How to disable the seat belt alarm or 07 4door - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > How to disable the seat belt alarm or 07 4door
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 09-14-2008, 11:12 AM   #1
kentpolo
How do i disable the seat belt allarm on the 07 4 door like wat is the code or the sequence you need to do anybody now pleas help i drive around the ranch mostly and the seat belt alarm drives me up the wall.
2007 JK X balck 3.5 Ich lift on 18 Pro Comp Xtream with 35 Inch Nitto Mud Grapplers
Its A Beast
kentpolo is offline   Reply With Quote
Unread 09-14-2008, 11:35 AM   #2
Gordon2
Go to a junk yard and get an extra seatbelt latch. Keep it in center console.
Gordon2 is offline   Reply With Quote
Unread 09-14-2008, 02:14 PM   #3
Rafic
The seatbelt chime can be turned on or off by your dealer, given that they would agree to do it for you that is. As another option, I've found this on another website a long time ago and saved the procedure on a word document. I never tried it but I remember that everyone who did try said it worked. Here goes:
"NOTE:
The following steps must occur within the first 60 seconds of the ignition switch being turned to the ON or START position.
The manufacturer does not recommend deactivating the Enhanced Warning System (BeltAlert).
1. Turn the ignition switch to the OFF position, and buckle the driver’s seat belt.
2. Turn the ignition key to the ACCESSORY/RUN position (engine does not need to be running), and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver’s seat belt at least three times within 10 seconds, ending with the seat belt buckled.
4. Turn the ignition key to the OFF position. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated by repeating this procedure.
NOTE:
Although the Enhanced Warning System (BeltAlert) has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver’s seat belt remains unfastened."
Let us know how it goes....
Cheers!
Rafic is offline   Reply With Quote
Unread 09-14-2008, 02:16 PM   #4
BiGEN
give me 5 mins and i will do it right now...
FOR SALE!
R.E. Monotube Shocks - $200 NEW PRICE
VAJeepTrailDogs
[/color]
BiGEN is offline   Reply With Quote
Unread 09-14-2008, 02:25 PM   #5
BiGEN
ok... mine worked..
FOR SALE!
VAJeepTrailDogs
[/color]
Unread 09-14-2008, 02:36 PM   #6
Rafic
Great...gonna go try now...
Unread 09-14-2008, 02:43 PM   #7
Rafic
Worked as well...
Unread 09-14-2008, 05:57 PM   #8
TRAVLIN
the instructions are in your owners manual
TRAVLIN is offline   Reply With Quote
Unread 06-02-2010, 07:34 PM   #9
troy32323
2010 JK Wrangler
Sweet. It works! I was just about to cut the wires and twist them together like I did on my Tacoma.
troy32323 is offline   Reply With Quote
Unread 04-27-2011, 11:40 AM   #10
ratat98
2011 JK Wrangler
Works on a 2011 also!
"If it looks too deep, drive faster!"
"Watch out for that- ...Oh..nevermind..."
ratat98 is offline   Reply With Quote
Unread 04-27-2011, 12:23 PM   #11
ncb
Plasti Dip yourself!
ncb's Avatar
2009 JK Wrangler
It seems like nobody reads the OM, or is it because they don't offer a paper version anymore?
ncb is offline   Reply With Quote
Unread 04-27-2011, 01:37 PM   #12
JEEP_GREEN_4DR
2009 JK Wrangler
WEAR the damned thing and this isn't an issue.
I know at least one Jeeper who is missing a leg because he overlooked his seatbelt and got into an accident.
His belted passenger suffered only a broken collarbone where the belt crossed over his left shoulder.
Take your pick, YMMV.
Jeepers Have Heart.
JEEP_GREEN_4DR is offline   Reply With Quote
Unread 11-24-2011, 11:10 PM   #13
Stewie Griffin
Originally Posted by Rafic View Post
"NOTE:
NOTE:
Cheers!
just a heads up, I tried this on my 2012 Rubicon and it works. I no longer have the seatbelt alarm screaming at me on short trips
Current:
2012 JK Rubicon
Past:
'01, '02, '04 TJ Saraha, '06 TJ Rubicon
Stewie Griffin is offline   Reply With Quote
Unread 11-25-2011, 06:00 AM   #14
8figgas
Just because you bought every bolt-on accessory available for your jeep, doesn't mean you know WTH your doing or talking about...
8figgas is offline   Reply With Quote
Unread 11-25-2011, 07:00 AM   #15
JEEP_GREEN_4DR
2009 JK Wrangler
Still applies.
Jeepers Have Heart.
