how much oil do you burn? - JeepForum.com
post #1 of 27 Old 11-21-2010, 07:53 PM Thread Starter
swoll50
swoll50's Avatar
i think im gonna take mine in and have the dealer check it out.
2008 JK, 21000 miles. i generally change my oil at 5000 miles and the last 2 times when ive gotten close to that point, when im coming to a stop light or anywhere else where the rpms drop back to an idle, the oil light will flash on for a few seconds. you bring the revs back up and the light goes off. i seem to notice quite a bit more valvetrain chatter as opposed to when it was brand new, too.
1997 XJ -Red
2008 Wrangler X - Steel Blue 3.73 - 6-speed - 35x12.50 Procomp Xtreme MTs - Olympic 4X4 Rock bumper - 2" XD Series BB
Blue Jeep Club Member #254
swoll50 is offline
post #2 of 27 Old 11-21-2010, 07:55 PM
wilywillie
What does the stick read?
Mine burns a little bit, but keeps enough to last ~5k per change
wilywillie is offline
post #3 of 27 Old 11-21-2010, 08:35 PM
SilvRSpeedX3
My oil disappears too, over the summer it seemed to be 1qt every 1000 miles or so. Since its gotten cold im at a quart after about 2k miles. I have an 08 with 39k on it, seems to be a design flaw with the motors from what I've seen online
2k2 Liberty limited
SilvRSpeedX3 is offline
post #4 of 27 Old 11-21-2010, 08:40 PM
jbco
2009 JK Wrangler
I am coming up on 19k on my '09 2 door and I do not burn any oil between changes at every 3 - 4k. I continue to have the dealer do it as long as they keep sending me coupons for oil changes @$17.95. I can barely do it for that myself. They use the Mopar filter and Mopar 5w-20 'synthetic blend' oil. Any time I have checked, the oil is very clean and I have never had to add a drop between changes. If your oil light is coming on at all, get it checked. If you are burning so much oil between regular oil changes that your oil light is coming on and you only have 21k miles, you either have a leak or a serious problem.
jbco is offline
post #5 of 27 Old 11-21-2010, 09:27 PM
ncb
Your statement makes me think you don't check the oil level. Do you ever check it?
ncb is online now
post #6 of 27 Old 11-21-2010, 10:06 PM
darg
2009 JK Wrangler
The red light has actually nothing to do with the oil level. You would need to have such a low level, that the pump is sucking air to get a break down in pressure or the little bit oil left to circulate is getting cooked hot in an instant. I would rather guess worst case a bad oil pump or best case a hyperactive sensor.
--- When in doubt, C4 ----
KJ6EPH
darg is offline
post #7 of 27 Old 11-21-2010, 10:21 PM
ronjenx
ronjenx's Avatar
People who drain their oil for an oil change, and discover there is only a couple quarts in there, don't like that question.
Many have actually stated they don't believe they should have to check the oil level between oil changes.
ronjenx is offline
post #8 of 27 Old 11-21-2010, 10:51 PM
1222
RIP John
1222's Avatar
Have I missed something? I’ve read this thread twice, quick though and it seams that the OP has never actually checked his oil level with the dipstick.
(2011-2016)
1222 is offline
post #9 of 27 Old 11-22-2010, 07:04 AM
nystrooper
Jeep Oil problems
2007 JK Unlimited Rubicon with 42K miles. I was loosing oil at a quart every thousand mile. Blue smoke on start. Dealer replaced the engine. They had a small percentage of Jeeps with bad rings. Got the new engine, and now at 300 miles, my oil light started coming on. I stopped driving it and called the dealer. Turns out Jeep also has a batch of bad oil pumps out there in brand new engines. It's back at the shop today for repairs. Good thing I was still covered by the powertrain warranty.
nystrooper is offline
post #10 of 27 Old 11-22-2010, 07:25 AM
jstrubberg
2009 JK Wrangler
22,000 miles. I don't burn any noticable oil between changes. I check it every second or third fill up just because of threads like this.
No modern engine should burn oil at anything under 150,000 miles.
jstrubberg is offline
post #11 of 27 Old 11-22-2010, 08:44 AM Thread Starter
swoll50
swoll50's Avatar
I worded that wrong. yes, i check my oil. Seems I burn about a quart every 5000 miles, which is still high, but not like some of yall. I think this is probably a sending problem since it only occurs at low revs and corrects itself with a load on the engine.
1997 XJ -Red
swoll50 is offline
post #12 of 27 Old 11-22-2010, 10:04 AM
insanitize
Jeepin Old Man
insanitize's Avatar
60000 + mile on my 07 JK unlimited I change the oil every 3000 and I've never used/leaked burned much oil.
07 Rescue Green Rubicon
AEV hood, AEV snorkel, ARB front bumper with Warn Powerplant winch, Pure Jeep rear bumper with tire carrier, Poly long arm, RR and Poly skids, 35 GY MTR ks, Hutchinson Beadlocks, 4.88 gears
78 Red CJ 7
v8 some mods. lifted
and other assorted old iron
insanitize is offline
post #13 of 27 Old 11-22-2010, 10:08 AM
NorthRiver
My 2010 doesn't use any that my eye can detect on the dipstick. 11,000 miles on the clock.
I laugh at the guys that say "mine doesn't use a drop". Dudes must have some seriously calibrated eyes to be able to tell if its used a drop of oil.
NorthRiver is offline
post #14 of 27 Old 11-22-2010, 11:06 AM
tavic
2010 JK Wrangler
6500 on my 2010 and it was still full at the 6k change. My dealership runs $20 special on occasion as well. I normally do oil changes myself but I don't mind paying an extra 5 bucks to have someone else do it.
tavic is offline
post #15 of 27 Old 11-22-2010, 11:09 AM
farmer-dave1
I've run synthetic in mine when it was bought used at 16k. Since then I've had to add a quart every 3k miles. I then generally change my oil at 5k miles and generally my level is still full. I'll have to see this winter if lower temperatures affect my oil usage. I haven't talked to a dealer about it but from previous discussion my usage isn't outside of the normal range, just annoying.
farmer-dave1 is offline
How much oil does your 4.0 Burn? SloppyJoseph YJ Wrangler Technical Forum 6 08-11-2010 04:10 AM
How much oil does your TJ burn?? achoo TJ Wrangler Technical Forum 34 07-21-2008 12:46 PM
Can you burn out? LlamaJeep YJ Wrangler Technical Forum 40 02-06-2008 12:52 AM
Can I Burn It? SonofSam02 YJ Wrangler Technical Forum 5 01-13-2008 08:39 PM
New Cat burn in Jeep225 YJ Wrangler Technical Forum 1 11-12-2006 07:54 AM
