How the heck? Transmission fluid 2008 JK Wrangler Shara - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > How the heck? Transmission fluid 2008 JK Wrangler Shara
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 04-10-2015, 12:35 AM   #1
KenDWpg
OK ... so maybe im mildly retarded...
Had my JK for 5 years... never thought about the transmission... cuz its manual man! -_- LOL
I see a bit of a fluid leak in the driveway.
The clutch is making a bit of noise.
I go to look at the transmission levels... OK... wheres that darned dipstick.
WTF!?!?!
How the heck? Transmission fluid 2008 JK Wrangler Shara unlimited.
How do I check it?
Is the noisy clutch - when let out - because of low levels?
Any help for the know not... would be great : )
KenDWpg is offline   Reply With Quote Quick reply to this message
Unread 04-10-2015, 01:06 AM   #2
ronjenx
ronjenx's Avatar
Manual transmission has a fill plug on the side. The fluid should be up to the bottom of the fill hole when the Jeep is sitting on level ground.
2008 JKU Rubicon
42RLE Auto
ronjenx is online now   Reply With Quote Quick reply to this message
Unread 04-10-2015, 01:12 AM   #3
KenDWpg
Like under the vehicle bro?
Unread 04-10-2015, 01:16 AM   #4
ronjenx
ronjenx's Avatar
On the right side of the transmission.
2008 JKU Rubicon
42RLE Auto
Unread 04-10-2015, 09:48 AM   #5
ncb
The manual transmission fluid should be changed every 30K miles.
It might be the clutch cylinder that's leaking. It uses fluid from the brake master cylinder. There's a portion of the reservoir that's partitioned to supply fluid for the clutch cylinder.
ncb is offline   Reply With Quote Quick reply to this message
Unread 04-10-2015, 11:20 AM   #6
JIMBOX
YUP, REMEMBER, it's a hydraulic clutch---there is no mechanical linkage between the clutch foot lever and the "Throw out" Bearing"-
Check the bottom of the tranny/eng. Bell housing and lookfor "DROPS/STAINS"
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote Quick reply to this message
Unread 04-10-2015, 02:45 PM   #7
KenDWpg
Thanks ! : )
Unread 04-10-2015, 02:47 PM   #8
KenDWpg
Thanks! : )
Good luck
JIMBO
Unread 04-10-2015, 02:47 PM   #9
KenDWpg
Great advice guys! : )
Ill look into this stuff : )
Thanks!
Unread 04-10-2015, 03:05 PM   #10
JIMBOX
Thanx KW, here's another tidbit-
I'll look into this stuff : )
Thanks!
Most hydraulic clutch's exert their max pressure on the throwout brg fork-in the CLUTCH PEDALS FIRST 6 INCHS OF TRAVEL, so there's no use to fully depress the clutch for each shift-you can develop a 1' leg cycle that works very quick/convenient-
I think you do have to for the ignition start on the JK-
Whatever
JIMBO
Yellow Jeep No. 683
Unread 04-10-2015, 05:47 PM   #11
KenDWpg
Just another question...
If it is transmission fluid leaking... And I have never changed it or had it changed...
What color would it be... ???
I have red stuff dripping at at the bottom of the bell-housing...
cant see it coming from anywhere else... looks like its coming from right at the bottom there...
Unread 04-10-2015, 07:39 PM   #12
Neo1130
2015 JK Wrangler
If it's leaking there, probably the input shaft seal. A shop will need to do it for sure. It'll also screw with the clutch when the fluid gets on the friction surfaces...
Neo1130 is online now   Reply With Quote Quick reply to this message
Unread 04-11-2015, 04:40 PM   #13
ncb
What type/brand would be red?
Unread 04-11-2015, 04:52 PM   #14
JIMBOX
Beats me, sounds like a FORD Pwr steering fluid-
Could be some wild combo, but IDK-
JIMBO
Yellow Jeep No. 683
Unread 04-13-2015, 07:41 AM   #15
duneslider
ATF+4 is red. Is that what they use in the manual transmission too? Most transmission fluids are red aren't they?
duneslider is online now   Reply With Quote Quick reply to this message
transmission fluid level
