How to stiffen up the steering? - Page 4 - JeepForum.com
post #46 of 52 Old 01-09-2014, 11:03 AM
ferninaz
ferninaz's Avatar
I would suggest you go and get an alignment to see where you are sitting now that you have installed those drop brackets. If your axle is sitting to the right, you should invest in an adjustable track bar. I am sure you know that you should torque everything properly once the vehicle is sitting on the ground under its own weight. Good luck with the investigation. Check your wheel lugs as well if you haven't already.
ferninaz is offline
post #47 of 52 Old 01-09-2014, 11:07 AM
HOKIES2010
2011 JK Wrangler
x2 and when you get it back make sure they didn't fill your tires up to full max.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #48 of 52 Old 01-09-2014, 07:31 PM Thread Starter
irishluck
I have 33"s The tread wright mud tires.
Well that's what I was suggesting before that I think is the issue.
Is I need an adjustable track bar.
Whats an alignment ship going to do that I haven't done already?
irishluck is offline
post #49 of 52 Old 01-10-2014, 09:02 AM
ferninaz
ferninaz's Avatar
They will probably fix your problem or at least tell you what you need to do to fix your problem. They usually have free coffee to so thats nice.
ferninaz is offline
post #50 of 52 Old 01-16-2014, 08:59 AM Thread Starter
irishluck
Unfortunately I'm not really a coffee drinker
Ill just save up to get the adjustable track bars and then go from there. I mean the tires are even on the road it looks like for now. Ill be doing another chalk test this weekend since theirs finally no snow, its dry out and it will be decently nice this weekend!
post #51 of 52 Old 01-16-2014, 04:25 PM
06bluebeast
When you say sitting to the right, do you mean driver side or passenger? if it is sitting to the passenger side, you may have a bigger problem. Also, if you are on 12.50s, expect some slight pulling to the right, most roads have a slight grade, and wide mud tires will follow the road.
06bluebeast is offline
post #52 of 52 Old 01-16-2014, 04:46 PM
YATZI1980
2011 JK Wrangler
If you change your track bar I would also change the hardware to 9/16 grade 8.
YATZI1980 is offline
