Quantcast How to perform a 6000 mile service. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > How to perform a 6000 mile service.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 05-10-2009, 07:12 PM   #31
lawnboys02
Hey good thread but if i could put in my 2 cents. With the car so new theres no real need to use full synthetic oil. When you start using that you should continue for the life of the car. Save some money and just use regular oil. And for the greasing question if theres a zert fitting then you should grease every oil change since your already under there. I don't remember if you should lift the tires off the ground or not but i know you should only put a little grease. To much and you will bust the seal and it will run all out. Stop before you see it coming out the sides.
lawnboys02 is offline   Reply With Quote
Old 05-15-2009, 07:55 AM   #32
Steve-0
2009 JK Wrangler
Great write up.
Originally Posted by Jerzjeep View Post
The automatic transmission fluid has to be checked with the engine running.
Agreed.
The auto transmission fluid needs to be checked when it is warm, with the engine running. IE, you shouldn't just start the Jeep (or any other auto trans car) and check it cold. Go for a 10 minute drive then check your transmission fluid.
Drinking for the cause.
Join Date > Post Count
Steve-0 is offline   Reply With Quote
Old 05-15-2009, 10:34 AM   #33
-Zona-
You are right, but I wanted to- I don't like doing oil changes every 3k- and that right there negates the savings of using conventional
Originally Posted by MrNate View Post
Zona and Cause. I'm halfway convinced they're the same person.
Originally Posted by cherrybomb05 View Post
Or Zona because he reminds me of charlie sheen
http://www.preparedsociety.com
-Zona- is offline   Reply With Quote
Old 05-15-2009, 10:36 AM   #34
-Zona-
Originally Posted by Steve-0 View Post
Great write up.
Agreed.
I more or less threw that step in there to show where the auto trans dipstick is- you are all correct- the best time to check it is when it is warm. However, there is no harm in checking it cold either (otherwise I don't think they would've put the 'cold' check line on the bottom of the dipstick)
Old 05-17-2009, 07:39 PM   #35
BludoomJK
2009 JK Wrangler
Is there anything I should check on the manual trans for a 6000 mile service?
BludoomJK is offline   Reply With Quote
Old 05-28-2009, 02:12 PM   #36
-Zona-
The fluid is about it, nothing mechanical.
Old 05-28-2009, 10:21 PM   #37
ynfinity
Sweet post! I went with Royal Purple all around. Full syn does make a difference especially on the Autobahn; 3500mi. no oil light....now watch, it will come on when I go to work this morning!
JK Unlimited...It's like a Hummer, only good
ynfinity is offline   Reply With Quote
Old 05-31-2009, 08:28 PM   #38
Storm1126
I just wanted to say thanks to ZonaJeep. The great post and step by step allowed me to do my first oil change ever. My girlfriend kept asking who that man was under that Jeep turning a wrench.
Storm1126 is offline   Reply With Quote
Old 06-02-2009, 05:33 PM   #39
-Zona-
Glad to be of service.
Old 06-04-2009, 12:18 PM   #40
BlackhawkJK
2009 JK Wrangler
Thanks Zona!!! I printed your post out and had it next to me while changing the oil.....my first time too. I must be the only one in the dorms that knows how to change oil..thanks to you. A group of people were like watching me doing it trying to learn lol.
BlackhawkJK is offline   Reply With Quote
Old 06-04-2009, 11:56 PM   #41
-Zona-
I should start slipping subliminal messages into my tech posts...
Old 06-05-2009, 06:55 AM   #42
BlackhawkJK
2009 JK Wrangler
haha...ya but you wouldnt do something like that. I actually enjoyed changing MUST BUY ZONA A HEMI FOR HIS JEEP the oil. I will pass on what I know now. THanks again zona.
Old 06-05-2009, 09:46 AM   #43
-Zona-
I see what you did there
You are welcome, I'm looking forward to posting my 12k service here in about 2-4 months now.
Old 06-06-2009, 12:00 AM   #44
Mudhound0530
2009 JK Wrangler
Take the top cap off first, before pulling the drain plug. My .2USD is to leave oil and oil filter discussion to a different thread. Nice Job, like the pics.
--- Max
88 Comanche
09 RUBICON
Mudhound0530 is offline   Reply With Quote
Old 06-07-2009, 06:04 PM   #45
SpEd
Probably a stupid question, but...
Since the drain plug is towards the back of the pan, would it be beneficial to have the Jeep facing uphill? In other words, would that get more of the old oil out of the system while draining?
Or is this a stupid question?
SpEd
SpEd is offline   Reply With Quote
6000 mile service, d.i.y. service, how to, JK Wrangler, tune up, wrangler
Glock Forum
