[How To] Install Remote Start in 08-09 Wrangler JK - Page 3 - JeepForum.com
post #31 of 38 Old 02-07-2012, 12:13 AM
zamball
2009 JK Wrangler
Originally Posted by Av8terZ06 View Post
Drive to a dealership and have them cut the new keys first, then unplug the plug from the old WCM and plug it into the new WCM, and then follow the directions for programming the new keys and WCM. After that's done, drive home.
I am going tomorrow to get it programmed. So I will have them cut my keys first. Then plug in the new WCM. I read in the manual that it takes two keys that are programmed to do the next set. So where are you finding the directions to program the new keys to the WCM?
2009 JK Rubicon 2.5" RC lift | Drop in K&N filter | Bully Dog GT Gas Tuner
2007 WK CRD 3.0 Stock for now...
zamball is offline
post #32 of 38 Old 02-07-2012, 08:40 PM Thread Starter
Av8terZ06
If I remember right, once they cut the keys, they will then hook up their computer to the jeep and program everything at one time, which is the jeep to recognize the remote start, the WCM, and the keys.. The dealership does all the programming.
2012 Jeep Wrangler Unlimited "Call Of Duty"
2007 Corvette Z06
2009 Jeep Wrangler Unlimited Sahara - Sold
1994 Jeep Wrangler Renegade - Sold
Av8terZ06 is offline
post #33 of 38 Old 10-20-2012, 08:49 AM
rmacleod96
Has anyone found out for sure if this will work without power door locks ?
rmacleod96 is offline
post #34 of 38 Old 10-30-2012, 06:05 PM
arcticmonkey
Thanks for this post!! I've ordered the unit online ($204) The instructions also call for the antenna to be mounted under the passenger side airbag.
Per the installation instructions:
CAUTION:
XBM remote start can ONLY be installed on vehicles that have the following factory options: Automatic Trans*
mission, Remote Keyless Entry and Immobilizer.
WinFobik based vehicles, the sales code must be added to the database prior to installing the new WCM module.
Failure to do so will render the WCM module’s remote start function inoperative.
The technician should wait 1/2 hour between adding XBM sales code in DealerConnect before installing the
WCM module. In the interim, the technician can install all other components except the WCM module.
NOTE: Prior to installation, obtain the four digit PIN from the dealership's parts department.
NOTE: The wiTECH software level must be at the latest release to perform this procedure.
NOTE: Prior to installation, the technician should cut the KEY FOBIK Blanks using the original vehicle's Key
FOBIK as a template.
1. VIN must be updated with the sales code of the added accessory in order to enable system functionality. Using the
DealerCONNECT website and the wiTECH diagnostic application, complete the vehicle configuration.
2. Log on to https://dealerconnect.chrysler.com.
3. On the Home page, select the "Service" tab.
4. On the Service page, look for the Global Claims System area and select "Vehicle Option".
5. On the Vehicle Option page, enter the last eight digits of the VIN, then select "View".
6. On the "Available Vehicle Option'" list, scroll down the list and select "XBM Remote Start System".
7. Click the "Add" button and make sure "XBM Remote Start System" appears in the "Selected Vehicle Option" list on
the right.
8. Click the "Save" button to complete adding the sales code to the vehicle database.
PROCEDURE STEPS:
o||||||||o
2012 Arctic
arcticmonkey is offline
post #35 of 38 Old 01-31-2013, 11:00 AM
JRunner01
So has anyone been able to confirm the kit with the integrated button in the key will work on the 07 with keyless entry \ factory alarm \ automatic trans?
I too would like a remote start in my 07 but don't want the little fobs that Ive seen only available for the 07s.
Also it seems there is a 3rd version which is a 2 way version, but I am not sure which type this is, ie with an integrated button in the key or separate fobs. I think its with the extra fobs as it has a built in led that changes color, although I haven't seen any pics, something I believe I read.
Thanks in advance...
JRUNNER01 2007 JK Rubicon Unlimited REDROCK
JRunner01 is offline
post #36 of 38 Old 02-01-2013, 06:56 AM
JRunner01
Some News From My Dealer...
So its seem according to the parts mgr at my dealer, the 07 will only take the separate fobs version, which is a 1 way communication. As everyone has read, the 08's and up will take the integrated button in a new key version. This is according to Chrysler who he investigated with. Now who knows if anyone "got it to work" in the 07's is my question.
As for a 2 way communication, he didn't say one existed for any model years. So not sure how I read in the thread that a 2 way was installed. Also not sure the model year or version... separate fob or integrated key.
post #37 of 38 Old 02-01-2013, 08:02 AM
jstrubberg
2009 JK Wrangler
You are wasting your money putting a factory remote start unit in. The range on them is absolutely pitiful compared to the cheapest aftermarket units. You can have a decent aftermarket unit installed for what you are paying for parts on a factory system, and the aftermarket unit will outperform the factory one.
jstrubberg is offline
post #38 of 38 Old 12-04-2013, 06:30 AM
DrSaw
Where does the remote antenna go?
DrSaw is offline
how to , installation , JK Wrangler , remote start , wrangler
08 Unlimited and Viper 5301 remote start install trouble kwazyace JK Wrangler Technical Forum 1 02-02-2010 10:20 AM
Install remote start on JK 2.8 CRD simov_mincho JK Wrangler Technical Forum 5 11-05-2009 09:15 AM
'98 Wrangler Remote Start Wiring HELP! SoccerJett TJ Wrangler Technical Forum 3 12-26-2008 08:50 AM
Remote start install Q, heater power? CLynn85 TJ Wrangler Technical Forum 4 01-09-2006 06:12 AM
How hard is remote start install? patriot2005 TJ Wrangler Technical Forum 6 12-08-2005 10:27 PM
