[How To] Install Remote Start in 08-09 Wrangler JK - JeepForum.com
post #1 of 38 Old 04-15-2009, 06:58 PM Thread Starter
Av8terZ06
This is my install write-up from my 2009 Sahara. I ordered the kit part# 82211437AC, which is a factory kit for 08-09, from a chrysler dealership on ebay. Since it was specified for the 08-09 model year, I assume earlier models are different. Below are a few pics to give you an idea. If you have any questions, I will answer the best that I can.
Before receiving the kit, I was talking with a tech at the dealership and he said that the jeep wont start until its programmed and that I may have to tow it in. Well, I wasn't thrilled with that and got thinking that there had to be another way. The way I described the installation below, will still allow you to drive the jeep to a dealership to do the programming. The guy that did the programming at the dealership updated the vin number on my jeep so its included in the system and warranty, From the link below, I printed the programming pages and took them with me to the dealership which helped because initially when he was trying to get it to program through the computer, it wasn't working. It would arm and disarm but wouldn't start. He came and told me about it, and I then told him about the pages on the seat that I brought. He went back, read through it and that's when he saw that the VIN had to be updated through chryslers system in order to work. Anyway, after all that, it worked great. You should be able to install this entire system in about an hour. Especially with my write-up.
I initially wasn't going to install the hood switch at all, basically because I just didn't want to and wasn't worried about someone being under the hood or anything else. Im the only one that will be working on my jeep and also I figured it was just a simple ground or open type of switch. But after receiving the kit and taking a closer look at it, there is a little resister inside the switch between the two pins. So even though the hood is closed and the switch is open, the circuit is still completed and it still sees a very small amount of ground. So the computer still checks for a completely/correctly installed harness. After coming back from the dealership, I also tested this by disconnecting the ground wire at the ground post from the switch, held the hood switch down and tried to start it and it wouldn't. So, youre going to need the hood switch. It only takes a few minutes to install it and is safer to have it anyway.
While I was installing the antenna module. I walked down the street to more than a 300' and was still able to start by remote. So the location I put it in works great.
Also, on a side note, the tech asked if I wanted any other changes with the computer, like the locking, unlocking etc. I already knew how to disable the seat belt chime, stop the horn from honking while arming, and only the driver door to unlock when disarming. So I brought up the doors locking thing at 20 mph. I dont like that and is just more wear and tear. Anyway, he was able to disable that feature as well, which is nice.
Instructions:
1. Disconnect ground cable on battery.
2. Install hood switch with supplied bolt, nutplate, and bracket.
3. Connect ground wire from hood switch to ground post that's about 8" away on driver side fender wall.
4. Route other end of wire along the wire harness that follows fender, then over to firewall, and down to the fuse/relay box and secure with enclosed tie wraps.
5. Pull up relay/fuse box by releasing the 4 tabs in the corners. Leave top cover on.
6. Disconnect center plug on the bottom.
7. Carefully pry bottom of plug cap off with small flatblade screwdriver on the sides. BE GENTLE.
8. Carefully pry out rubber wire seal.
9. Carefully pry up the top of the plug with a very small flatblade screwdriver. BE GENTLE.
10. Using a very small flat blade screwdriver or needlenose pliers, break little black plastic blocker in the 3rd hole of the bottom cap from the plug.
11. Feed new hood switch wire through the bottom cap, then rubber seal of the plug in the 3rd hole and then up through the plug. Make sure you have the terminal end of the wire facing the correct position before feeding into the plug. You will here it click into place once inserted. You can tell which way the terminal end faces by comparing it to the other wires already in the plug.
12. Reassemble plug and plug back into the relay/fuse box.
13. Reinstall fuse/relay box back onto the 4 post bracket. Watch other wires as you reinstall the box back onto the 4 post bracket.
14. Reconnect ground on battery and close the hood.
The jeep is still driveable with this wire installed in case youre unable to finish with the WCM and antenna installation at this point in time and need to continue another day. This wire does nothing at this point.
Installing new WCM and antenna.
1. Remove lower vertical cover under steering column by starting from the top and pulling the top ends, working your way down. Its held in by 4 clips I believe. After the 4 clips have been pulled, rotate the cover downward because its hinged at the bottom, and then remove it and set aside.
2. Lower the steering wheel as low as it will go.
3. Remove the steering column covers by removing the 3 torx screws from the bottom. One screw is easy to see, the other two are recessed up inside the cover. My torx driver wasn't long enough to reach up inside for the recessed screw on the right, so I put the torx driver in a vice and pulled the shaft out of the handle about a quarter of an inch and then it was long enough to reach it.
4. Split the covers and remove them. The rear part of the covers are just snapped together, pretty much like the rest of the jeep. LOL. Just pull part.
5. At this point, you can see the WCM by the key cylinder.
6. Carefully, with a very small flat blade screwdriver, remove the little yellow wire harness plug from the wiper arm assembly by depressing the little retaining clip and sliding toward you.
7. As youre facing the steering wheel, remove 1 phillips screw on the right side of the wiper arm assembly and then slide the wiper arm assy toward the center of the jeep and set aside.
8. Now you can see the 1 screw that holds the WCM in place. Remove it and then push away the arms on the WCM to "unclip" it from the column but DONT disconnect the plug. Just let it hang.
9. Install the new WCM and the 1 retaining screw.
10. Install the wiper arm assembly in reverse order from above.
11. Plug in the wire from antenna module into the new WCM and route excess wire under steering column.
12. Hold antenna module in place against steel plate as seen in pic, mark 2 holes, drill and attach module.
In order to start the jeep, you will need to hold the old WCM close to the key, then start the jeep. After it has started, continue holding the WCM close to the key while the jeep is running for about 3 seconds and then let go of it and let it hang. You wont have any problems with it after that. Drive to a dealership and have them cut the new keys first, then unplug the plug from the old WCM and plug it into the new WCM, and then follow the directions for programming the new keys and WCM. After that's done, drive home.
13. Reattach steering column covers in reverse order from above
14. Reinstall lower vertical cover under steering column in reverse order from above.
DONE !!
http://site.justforjeeps.com/guide/82211437AC.pdf
2012 Jeep Wrangler Unlimited "Call Of Duty"
2007 Corvette Z06
2009 Jeep Wrangler Unlimited Sahara - Sold
1994 Jeep Wrangler Renegade - Sold
Av8terZ06 is offline
post #2 of 38 Old 04-15-2009, 08:14 PM
WVUJeeper
Originally Posted by Av8terZ06 View Post
Clickfreed for you.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
post #3 of 38 Old 04-15-2009, 08:18 PM Thread Starter
Av8terZ06
Originally Posted by WVUJeeper View Post
Clickfreed for you.
Oh thank God. You saved me from about 25 stupid posts. LOL
2007 Corvette Z06
post #4 of 38 Old 04-15-2009, 10:48 PM
gmd
2009 JK Wrangler
can i get it for a manuel
----says it all----> meus veneratio est verum
Originally Posted by jsbarks View Post
pics or your making this all up
n i g h t c r e w #077
BLACK JEEP MEMBER 327
(from:friskeljr)The real test comes when all strength has fled and man must produce victory on will alone...
Courage is the mastery of fear...
rs.com/commu...mber.php?u=750
gmd is offline
post #5 of 38 Old 04-16-2009, 07:57 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Great write-up .. added it to the FAQ
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #6 of 38 Old 04-16-2009, 08:17 AM
badazzelanore
You cant get it specifically for a manual because it is a safety issue. If you didnt have the parking brake on all the way and had it in gear like most people do when they park (since back in the day they didnt have good parking breaks on thier old manual trani's lol) you could start it and have your Jeep drive itself probably into the garage or another car... anyway, you CAN take it to an alarm instaler or somthing along those lines and pay a **** load to have it installed and have the safety clutch switch disabled though im not sure how to get around it being programmed by the dealership.
badazzelanore is offline
post #7 of 38 Old 04-16-2009, 03:43 PM Thread Starter
Av8terZ06
Im not sure if the factory remote start system will work with a manual, but an aftermarket system definitely would. When I had my 94 Renegade w/ 5 speed, I had a remote start system in it. Down at the clutch, there is a little switch that is activated when you depress the clutch. Usually most vehicles these days wont start unless the clutch is depressed. Anyway, I just unplugged the plug and made a little jumper wire and installed it into the plug. I hate having to always press the clutch to start my vehicles. Im the only one that drove my Renegade and I always left it in neutral. I may be working on it and if I need to start it, I can just lean in the window and do so without having to get all the way in and hit the clutch first. If the only thing on the newer jeeps is the clutch switch that makes the difference, I dont see why the factory remote start system wouldnt work. But finding a dealership that will hook it up to their computer and make the program changes in the jeep is another story.
2007 Corvette Z06
post #8 of 38 Old 04-17-2009, 03:36 AM
DarnBig
DarnBig's Avatar
What is the hood switch for?
~Michael
Her New Ride: 2012 4 door Rubi in Dozer Yellow/Orange - Stock for now.
DarnBig is offline
post #9 of 38 Old 04-17-2009, 06:03 AM Thread Starter
Av8terZ06
Its just for safety. In case you happen to have the hood open and are working on something and say someone hit the start button on the key fob, it prevents the engine from starting. Or if there was some type of glitch with the remote start system and you happen to be under the hood and say the engine just started all by itself suddenly etc etc. The hood switch sends a ground signal to the computer so it wont/cant start.
2007 Corvette Z06
post #10 of 38 Old 04-17-2009, 07:21 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
that was a really good write up
nice
keep wheeling
-Matt
mattman8706 is offline
post #11 of 38 Old 04-17-2009, 09:20 AM
mefly2
Super write up; may I ask the kit cost as well as the charges from the dealer?
mefly2 is offline
post #12 of 38 Old 04-18-2009, 06:43 AM Thread Starter
Av8terZ06
Thanks. The kit was about 200.00 and the dealer wanted about 95.00 to cut the keys, program the keys to the computer, and to do the computer programming for the remote start. I thought that was a little high but initially the dealership wanted a little over 500.00 to do the entire kit. So I saved at least 225.00 by doing it myself and have the satisfaction that it was done right.
2007 Corvette Z06
post #13 of 38 Old 04-18-2009, 07:39 AM
SaharaBlackNo1
Excellent write up. I've been wondering if it was possible to install the 08-09 kit you purchased on an 07. The 07 kit doesn't have the integrated key and it's actually a seperate little fob which I don't like. I might have to go poking around under the hood to see if the wiring is the same, because so far nobody has been able to say definitively if the kit you installed will or won't work on an 07.
AEV: Hood, Skidplate & Bumper, jackstand and Badging Expedition One Rear Bumper,RE 4.5" Long Arm Kit,5.13s, Black Riddler Diff Covers, Hypertech Airaid CAI, PIAA 540s w/flush mounted switch, Flowmaster 40, 325/60/22 BFGs and the list goes on...
SaharaBlackNo1 is offline
post #14 of 38 Old 04-19-2009, 05:25 AM Thread Starter
Av8terZ06
I dont know anything about the 07 model but I did run across this when I was looking up information on mine. Not sure if its true or not, might be worth looking into.
""Even though I and my parts guy said 1000 times it wont work for the 07' I believe that to be false now. With the instructions I got from my parts dude for the "08' Remote Start Kit" a internal email was included that said "For 2007 model vehicles, the factory remote start system contains a provision which does not allow the system to be operational until the vehicle is driven for 50 miles. This provision was eliminated on 2008 model year vehicles" SO it sounds like it will work, or at least it may be worth a try. I couldn't imagine the 07' and 08's being that different. I do know that my 08' came with a wire harness pre-wired for the hood pin switch. The remote start kit did however come with the wire harness in the box "incase" the harness wasn't pre-installed from the factory... maybe this is for the 07's??? Hopefully this info can be of a help for the 07's guys.""
2007 Corvette Z06
post #15 of 38 Old 04-19-2009, 05:50 PM
asknight
Will this system work on a Jeep without power windows/locks?
My wife enjoys the remote start during the winter, but a Jeep doesn't need electric windows and stuff.
asknight is offline
how to , installation , JK Wrangler , remote start , wrangler
08 Unlimited and Viper 5301 remote start install trouble kwazyace JK Wrangler Technical Forum 1 02-02-2010 10:20 AM
Install remote start on JK 2.8 CRD simov_mincho JK Wrangler Technical Forum 5 11-05-2009 09:15 AM
'98 Wrangler Remote Start Wiring HELP! SoccerJett TJ Wrangler Technical Forum 3 12-26-2008 08:50 AM
Remote start install Q, heater power? CLynn85 TJ Wrangler Technical Forum 4 01-09-2006 06:12 AM
How hard is remote start install? patriot2005 TJ Wrangler Technical Forum 6 12-08-2005 10:27 PM
