How to replace stereo?? - JeepForum.com
post #1 of 4 Old 09-30-2013, 06:17 PM Thread Starter
ianmedwards
Are there any tutorials on on how to replace the stereo on a 2013 Jeep Wrangler Sahara Unlimited?
ianmedwards is offline
post #2 of 4 Old 09-30-2013, 11:27 PM
HappyTrails
Check YouTube. There should be plenty of info on that.
Here is a start:
http://www.youtube.com/results?searc...be.xuuDeL4TXb0
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #3 of 4 Old 10-01-2013, 12:28 PM
222Doc
222Doc's Avatar
its fairly easy. I just had the whole dash apart. Not that many screws and bolts. Most of it is snap to gather. The dash cover is two piece. If you need to remove the passenger side upper cover and air bag there is a Hidden bolt in the passenger side defrost vent. Pull that up and there is a bolt. two more up from the glove box, ezey pezy.
After I did it once I could strip the thing down in less than 20 minutes. Including the steering wheel, though you need a puller to work on that.
All in all its rather well done for access. Man the size of the airbag Pyrotechnic is freeking HUGE on the passenger side, two staged. Looks like something Johnny Jihadi would strap to his a$$. weigh over six pounds. Do not work on these unless you follow the tech manual. I would love to set that off to see what it looks like BUT its like 500+$$ but it is Removable from the cover. They way they assembled that is rather trick as well. Pulling the wires, in your mind you think, "red ore yellow", lol.
Stereo you could steal in under 10 minutes if you know how these are put together. Like I said there is very few tools and screws. Unless you get deeper like me.
222Doc is offline
post #4 of 4 Old 10-01-2013, 12:42 PM
222Doc
222Doc's Avatar
Dp
222Doc is offline
