How many have Pentastar engines that are OK? - Page 27 - JeepForum.com
post #391 of 516 Old 01-11-2014, 02:52 PM
brianjw
Originally Posted by Spank
I apologize if I'm being ignorant here, but what the **** are you talking about?
Lol
Ok it's not just me who doesn't understand his jibber jabber.
This isn't like Chrysler made the engine 20 years ago and ethanol is a new thing. They built it for the current market. I don't like ethanol fuel or other things being shoved down out throats, but it's here and judging by what I see globally, not going away. If every other manufacturer was having issues building new cars to run on our fuel it would be a different scenario.
94beachxj
I don't understand the entitlement comment. If you think I have a problem with entitlement you're a complete moron. Nothing in my post has a shred of entitlement in it at all.
Go ahead and put your tin foil hat back on and blame everything on government conspiracies. Sounds like you have an issue with accountability.
brianjw is offline
post #392 of 516 Old 01-11-2014, 03:05 PM
BruceM1964
Originally Posted by 94beachxj View Post
Thanks for posting how your pentastar did after going Syn. I have been waiting and chomping at the bits to get Ams-oil in the crankcase. But so far Chrysler has no syn oil or any after mrk oil that meets the manufactures specs.
I will wait. Taps is only best heard on a on a bugle, not a engine..............
Pretty sure I read on the bottle of Pennzoil Platinum synthetic that it exceeds all Chrysler Manufacturer specs.
This quote taken from their website;
"•Pennzoil Platinum® 5W-20 exceeds Chrysler MS-6395,"
http://www.pennzoil.com/motor-oil/pe...Specifications
BruceM1964 is offline
post #393 of 516 Old 01-11-2014, 06:28 PM
94beachxj
1994 XJ Cherokee
I am aware what Pennzoil says about their brand of oil. BUT....Jeep's
owners Manuel states to use Traditional, non-synthetic motor oil. Also with an ILSAC standard of GF5 is recommended.
Pennzoil will not honor any premature damage on your engine, nor will Chrysler if you do not follow proper instructions.
I think Amsoil is the best oil made, but Amsoil will not back my pentastar engine if it fails. Neither will Chrysler. So I am going to wait. And is your engine still tapping? I would be concern about any tapping or ticking.
Thanks.
94beachxj is offline
post #394 of 516 Old 01-11-2014, 06:37 PM
BruceM1964
....Jeep's
Thanks.
Quoted verbatim from the 2013 jeep wranglers owners manual on page 568 under the heading of "synthetic motor oils"
"You may use synthetic motor oils provided the recommended oil quality requirements are met, and the recommended maintenance intervals for oil and filter changes are followed."
And just to clarify my engine has never started tapping, you have me confused with another poster in this thread.
post #395 of 516 Old 01-11-2014, 06:43 PM
94beachxj
1994 XJ Cherokee
Originally Posted by brianjw View Post
Lol
94beachxj
I am not much of a poet or good speaker. So I apologize that my post are a struggle to understand. My point is on the Pentastar failing. I am at a point of protesting about the bad fuels at the pump being a major factor on the failure of this VVT engine! Try to run a lawn mower in the cold weather on corn gas for example. I understand that many feel / think fuel of any kind doe not reach critical engine parts. I can only disagree with those. But to those like me that understand fuel does effect the engine in more ways than the fuel system, should at least hear me out. I have owned 2 jeeps with the pentastar engine. I always use good gas. Real gasoline most of the time.If unable to reach a gas station with 100% gasoline, I treat the fuel with stabilizers.I am confident this is the primary reason I have had no engine failures thus far. i like to share the things that work for me to help others. If it offends you all I am sorry.
post #396 of 516 Old 01-11-2014, 06:48 PM
BruceM1964
Also quoted on page 567 in the same manual under the heading "Engine oil Selection"
"For best performance and maximum protection under all types of operating conditions, the manufacturer only recommends engine oils that are API Certified and meet the requirements of Chrysler Material Standard MS-6395"
Pennzoil platinum and ultra synthetics both meet these standards and surpass them for that matter.
post #397 of 516 Old 01-11-2014, 07:04 PM
94beachxj
1994 XJ Cherokee
" Nothing in my post has a shred of entitlement in it at all. "
I beg to differ.
I do not think its the Manufactures fault/responsibility of what kind of fuels work best in our vehicles. How can you hold any car manufacture under the gun to make a combustion engine to work at peak performance on fuels that cause moisture, water, crud, rust in critical components?
Unleaded fuels is what is required in the pentastar engine PERIOD! When you use fuels that are modified with corn,meth, etc...... that should be on the owner, you not the car manufacture. So yes it is entitlement to suggest the Manufacture is to be responsible for a owners neglect. Sorry but its common sense. If you make a poor choice you get poor results. Your idea that the Car manufacture is responsible for a owner's neglect, is a form of "entitlement" ...
BTW.....Why do you think there is a Warning sticker on every gas pump that has any % of corn in the tanks in the ground?
IF You use crap materials you get crappy results.
Again its not Chrysler's fault!
Peace
post #398 of 516 Old 01-11-2014, 07:12 PM
94beachxj
1994 XJ Cherokee
Wish I could trust that info you got there. But the guys at Chrysler still tell me its best to use dino oil in a VVT pentastar. I really want to use syn oil but this engine is so different than my other older jeep engines, I am not risking it. The guy that posted about his engine tapping after he switched to syn oil, is enough to keep me staying with dino oil.
Once you damage a motor like that, its no turning back.
post #399 of 516 Old 01-11-2014, 07:20 PM
BruceM1964
First you tell me that the owners manual states to use only " Traditional, non-synthetic motor oil"
I show you were the owners manual states exactly the opposite and qute that manual for you then you state "the guys at Chrysler still tell me its best to use dino oil in a VVT pentastar" Which is it?
I have my doubts but if you say so then be happy with dino oil.
post #400 of 516 Old 01-11-2014, 07:49 PM
94beachxj
1994 XJ Cherokee
My owners Manuel does not have that clause about syn oil.
For both the 2012 and 2013 I showed you what is required. Conventional oil.
I am not using any syn oil on this weird motor till its been affirmed by the manufacture. I hate the fact Ams- oil will not back their product on my Jeeps.
So I am not going to take a chance .
BTW do you you have a different type Manuel. ? I do not see anything in mine about using syn oils.
There has to be something in the VVT of this motor that has caused all the uncertainty on the syn oil thing. I guess.
post #401 of 516 Old 01-11-2014, 08:16 PM
Spank
2014 JK Wrangler
blah blah blah
You're arguing for the sake of arguing and you're trying to argue a point that makes absolutely no sense.
The Pentastar head issue has nothing to do with the fact people are using evil ethanol-based fuel, Obama, entitled Americans, the Wrangler specifically, or the fact that just because you're using Super Pure Awesome Mega Gas, you're in the clear.
Can bad gas cause engine problems? Of course it can. Could ethanol be causing the issues present in these engines? It might be. Should it be? Absolutely not.
Please, just quit while you're behind.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #402 of 516 Old 01-11-2014, 08:16 PM
BruceM1964
Page #567;
Page #568
post #403 of 516 Old 01-11-2014, 08:48 PM
94beachxj
1994 XJ Cherokee
I do not have that book.....wow. Guess my dealer short changed me.My Manuel does not look like yours,I think I need to take a trip to town! lol
But I am not going to switch to syn till I find a proven syn lubricant thats able to meet the VVT requirements of this pentastar.
Have you ever heard of this oil? I am going to do more research on this VVT special oil. Thanks for the owners Manuel pic.
post #404 of 516 Old 01-11-2014, 08:53 PM
94beachxj
1994 XJ Cherokee
Driven by Gibbs?
post #405 of 516 Old 01-11-2014, 08:53 PM
BruceM1964
Your warranty is with Chrysler, meet Chrysler's needs not anyone else's.
Closed Thread
Pentastar Price? Terrain Twister JK Wrangler Technical Forum 16 02-06-2014 04:42 PM
RIPP Pentastar dwink JK Wrangler Technical Forum 1 02-08-2012 01:03 PM
JK Pentastar 3.6 in China thejdj JK Wrangler Technical Forum 5 07-01-2011 02:52 PM
No Wrangler Pentastar? ARTSBEST Wrangler General Discussion 12 04-10-2009 01:57 PM
