how u remove plastic grill on jk to install mesh - JeepForum.com
post #1 of 7 Old 11-03-2008, 11:45 AM Thread Starter
elfamiglia
Okay. I was able to remove the five plastic rivets on the top of the grill. for the life of me, I don't know how the bottom part comes apart. I don't want to pull on the grill too hard because it is plastic. Any detailed help is appreciated?
Oh, I have an '09 JK. Thanks
elfamiglia is offline
post #2 of 7 Old 11-03-2008, 11:58 AM
USAntigoon
Retired from Forum
Check out THESE series of pictures, they for sure will help you. Use a flat screw driver to gently "ease out" the bottom clips..
Sorry it is from another forum.
USAntigoon is offline
post #3 of 7 Old 11-03-2008, 12:29 PM
michaelmjc
Unhook the blinkers, and then grab the bottom and just reef on it. The whole thing will pop out.
michaelmjc is offline
post #4 of 7 Old 11-03-2008, 12:38 PM
Avian
Yup. It just needs some encouragement.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #5 of 7 Old 11-03-2008, 02:01 PM
1222
RIP John
1222's Avatar
Just slip your fingers under the bottom of the grill and give it a good yank. Donít be shy about it either. Start at one end, then the middle and then the other end. If you yank too hard donít worry you wonít damage it. After the first pull youíll have a pretty good idea how hard to pull on the rest of it.
To install it make sure the top of the grill is resting correctly on the top and the sides then line up the tabs on the bottom and tap them in with you hand. Make sure they have popped in all the way.
(2011-2016)
1222 is offline
post #6 of 7 Old 11-03-2008, 02:43 PM Thread Starter
elfamiglia
I grabed the bottom section and gave it a good hard yank, and voila! it came apart.
Thanks everyone for the hint and encouragement
post #7 of 7 Old 11-03-2008, 03:29 PM
1911lover
Ahhhhh,there is some sort of poetry in "jerks, grabs, yanks" and "voilas".
Reason I say that is I am usually to timid to do that as past expensive lessons of "snap, crack" and "oh ****" have turned me into a wimp who turned in his "mancard" years ago.
Bullpoop and heifer dust...the essence of life.
1997 Explorer
2008 Liberty
2008 Sahara Unlimited
1911lover is offline
Mesh Grill Mod.....with Pics! BAMAJK JK Wrangler Technical Forum 245 11-07-2014 09:14 AM
'97 TJ Mesh Grill Insert Mushrabbit TJ Wrangler Technical Forum 13 11-10-2009 05:13 AM
Custom Mesh Grill A.B.C's TheGillz JK Wrangler Technical Forum 35 09-14-2009 07:09 PM
Mesh inserts for grill? Tufftoy TJ Wrangler Technical Forum 16 03-07-2008 01:06 PM
Where to find mesh grill?? bombadillo YJ Wrangler Technical Forum 6 06-02-2006 06:26 AM
