how to disable traction control? - Page 2 - JeepForum.com
post #16 of 56 Old 12-06-2011, 10:09 AM
Canadian-Bear
2011 JK Wrangler
Originally Posted by RedRubiconLJ View Post
So even though I dont have it on my LJ I cant turn it on?
I hope you know Im messing with you....
Have you watched the movie "Badder Santa"? Well, Billy Bob Thornton (Willie) is playing checkers with the "little" boy (Therman). The boy moves his pieces, back and forth, and he isn't quite sure where he is going to move next. Meanwhile, Willie is sitting there growing impatient until the boy finally makes his move and jumps a few of Willie's pieces, and then says "King me". Then Willie snaps and throws the board, and pieces, and says, "SOB! You lousy cheating little sh*t! You are f****** with me. You did that on purpose. You sit there and play like the dead lice are falling off of you, and then suddenly, you're like Seabiscuit all over the place. You're a smart a**, is what are you, kid."
That scene is absolutely hilarious!
2011 CANADIAN BEAR JK
/l ,[____],
l----L-OlllllllO-
()_) ()_)-o-)_)
Canadian-Bear is offline
post #17 of 56 Old 12-06-2011, 10:18 AM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
Love the movie!!!! hahahahahah
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #18 of 56 Old 12-06-2011, 02:06 PM
jrod250
2011 JK Wrangler
Like I said in my first post. This needs to be done 100% correctly. If you mess it up at all then it will not work.
As far as holding the button for 5 seconds. Yes that deactivates it when and only when your in 4H. If you do the steering wheel trick, that deactivates it ALL THE TIME EVEN IN 2WD.
In 4Lo that tractional control automatically turns off
jrod250 is offline
post #19 of 56 Old 12-06-2011, 03:26 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
The easiest way to disable traction control and all those other computer demons on a JK that we ***** about is sort of like a priest exorcising any demon - only using gasoline instead of holy water and a bic lighter instead of a thurible....
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #20 of 56 Old 12-07-2011, 08:54 PM Thread Starter
MoreMud
So, can you confirm you've been able to do this on your '11 ?
MoreMud is offline
post #21 of 56 Old 12-08-2011, 12:47 PM
jrod250
2011 JK Wrangler
Yes, I have done this on my 2011. It took me 4 times before if was successful.
If you download the owners manuel, that also gives detailed directions on how to disable it.
jrod250 is offline
post #22 of 56 Old 12-08-2011, 12:59 PM
jrod250
2011 JK Wrangler
I COPIED AND PASTED THIS RIGHT FROM THE OWNERS MANUEL
The following procedure will disable (or re-enable) ESC functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESC OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn to the left (counterclock- wise).
8. Press and hold the ESC OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESC OFF button for seven sec- onds.
11. Cycle the ignition key to OFF.
After performing the ESC disable procedure correctly, “ESC OFF” will be displayed in the odometer for ap- proximately 12 seconds each time the ignition is moved to ON. Repeating the ESC disable procedure will re- enable normal ESC operation.
jrod250 is offline
post #23 of 56 Old 12-08-2011, 01:07 PM
paulygi
When I 1st read this process I though you guys were joking. Wow, it is definately not something you would do by accident.
Since I haven't lifted or changed the tires, I'll just use the ESP Off or Partial mode
2012 Sahara JKU Auto ,All stock fully loaded.
paulygi is offline
post #24 of 56 Old 12-08-2011, 01:51 PM
Reelworks
Just a dummy question, but what are pros/cons of turning this off?
thanks
Reelworks is offline
post #25 of 56 Old 12-08-2011, 02:11 PM
jrod250
2011 JK Wrangler
The main reason why I disabled mine was to extend the life of the back brakes. The traction control is constantly applying the brakes if it thinks anything is out of the ordinary.
It also annoying when you try to pull out in traffic on a wet road and the engine dies out, because you spin your tires a little.
jrod250 is offline
post #26 of 56 Old 12-08-2011, 02:41 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
i did mine, but it acts like it doesnt want to take after you turn it off in 2wd. works just fine in 4 high.
maybe i missed something?
no longer says ESCOFF in the dash when you turn it on
My builds:
and
or follow us on
spyder6 is offline
post #27 of 56 Old 12-08-2011, 03:51 PM
spyder6
spyder6's Avatar
2010
I've tried this a dozen times. i don't think it exists, i think you're all lying to me
My builds:
and
or follow us on
spyder6 is offline
post #28 of 56 Old 12-08-2011, 03:59 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
You gotta cross the pinky toe of your left foot over the big toe of your right while you do it or it won't work...
(the steering wheel input has to be real good - and it does tend to want to come back a bit when you relax the input)
post #29 of 56 Old 12-08-2011, 05:38 PM
Reelworks
thanks
Anyone? I seriously don't know squat about the traction control. My last jeep was a 1998 and traction control was not stomping on it in wet weather :-)
post #30 of 56 Old 12-08-2011, 06:28 PM
spyder6
spyder6's Avatar
2010
JP said you could do it with the motor on, so i did. but i also did it with the motor off (in on position). i literally did it by the book and i cannot make it happen.
i wish someone would post a video
My builds:
and
or follow us on
spyder6 is offline
Traction Control & Electronic Throttle Control Lights PSYCH0 JK Wrangler Technical Forum 4 07-18-2012 09:41 AM
Traction control cosmoblue JK Wrangler Technical Forum 9 10-21-2011 08:46 AM
Traction control Robbish87 JK Wrangler Technical Forum 4 12-14-2010 12:14 PM
8.8 with traction control? Fun2Jeep YJ Wrangler Technical Forum 9 03-08-2009 09:43 AM
TSB - Electronic Stability Control Disable Feature For Modified 4WD Vehicles JRunner01 JK Wrangler Technical Forum 8 01-15-2009 06:36 AM
