How do you reset the LOWER TIRE SENSOR - JeepForum.com
post #1 of 28 Old 12-25-2010, 01:04 PM Thread Starter
Bruno03
2010 JK Wrangler
i can't seem to get the sensor to go out, my tires are dead on with PSI and yet the light wont go out..PLEASE HELP!
Bruno03 is offline
post #2 of 28 Old 12-25-2010, 01:12 PM
Joevacs
2010 JK Wrangler
overinflate to maybe 40 and drive a while, then let it back out to 37
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #3 of 28 Old 12-25-2010, 01:22 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Did you check the pressure in the spare?
It will chime once for each sensor that is low, how many chimes are sounding at start-up?
Jim
JLC08JK is offline
post #4 of 28 Old 12-25-2010, 04:46 PM
Dogzilla
The spare will NOT set off the alarm.
Dogzilla is offline
post #5 of 28 Old 12-25-2010, 07:14 PM
krutj
2009 JK Wrangler
Hey Dogzilla...I'm still waiting to see the pic of your new white JK..
BTW, my spare has set off the alarm..fyi and Happy New Year!!
-- Joel --
krutj is offline
post #6 of 28 Old 12-25-2010, 07:20 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Yes the spare can & has set off my tpms alarm.
RockyClymer is online now
post #7 of 28 Old 12-25-2010, 07:59 PM
jeep161
2009 JK Wrangler
Had the same problem just over inflate and then deflate..
jeep161 is offline
post #8 of 28 Old 12-25-2010, 08:39 PM
JIMBOX
Just go buy an AEV Procal Module and take care of the TPMS forever !!
Calibrate speedo/ adj auto tranny/ disable TPMS/ configure driving lights-etc !!
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #9 of 28 Old 12-26-2010, 08:29 AM Thread Starter
Bruno03
2010 JK Wrangler
Jim, im only getting one chime..so maybe i will check the spare but that just seems crazy since the spare is hooked to the back door. Thanks for the advice and i will try these helpful tips.
Bruno03 is offline
post #10 of 28 Old 12-26-2010, 11:02 AM
Washi
Rockbiter
Washi's Avatar
2009 JK Wrangler
It may be on the tailgate, but it still has an active sensor on it. Why wouldn't it?
Originally Posted by 00JGC00 View Post
Meh. Jake's is longer. I've seen it...
__________________________________________________ __________________________________________________ _______________________________________
/l ,[_____],
l----L-OlllllllO-
()_) ()_)-o-)_)
Washi is offline
post #11 of 28 Old 12-26-2010, 12:48 PM
smess
Junior Member
2011 JK Wrangler
same problem the tires are all at 34 lbs and the sensor light wont go off, i even disconnected the battery.
any ideas?
bad sensor? will a bad sensor make the light saty on forever or do they normally go bad and then stop sending signal so they dont cause the light to trigger?
smess is offline
post #12 of 28 Old 12-26-2010, 01:09 PM
Dogzilla
This has been posted before from the manual.
A tire pressure monitoring sensor is located in the spare
wheel if the vehicle is equipped with a matching full size
spare wheel and tire assembly. The matching full size
spare tire can be used in place of any of the four road
tires. A low spare tire will not cause the “Tire Pressure
Monitoring Telltale Light” to illuminate or the chime to
sound.
The “Tire Pressure Monitoring Telltale Light” will
illuminate in the instrument cluster, and an audible
chime will be activated when one or more of
the four active road tire pressures are low.
Again...It's in the manual.
Reason? The centrigal force is what activates the sensor through inertial movement caused by the rolling of the wheel. The spare doesn't roll.
Dogzilla is offline
post #13 of 28 Old 12-26-2010, 01:20 PM
him
2010 JK Wrangler
...the tires are all at 34 lbs and the sensor light wont go off, i even disconnected the battery.
any ideas?
Yeah, crank 'em to 38+. As has been said before, TPMS won't reset until the pressure is quite high.
him is offline
post #14 of 28 Old 12-26-2010, 02:26 PM
kudah
What tire pressure is on the tab on your door frame? I know for Rubicon's they think 37lbs is optimal. The sensor is supposed to turn on the light at 30lbs and turn off at 34. A lot of times it will take 35 or more to get mine off. btw it is adjustable by the dealership. I lowered my target to 30lbs so that when airing up after wheeling I didn't have to hit 35 all the way around to get the light off. The light is not that big of a deal, but unfortunately when it is on my odo will not dim with the dash lights, so it stays on full bright. that annoys me.
Robert
kudah is offline
post #15 of 28 Old 12-26-2010, 02:58 PM
krutj
2009 JK Wrangler
sound.
Yeah, well it's crazy because this Spring, when I rotated(tires are aired down for the winter) I aired up all the tires on the ground, kinda forgot the spare, alarm stayed on, aired up the spare, alarm went off...why?
-- Joel --
krutj is offline
ECM reset after crankshaft position sensor installed? dmw319 TJ Wrangler Technical Forum 12 10-07-2010 09:45 AM
do i need to reset computer after i replace my map sensor ??? Smith TJ Wrangler Technical Forum 2 09-17-2010 11:23 AM
Tire Rub On Lower Control Arm JEEPBUDDIE TJ Wrangler Technical Forum 3 03-31-2009 06:50 AM
95 4.0L changed oil pressure sensor, now has lower psi than before?!? Obie95Sahara YJ Wrangler Technical Forum 8 01-16-2009 11:06 AM
Throttle Position Sensor - Reset/adjust? Doc_Vegas TJ Wrangler Technical Forum 20 06-05-2006 09:47 AM
