How many have left the soft top in the back? - Page 3 - JeepForum.com
post #31 of 38 Old 02-13-2007, 04:03 PM
jeepers3
Originally Posted by PatrickBateman
I ended up getting a multi tool one, where you can use them at 90 degrees or straight like a screwdriver...10 bucks at canadian tire...seems like it should do the trick. thanks!
Good luck. That's what I originally tried, before I wised up and went and got my ratchet (:
Cheers!
jeepers3 is offline
post #32 of 38 Old 03-21-2007, 02:22 PM
unlimitedgrizz
have the dealer do it
as it was when you got it brand new? the sticker on mine says to 'remove' one of them...but it looks like a pain in the *** to do, especially now that its winter...
i just had the dealer do it! i picked my x up on 2/28
unlimitedgrizz is offline
post #33 of 38 Old 03-21-2007, 02:30 PM
jeepers3
Was not really an option for me, since I had a 5000 mile drive home from the dealer. (:
jeepers3 is offline
post #34 of 38 Old 03-23-2007, 05:29 AM
07rubi lemon
I asked my 5 star dealer to remove the soft top twice. They "Forgot" both times. I left it mounted for about 3000 miles. When removed, 2 "rub" spots were left on the roll bar. Take it out as soon as you can if you don't want the wear marks.
07rubi lemon is offline
post #35 of 38 Old 03-23-2007, 09:26 AM Thread Starter
PatrickBateman
i dont think mine is 'mounted', its just packed up and laying on top of the sides of the rear of jeep...i think...
PatrickBateman is offline
post #36 of 38 Old 03-23-2007, 10:03 AM
caliwankers
It took me about 30 minutes total to remove the soft top.
You first have to remove the panels and the Freedom Top. It is important to remove the driver's panel first then the passenger side next. There are 8 t40 screws that hold the freedom top in place. 3 on each side along the back sides and 2 on the outside of the front corners of top. The side steps came in handy when getting these top ones out. Then disconnect the wiring harness and the rear windshield wiper tube and remove the top and place aside. Then use the t30 torx to remove the 4 bolts (2 per side) that attach the soft top to the side roll bar tube. Once this is done, put the freedom top and the panels (in reverse order) back on and re-install the harness and wiper tube.
As spring is here, the other option is to just remove the hard top and get the soft top up and operational. I figure 2 more weeks tops for that to occur.
If I have repeated things here, please forgive me.
Cali
Caliwankers
2007 Wrangler Unlimited Sahara
Silver
18" Wheels
Dual Top Group
6 Speed
caliwankers is offline
post #37 of 38 Old 03-23-2007, 10:11 AM Thread Starter
PatrickBateman
Cali
thanks for reply. ya its getting warmer here too, so in the next few days ill just do the latter...thanks again. i guess mine is attached somewhat....
post #38 of 38 Old 03-23-2007, 03:05 PM
wranged
2015 JK Wrangler
I had the dealer remove it before I picked it up beacuse it was 18 degrees. Sales guy said it took them less than a half hour, no charge.
wranged is offline
Left Back-up light out wiring help tturkstra JK Wrangler Technical Forum 7 02-23-2011 11:51 AM
back seat brackets right or left? xamdarb TJ Wrangler Technical Forum 3 05-22-2009 03:07 PM
Anyone ever left a soft top out in the hail? je1330 JK Wrangler Technical Forum 2 12-16-2008 08:56 PM
Pulls left when accelerating, back right when letting off gas... robplumm TJ Wrangler Technical Forum 12 07-11-2008 12:45 PM
Only the back right tire rubs not the left??? Masm127 TJ Wrangler Technical Forum 10 09-30-2004 11:30 PM
