How to reset the PCM - JeepForum.com
post #1 of 9 Old 06-04-2008, 03:15 PM Thread Starter
n19948
Does anyone know if this procedure works on the JK?
This very simple procedure will Erase the “Adaptive Memory” stored inside the PCM and allow a new “Adaptive Memory” to be developed.
After performing this procedure the PCM will re-learn and store into Adaptive Memory your engines performance characteristics.
Please perform these steps exactly as they are written, in the order they are written. This will cause the adaptive memory in the PCM to be erased and cause the PCM to go into Fast Learn Mode adaptive mode.
Disconnect the POSITIVE battery Terminal and touch it to ground for 30 seconds. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory.
Reconnect the Battery Cable
Turn Ignition Switch to the “On” position but DO NOT start the engine
Turn Headlight “On”
Turn Headlights “Off”
Turn Ignition Key “Off”
The PCM Adaptive memory has now been flashed, or erased from the PCM.
When you start the engine it will be running off a set of pre-programmed tables that come with the PCM from the factory.
When you get the engine up to operating temperature the PCM will start to collect data for the “Adaptive Memory”.
The PCM will collect data for Adaptive Memory for the first 50 Warm-up Cycles.
I found this in the Cherokee form.
Thanks for any help.
n19948 is offline
post #2 of 9 Old 06-04-2008, 03:51 PM
MacK
2015 JK Wrangler
Hmm.. I wonder if this really improves anything. I mean I get 21MPG in my Jeep. When I first got it, the engine used to rev up but it stopped. Not sure if it was because when I got it was cold out and it was just warming itself, or what. Oh well Let me know if you try this out!
MacK is offline
post #3 of 9 Old 06-04-2008, 04:08 PM
BiGEN
my revs high when my jeep sit for a long while.. and its still 80 degrees out
FOR SALE!
R.E. Monotube Shocks - $200 NEW PRICE
[/color]
BiGEN is offline
post #4 of 9 Old 06-04-2008, 05:18 PM
igofshn
Locked @ both ends
igofshn's Avatar
Sure it does, but it doesn't accomplish anything. Your Jeep will not misteriously run better or have more power. This is usually done to erase codes.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #5 of 9 Old 06-04-2008, 08:59 PM Thread Starter
n19948
I'm having trouble with the torque converter lock up on the 2 to 3 shift - it shutters. The dealer replaced the TC at 800 miles and cleared the pcm and it worked great for 300 miles and it started again. They cleared the pcm 2 days ago and it was great for until today. The mechanic said it looks like the memory is learning wrong so I was just thinking about clearing it again myself and seeing what happens.
Everything else is great. I get 22 mpg and all the shift points are good - just a little shutter on the 2 to 3 shift. Just trying to make it perfect.
n19948 is offline
post #6 of 9 Old 01-10-2009, 11:42 AM
malton
1993 XJ Cherokee
"to ground"...help an idiot out here...to the negative cable/terminal, or...?
"The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by menacing it with an endless succession of hobgoblins, all of them imaginary."--H L Mencken
malton is offline
post #7 of 9 Old 01-10-2009, 12:09 PM
Evil_Trolloc
Yes, the ground would be the negative cable, post, all the chassis (just don't hold it to a painted part or a piece of metal fastened to plastic. Best to go right to the negative terminal at the battery
08 rubicon / 2dr / 6spd / 3.5" rockkrawler / 1" BL / 36" TSL's / superior rear axle shafts, JE Reel 1350 rear DS / skidrow oil/trans skid / riddler covers / EVO C gussets / RK truss / custom grill gaurd / CB / Herculiner / home brew sliders / plenty of scratches
Evil_Trolloc is offline
post #8 of 9 Old 01-10-2009, 03:32 PM
thundercat900
thundercat900's Avatar
Very wrong and could be very bad for any computer controled vehicle. NEVER remove the positive terminal first and NEVER NEVER install the positive terminal LAST.
You should always remove the negative terminal first and install the negative terminal last to help prevent voltage spikes into the vehicles modules.
I'm not saying that every time you spark the positive terminal back on it will wipe out a ecu....but why take a chance.
But I have used many times resetting the pcm by unhooking the netative terminal and touching it to the positive terminal for at least 10 seconds. This will not short anything out because the battery is open and there will be no current flow thru it.
Hesco employee
205-251-1472
Jon Schaefer
2007 JK Unlimited
Supercharged 3.8
Unichip dyno tuned
thundercat900 is offline
post #9 of 9 Old 01-11-2009, 02:38 PM
cerbomark
On Chevy it was just dis connect battery overnight. I would not try what was suggested with the battery terminals unless you are 100% sure of that.
cerbomark is offline
Is there an ECU reset for the JK? RRCP08JK JK Wrangler Technical Forum 0 06-25-2009 09:50 PM
04 TJ - To Reset, OR Not To Reset PCM JohnLM007 TJ Wrangler Technical Forum 4 04-24-2009 06:44 PM
PCM Reset? chorndawg TJ Wrangler Technical Forum 8 03-20-2009 08:25 PM
Cpu Reset 175MM BULLDOG TJ Wrangler Technical Forum 9 04-09-2006 12:09 PM
OBD Reset? captsc TJ Wrangler Technical Forum 8 06-07-2005 07:54 AM
