How to replace spark plugs on my 07 JK wrangler - JeepForum.com
post #1 of 14 Old 12-17-2010, 12:15 PM Thread Starter
ccpintl
Bought my first Wrangler 2 weeks ago, just love it. Is there any write-ups for replacing spark plugs on a JK wrangler. I couldn't find any. 3 spark plugs on the driver side is very easy to be located, but the the rest 3 on the passenger side are hiding underneath a cover. Anybody know how to remove that cover to reach the spark plugs. Thanks......
ccpintl is offline
post #2 of 14 Old 12-17-2010, 05:50 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I checked my maintenance manual and there was no info in there on removing the panel...at least I could not find it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 14 Old 12-17-2010, 06:07 PM
jehnmg
2009 JK Wrangler
Just follow the engine wires and you come to the plugs. The passenger side plugs are a bit harder to get to, especially the #1 plug, which is closest to the passenger. You'll need a swivel to get at it.
I did mine last weekend. It took about 10-15 minutes to do the driver's side, and about 30 minutes to do the passenger side. A bit of a pain, but absolutely do-able.
Good luck
Teraflex 2.5" Coil & Shock lift, fr. lower control arms,
Gdyr 35x12.5r15, P.Comp 1069's...
Skids- Sway Bar, c. arms, s.mounts, oil pan, evap. cannister, EVO C2 front axle Gussets...
jehnmg is offline
post #4 of 14 Old 12-17-2010, 06:34 PM
yoda13
Force Wheeler
yoda13's Avatar
are everyone's plugs going bad already? I still have my originals in after 61K miles...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #5 of 14 Old 12-17-2010, 07:41 PM
Unknown303
Should be able to get at all of them with a swivel attachment. I did when the engine ate water. Just watch your poor knuckles.
Unknown303 is offline
post #6 of 14 Old 12-18-2010, 04:19 AM
wilywillie
Using a 4" extension and a u-joint ("swivel") with the socket wrench makes some of them easier. The "guides" that the wires run through can be pulled off and pushed back on when you're done. (JK plastic crap)
wilywillie is offline
post #7 of 14 Old 12-18-2010, 09:57 AM
Vin
When I hydrolocked my engine, another board member here was able to pull all six plugs with a regular socket wrench and a small extention on the trail. It was rough, but he did it.
Vin is offline
post #8 of 14 Old 12-18-2010, 07:56 PM Thread Starter
ccpintl
I will give it try tomorrow..... Thanks for the help guys.
ccpintl is offline
post #9 of 14 Old 05-18-2011, 08:24 AM
Rckcrwlr247
I spent 2 hours changing the spark plugs on my 07 unlimited and finally got to the back sparkplug through the wheel well on the passenger side using my left hand. At first I couldn't get the wire off. When I got the wire off, I went through the top and I used a 3inch extension with a swivel to a 10inch extension and the spark plug came right out. This is almost certainly the worst Jeep design ever. If the battery tray had a removable section (close to the engine)all you would have to do is pull the battery and it would be easy as pie. Good luck guys and gals.
Rckcrwlr247 is offline
post #10 of 14 Old 07-05-2014, 11:09 PM
JeepK9_79
2010 JK Wrangler
The plugs on the passenger side at first look seem difficult and reading all the posts did give me any confidence however they are just as easy as the passenger side, it just require a little bit more prep.
First, you will need three medium/large zip ties and a flat head screw driver. Now remove the rubber tube that is connected to the air box that holds the air filter and move it out of the way.
Secondly, there are two other rubber tubes that are held hostage by a piece of plastic, use your screw driver to unlock. Once they are freed zip tie it up and out of the way.
Now, the only thing that should be in your way is the plug wires. So disconnect them all and zip tie them up and out of the way, that is unless you have a little helper. Now the prep is done so go to town.
Seriously, you do not have to go out and buy anything unless you need an excuse to go buy something you don't have.
Tools: 3 inch extension, spark plug socket, ratchet, flat head screw driver, two zip ties, 9 year old daughter(wanted to help). Staring at it the area and stressing out 15 min, Prep 5 minutes. Total time 10-15 mins for the passenger side. I didn't count the time staring at it stressing out. Good luck and I hope this helps!
JeepK9_79 is offline
post #11 of 14 Old 07-06-2014, 07:26 AM
jabsther
2010 JK Wrangler
I agree with the others, swivel worked best to get them out.
Maybe I dont remember them being to difficult because I did mine shortly after I did my wife's Highlander. Front three 15 minutes, back three took 3+ hours. Back three you cant see next to firewall. Had to take intake manifold and wiper motor panel out to get to them.
jabsther is offline
post #12 of 14 Old 07-06-2014, 08:39 AM
rirrgang
I waited until the magic 100k that the manual says to change them at. Mistake, they were probably done at 50K.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #13 of 14 Old 07-06-2014, 01:19 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Holy thread revival batman!!!
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #14 of 14 Old 07-07-2014, 01:47 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Another good trick - use the spark plug socket that has an external hex on the end - a 5/8 box wrench (or 5/8 shallow socket with swivel) to turn it. That can get you into many a tight place. Its easier to get the socket on it with nothing connected - then wrench or socket to break loose and fingers the rest of the way!
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
How often do you replace your spark plugs? TJShadow TJ Wrangler Technical Forum 87 10-18-2015 09:49 AM
Best Spark Plugs To Replace Oem Ones kronos JK Wrangler Technical Forum 36 04-12-2015 09:28 PM
'04 4cly 2.4l Wrangler Spark Plugs!! hallz907 TJ Wrangler Technical Forum 9 11-18-2009 04:20 AM
Need help changing Spark Plugs in 2003 Wrangler, 4 cylinder, manual sportyceejay08 TJ Wrangler Technical Forum 12 02-27-2009 01:47 PM
2001 Wrangler spark plugs??? frognogonon TJ Wrangler Technical Forum 2 05-09-2003 07:34 AM
