How many have left the soft top in the back? - JeepForum.com
post #1 of 38 Old 02-07-2007, 03:20 PM Thread Starter
PatrickBateman
as it was when you got it brand new? the sticker on mine says to 'remove' one of them...but it looks like a pain in the *** to do, especially now that its winter...
PatrickBateman is offline
post #2 of 38 Old 02-07-2007, 04:11 PM
franx
yeah same here, too cold for now.. wish I could take it out thought.....
I might try to do it this weekend in my father in law's garage...
will give a bit more space in the trunk !!!
franx is offline
post #3 of 38 Old 02-07-2007, 04:32 PM Thread Starter
PatrickBateman
I looked at it...I guess its OK in there, although I worry about it getting damaged....looks like a pain in the *** to get out of there though....
post #4 of 38 Old 02-07-2007, 04:34 PM
RLandis
I made the dealer take it out when the car was being delivered....it took 3 guys in service dept. almost 45 minutes. Then they had to readjust the doors, which weren't closing properly. It's a job, and if I were you, I'd go to the dealer, get them to remove the soft top and lay it down in the back.
RLandis is offline
post #5 of 38 Old 02-07-2007, 04:47 PM
Marauderk
Looks like it would rub thru in spots after awhile
89 YJ Islander Yellow, 258 Clifford intake holly carb MSD 6
Smittybilt flat fenders, Dick Cepek 3.5 in lift, Warn 8000I
2007 Rescue Green 2d Rubicon 6 speed soft top
Rubicon express 3.5 superflex system,35 in interco truxs mt's, skidrow skid plates, Killby muffler plate
Marauderk is offline
post #6 of 38 Old 02-07-2007, 04:52 PM
Rokitt
To reomve the hard top on my 2 door involved one wiring connector and six screws. It was off in less than 15 minutes and my wife and I lifted it off easily. The hardest part (if you call it that) was removing the soft top brackets that mount to the roll bar. Just make sure that you have the right size torx bit,ratchet and extension for removing the screws. You will laugh at yourself for dreading doing it once its removed..
Rokitt is offline
post #7 of 38 Old 02-07-2007, 05:25 PM
Margueritte
Additional benefit of hard top. It is much easier to load stuff in the back of the JK with the hard top on-- You just flip up the window. Ootherwise you have to unclip and unzip the window-- maybe not a big deal unless you need to do it often or it is really cold.
Margueritte is offline
post #8 of 38 Old 02-07-2007, 05:26 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
This must be the dealer that has 7 guys to change a light bulb.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #9 of 38 Old 02-07-2007, 05:38 PM
jimmyjack
Mine's still there in the original warning packaging. It was freakin 10 below zero this week -- it's gonna stay until spring. I'm not worried about damage - I've had 4 soft top jeeps in my life and they are not made out of tissue -- went almost a whole summer with a soft top in the down position and there was no friction issues.
The only bummer is the lack of available room for STUFF. I can wait.
jimmyjack is offline
post #10 of 38 Old 02-07-2007, 05:41 PM
SecondTJ
SecondTJ's Avatar
i took my top out of the back first chance i had
after the hardtop is out, the soft top will come right out
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #11 of 38 Old 02-07-2007, 05:52 PM
mc22958
2008 WK
My wife and I took the soft top out the day after we took delivery. You need a #40 torx bit to undo the top bolts. It took us all of about fifteen minutes.
mc22958 is offline
post #12 of 38 Old 02-07-2007, 10:00 PM Thread Starter
PatrickBateman
seriously, 15 minutes?? the manual is in the truck, but is there specific instructions for just taking out the softop how it is packaged from the factory???
Thanks.
post #13 of 38 Old 02-09-2007, 02:35 PM
qdzlug
It took my brother-in-law and I probably around 40 minutes to take the hard top off, take the soft top off, and then put the hard top back off. 6 T-40 bolts to take off the hardtop (once you remove the panels) and 4 T-30 bolts to take off the soft top.
I wasn't worried about it rubbing, I just wanted the extra space. Of course, I did have the luxury of doing this when it was a relatively balmy 40 degrees out - don't know if I would be attempting it in sub-zero temps unless I was in a heated garage....
qdzlug is offline
post #14 of 38 Old 02-10-2007, 06:24 PM Thread Starter
PatrickBateman
ya its gotta be warmer here for me to do this...f'ing freezing out...thanks!
post #15 of 38 Old 02-10-2007, 07:50 PM
jeepers3
I did it in winter - and I live in Alaska.
It is painless. 8 screws, pop the top off. Take the soft top out, put the hard top back on. You just need someone to help you. It's easy. I would not hesitate to do this if I were you.
Cheers!
jeepers3 is offline
Left Back-up light out wiring help tturkstra JK Wrangler Technical Forum 7 02-23-2011 11:51 AM
back seat brackets right or left? xamdarb TJ Wrangler Technical Forum 3 05-22-2009 03:07 PM
Anyone ever left a soft top out in the hail? je1330 JK Wrangler Technical Forum 2 12-16-2008 08:56 PM
Pulls left when accelerating, back right when letting off gas... robplumm TJ Wrangler Technical Forum 12 07-11-2008 12:45 PM
Only the back right tire rubs not the left??? Masm127 TJ Wrangler Technical Forum 10 09-30-2004 11:30 PM
