how to disable traction control? - Page 4 - JeepForum.com
post #46 of 56 Old 10-29-2012, 03:34 PM
BadTrainDriver
Originally Posted by kudah View Post
you can not fully disable the traction control in 2012 and newer Wranglers. The option has been removed. It is fully disabled in 4lo only and it does that automatically.
2007 Wranglers some will need a software update to make the steering wheel dance possible.
Also you can turn the steering wheel from 180-270 degrees, it has to see 180 or more degrees of turn.
Aeroforce turns everything off, fyi.
2012 Jeep Wrangler Unlimited Rubicon
Stock, for now...
BadTrainDriver is offline
post #47 of 56 Old 11-01-2012, 12:10 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Originally Posted by Spaschal View Post
I have an 07' so I don't need do to the "steering wheel dance" to disable my ESP in 4H. How do I truly disable in 2WD? I don't know if it is even posible.???
Your profile shows you have a JKU.
Do you have a 4X4 or a 4X2?
JeepCares is online now
post #48 of 56 Old 11-01-2012, 12:24 PM
calys003
Are you talking about the AeroForce Interceptor gauge?
Do it right the first time or don't do it at all.
calys003 is offline
post #49 of 56 Old 11-01-2012, 01:49 PM
BadTrainDriver
Yes, sir.
Stock, for now...
post #50 of 56 Old 11-01-2012, 06:34 PM
calys003
I just turned of my esp by using the aero force gauge. The jeep had to be running to do so, the only thing is I had a lot of lights turn on once I did this. ESP off light, ESP activation light, parking brake light, abs light. So It worked! But I had a Christmas tree of lights on my dash.
calys003 is offline
post #51 of 56 Old 11-01-2012, 09:04 PM
kudah
Some 2007 Wranglers did not have the ability to fully disable ESP, they needed to have a software update done by the dealer to enable the "steering wheel dance" procedure.
2007 was the first model year of the JK, that's when they realized people lifting jeeps and putting on bigger tires were having issues with the ESP.
Robert
kudah is offline
post #52 of 56 Old 11-02-2012, 08:13 AM
jstrubberg
2009 JK Wrangler
Lifts and tires don't cause ESP problems.
Improperly aligned suspension components and steering wheels cause ESP problems.
jstrubberg is offline
post #53 of 56 Old 11-05-2012, 12:48 PM
Spaschal
I have a 4x4. Like I noted, I can hold down the button while in 4H and the ESP disable shows up on the dash. My question was if it is possible to disable it while in two wheel drive?
Thanks...
Spaschal is offline
post #54 of 56 Old 01-01-2013, 12:10 AM
toxicwaste29
Im new at this stuff, if i were to put in lockers, what would i do with traction control, would it still be all hooked up except to the axle so the computer never senses slip so the tc never kicks on?
toxicwaste29 is offline
post #55 of 56 Old 05-26-2013, 05:05 PM
Waltjason
2011 JK Wrangler
Just in case anyone hasn't been able to accomplish this yet I have just done it and it works in 2wheel drive. I followed everyone's posts but had to use a watch which I placed on the dash have to hold for exactly 7seconds you will get a beep at 5 secs then one when let go at 7 seconds. It only took me months to figure this out. Now does anyone know how to turn of the ESP light I don't need that on while driving. But it does tell me ESP off after all the warning lights go off one it is started
Waltjason is offline
post #56 of 56 Old 05-26-2013, 07:19 PM
Waltjason
2011 JK Wrangler
Is there a bulb I can pull?
Traction Control & Electronic Throttle Control Lights PSYCH0 JK Wrangler Technical Forum 4 07-18-2012 10:41 AM
Traction control cosmoblue JK Wrangler Technical Forum 9 10-21-2011 09:46 AM
Traction control Robbish87 JK Wrangler Technical Forum 4 12-14-2010 01:14 PM
8.8 with traction control? Fun2Jeep YJ Wrangler Technical Forum 9 03-08-2009 10:43 AM
TSB - Electronic Stability Control Disable Feature For Modified 4WD Vehicles JRunner01 JK Wrangler Technical Forum 8 01-15-2009 07:36 AM
