How unhappy would I be with 3.21 axle ratio? - Page 2 - JeepForum.com
post #16 of 58 Old 10-24-2013, 11:53 AM
Bringbackmikey
Ok. Dumb question from a newbie here. Trying to learn. How do I determine what I have? Feel like I have a 3.73 axle but not 100% positive.
Bringbackmikey is offline
post #17 of 58 Old 10-24-2013, 12:03 PM
invest2m4
Jack the front end up, give the tire a full rotation and see how many rotations the drive shaft makes. Put a chalk mark on the tire and drive shaft so you can visually keep track. Slightly more than 3 means 3.21, almost 4 means 3.73.
invest2m4 is offline
post #18 of 58 Old 10-24-2013, 12:42 PM
bbbradley
Thanks for the replies, making a change of winter DD and I was wondering what impact the 3.73 vs 3.21 would have on drivability and fuel mileage in the New England area with frequent trips to the NH/ME mountains skiing. Is it common for dealers to have multiple gearing options in their inventory for manual transmissions? I'd like to try the two back to back on whatever hills I can find in this area, sounds like highway speed hills are the challenge for the 3.21 gears. The off-road driving I would do is limited to Nantucket beaches sand driving, no heavy duty action, would that tax the engine too much too?
bbbradley is offline
post #19 of 58 Old 10-24-2013, 12:51 PM
SLADE
Sand will be enough to bog down 3.21's.
There is no benefit to 3.21's if you are not travelling at 65mph+. If your typical commute consists of slower speeds, then you will not see better MPG out of the 3.21's.
I guarantee you will not regret getting 3.73's. That can not be guaranteed with 3.21's.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #20 of 58 Old 10-24-2013, 01:02 PM
brianjw
3.21s and 35s will be hell even in Illinois. At highway speed you'll be wide open trying to maintain speed. With a strong headwind? Not fun.
4 high probably won't work in sand. Not without destroying a clutch or overheating a trans.
brianjw is offline
post #21 of 58 Old 10-24-2013, 01:05 PM
invest2m4
The mpg difference is nominal at best. In fact, 3.21 could very well be worse if you go with a larger tire as you won't be in overdrive or 6th gear as much. I'd definitely have better mileage with 4.10 than 3.73 as I am in 5th a lot.
post #22 of 58 Old 10-24-2013, 01:10 PM
SLADE
MPG with 3.21's can be worse even with stock tires at less than highway speeds.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #23 of 58 Old 10-24-2013, 01:12 PM
SLADE
I ran 3.73's on my 13 JK 6 speed with 285's (small 33" tire), and often wished I had 4.10s.
I'm running 4.88's and 35's now and am very happy. I wouldn't want less than 4.56's with 35's.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #24 of 58 Old 10-24-2013, 05:23 PM
Butterjeep
2015 WK
If you have money to spend on a JK, a lift, wheels, or tires you have money to regear. If you can't then you can't afford the Jeep. Would you skimp on other "extras" like gasoline, maintenance or insurance?
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #25 of 58 Old 10-24-2013, 07:54 PM
HappyTrails
HappyTrails's Avatar
Originally Posted by Godholio View Post
With 35s you're probably going to want to regear anyway, so the only factor in 3.21 vs 3.73 is that the 3.21 front differential is different and requires more money to regear.
This is the most important issue. The front diff is different = more $$$.
Skip the 3.21 vehicle, buy one with the 3.73's at least (at least the diff can handle deeper gears). Or just take some money saved by buying the 3.21 vehicle and swap a D44 or D60 under there.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #26 of 58 Old 10-25-2013, 11:49 AM
quadna71
quadna71's Avatar
That's quite judgemental.
Current - 13 JKU, 01 TJ
Gone - 03 TJ, 01 XJ, 00 TJ, 93 XJ, 87 XJ, 87 XJ, 53 CJ-3B
quadna71 is online now
post #27 of 58 Old 10-25-2013, 12:06 PM
Yendor
The truth isn't always pretty.
Yendor is offline
post #28 of 58 Old 10-25-2013, 12:11 PM
number40Fan
2014 JK Wrangler
You will need to spin the tire two revolutions.
number40Fan is offline
post #29 of 58 Old 10-25-2013, 12:41 PM
Godholio
This is as asinine as people who insult others for giving a damn about mpg.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #30 of 58 Old 10-25-2013, 04:10 PM
NCRUBI2012
Or call/visit local dealer. They can run build sheet for you right in the service area. Did mine today. My window sticker showed 4.10 but actually have 3.73.
NCRUBI2012 is offline
