How much oil does the JK's 3.8 hold? - JeepForum.com
post #1 of 16 Old 01-05-2007, 02:24 PM Thread Starter
Diesel0312
Since the search on here is useless and I don't see the amount anywhere in the owner's manual, I'm not sure what to add.
2007 Jeep Wrangler Sahara Unlimited
Factory: Silver w/ black soft top, 18" wheels, auto
Mods: Windshield mounted Hella FF1000 driving lights, Rugged Ridge front grab handles, CLC rear grab handles, Teraflex 2.5" BB, Quadratec boor handle covers, Bestop spare cover, Custom front bumper, 17X9 Pro Comp 1079's, 305/17/R17 Buckshot Mudders.
In the works: Custom rear bumper.
Diesel0312 is offline
post #2 of 16 Old 01-05-2007, 03:31 PM
SecondTJ
SecondTJ's Avatar
it takes 6 quarts.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 16 Old 01-05-2007, 04:02 PM
tx-Skydiver
tx-Skydiver's Avatar
1979 CJ5
Originally Posted by SecondTJ
it takes 6 quarts.
a 3.8 Liter engine takes 6 quarts? Really?
tx-Skydiver is offline
post #4 of 16 Old 01-05-2007, 04:09 PM
scottyc
Originally Posted by Wrangler specs
Oil Capacity - 6 qt. (5.7L) plus filter
http://www.allpar.com/model/jeep/wrangler.html
scottyc is offline
post #5 of 16 Old 01-05-2007, 04:16 PM
PJRedd
Pg. 397 in the owners manual has all the fluid capacities.
PJRedd is offline
post #6 of 16 Old 01-05-2007, 05:45 PM
TexasChopper
TexasChopper is offline
post #7 of 16 Old 01-05-2007, 06:33 PM Thread Starter
Diesel0312
Thanks
I called the dealership I bought it from and was told add 4 qts, check the dipstick, then keep adding until it is right, ugh.
post #8 of 16 Old 01-05-2007, 07:32 PM
SecondTJ
SecondTJ's Avatar
yep.
Originally Posted by Diesel0312
Thanks
i'd start at 5 if you were really worried, its going to take alot more than 4 qts,what idiots. Even the 3.8 minivan oil pan takes 5 qts. but remember to start the engine, let it run for a few seconds to let the oil filter fill up with oil too
SecondTJ is offline
post #9 of 16 Old 01-05-2007, 09:06 PM Thread Starter
Diesel0312
Naw, not worried about it, I'll just put in the 6. I just thought it was stupid he told me to start with 4 and keep adding. Doesn't cause me to have much faith in the techs there.
post #10 of 16 Old 01-06-2007, 09:43 AM
benbenben
yep.
As you are changing your oil, add some oil into the filter so the engine doesnt start dry. Just fill the filter 1/2 way and screw it on, use a paper towel for clean up.
benbenben is offline
post #11 of 16 Old 01-06-2007, 01:44 PM
ColoradoJeep06
Depends if you have the half or full doors on
ColoradoJeep06 is offline
post #12 of 16 Old 01-06-2007, 04:38 PM
SecondTJ
SecondTJ's Avatar
this isnt really a problem for smaller filters. you can do this if you chose, but it isnt going to do a whole lot. Its when you get into bigger filters, (i.e. diesel filters), that need to be pre-filled
SecondTJ is offline
post #13 of 16 Old 01-08-2007, 10:18 PM
FixerUpper
The filter goes in sideways, so there is only so much oil you can put into it prior to threading it on.
Just a fyi, the oil comes out under more pressure than I'm used to. When I took out the drain plug, the oil shot out WAY past the drip pan and left a nice spot on the driveway!
FixerUpper is offline
post #14 of 16 Old 01-08-2007, 10:19 PM
Rocky529
Rocky529's Avatar
Add 4 quarts and keep checking dipstick... lovely.
They are so clueless.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #15 of 16 Old 03-09-2013, 09:41 AM
94beachxj
1994 XJ Cherokee
Not on my Jeep!
The Oil pump is at the bottom of the engine in the OIL pan
Oil filter is near mid engine area on my Jeep.
No dry start there.
94beachxj is offline
Will the plastic pieces that hold the soft top on hold a bike rack? Keesh TJ Wrangler Technical Forum 7 08-29-2009 08:37 PM
JK's on ice 242much JK Wrangler Technical Forum 54 12-08-2008 11:18 PM
Who says JK's get bad mpg?? :) tricked919 JK Wrangler Technical Forum 22 11-03-2007 06:43 AM
Used JK's? BlaineWasHere JK Wrangler Technical Forum 4 02-13-2007 01:34 PM
Will the Unlimited Rubi JK's axles hold up to 35 inch tires? DINOCAVE JK Wrangler Technical Forum 16 01-01-2007 07:22 PM
