?
Zrider1967 is offline
post #48 of 58 Old 10-30-2013, 06:28 AM
Denbag
I have 2012 sport automatic with 3.21 gears and I just put on 35x12.5 mtr's. It's liveable, not going to say it's perfect. Driving around town isn't bad at all but once you hit highway speeds I usually keep it in 4th and not overdrive. Lost about 2-3mpg after putting on the 35's
Regear is next on my list, most likely 4.10 or 4.56.
Denbag is offline
post #49 of 58 Old 10-30-2013, 06:29 AM
Waltjason
2011 JK Wrangler
If I were you I would take those side steps off. If you an on doing any off-roading you will probably get them caught on something and rip them off. Especially with no lift on it. Just my 2 cents.
Waltjason is offline
post #50 of 58 Old 10-30-2013, 01:55 PM
bbbradley
Originally Posted by SLADE View Post
It's about a $150 option.
You can add a "0" if you have to re-gear.
$295 per Jeep.com Build Your Own. Plus the increased cost of gas.
bbbradley is offline
post #51 of 58 Old 10-30-2013, 04:58 PM
SLADE
I knew it wasn't much. It's been a couple years since I really looked. It didn't matter when I bought my 2013 because I knew better than to consider anything other than one with 3.73's. I just told them to find me one.
Your mistaken if you think 3.73's will always decrease your fuel economy. The 3.73's could result in BETTER fuel economy. There are other factors to consider.... Typical driving speed, tire size, area (mountains/flatlander), towing /hauling...
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #52 of 58 Old 10-30-2013, 05:41 PM
bbbradley
Could...or could not.
post #53 of 58 Old 10-31-2013, 06:46 PM
GonzosWrangler
"I hate with a fiery passion my stupid 3.21 gears and 33s. If I hit the slightest incline on the highway I have to start down shifting. Unless I hit the hill at 70, I'm not able to stay in 6th gear."
Maybe it's me but, I've never had any vehicles in the last 40 years that didn't need to downshift on a hill if the hill was steep or long. Even automatics do, doesn't matter if I had a V8, a 6 or a 4 cylinder in the car, they all downshifted to maintain speed. Some of these automatics downshifted more than once. Why wouldn't you need to downshift a stick shift under the same situation? It's such an easy and simple thing to do.
GonzosWrangler is offline
post #54 of 58 Old 10-31-2013, 07:00 PM
DuckRunner09
1989 XJ Cherokee
Well I'm talking about anything above about a 3 grade.. Basically if its not down hill or perfectly flat I can't keep it in 6th.
I do understand going up hill takes more power and down shifting, but it's just a pain going from 60 to 50 to 45 and ending up in 3rd gear trying to get back up to speed on the tiniest hint of elevation increase.
I don't get lost, just temporarily misplaced
'12 JK-built and wrecked
'89 XJ-work in progress
DuckRunner09 is offline
post #55 of 58 Old 11-02-2013, 02:11 PM
SamM
My 2013 Jeep Sahara MOAB came with the automatic transmission and 3:21 gears. My Jeep was bought for Overlanding and should work perfectly for what I have planned. No lift, larger tires or re-gearing is needed or will be done. The Jeep gets very good fuel mileage. On a recently trip to Florida, I was getting 20mpg traveling with the traffic, at between 75 and 80. At 65 to 70 it gets about 22 to 23mpg. I couldn't be happier with it. Re-gearing, adding a lift and larger tires would void my extended warranty. Not going to happen.
My only additions have been MOPAR and AEV mud flaps, AEV floor mats, a MOPAR trailer hitch and soon a MOPAR cold air intake. With 300hp and stock sized tires it will run just great with the 3:21 gears. My Jeep does not just see street duty, as I live off-road. Getting to my place is great fun. The Jeep is my daily driver but mild off-road use is something I do all the time. It is more than capable for that, as is. The MOAB does not have a heavy hardtop which helps.
My future additions will be a winch in my a AEV bumper, a rear AEV tire carrier, AEV water tanks and Bilstein shocks. It will also get a Gobi roof rack and I am building a Schutt Industries expedition trailer to carry gear and a RTT.
SamM
SamM is offline
post #56 of 58 Old 01-31-2014, 10:07 PM
deaconhill
Originally Posted by SamM
My 2013 Jeep Sahara MOAB came with the automatic transmission and 3:21 gears. My Jeep was bought for Overlanding and should work perfectly for what I have planned. No lift, larger tires or re-gearing is needed or will be done. The Jeep gets very good fuel mileage. On a recently trip to Florida, I was getting 20mpg traveling with the traffic, at between 75 and 80. At 65 to 70 it gets about 22 to 23mpg. I couldn't be happier with it. Re-gearing, adding a lift and larger tires would void my extended warranty. Not going to happen. My only additions have been MOPAR and AEV mud flaps, AEV floor mats, a MOPAR trailer hitch and soon a MOPAR cold air intake. With 300hp and stock sized tires it will run just great with the 3:21 gears. My Jeep does not just see street duty, as I live off-road. Getting to my place is great fun. The Jeep is my daily driver but mild off-road use is something I do all the time. It is more than capable for that, as is. The MOAB does not have a heavy hardtop which helps. My future additions will be a winch in my a AEV bumper, a rear AEV tire carrier, AEV water tanks and Bilstein shocks. It will also get a Gobi roof rack and I am building a Schutt Industries expedition trailer to carry gear and a RTT. SamM
What is an approximate cost of changing gear ratios
deaconhill is offline
post #57 of 58 Old 01-31-2014, 10:54 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
$1500 +
Welcome to the Club
Jim
JLC08JK is offline
post #58 of 58 Old 02-01-2014, 07:31 AM
deaconhill
Originally Posted by JLC08JK
$1500 + Welcome to the Club
Thanks.....
I would be fine for what I'm using it for.... I but slightly larger tire on 245/7516 and a winch on the front. I will be pulling a camper under 1000 lbs. wife and I are just doing some camping, touring on dirt roads, easy two tracking, and silver lake dunes once a year. Mostly for touring.
I thought a different gear ratio would help.
Thanks for your help in advance
